Can't wait to try it out!
Sent from my VM670 using Tapatalk 2
Cool well will release build tommorow with key switch
Sent from my LG-LS670 using Android Central Forums
I might just cave in and flash to ZVJ and try this out myself.
Been needing to try a new non ICS or JB rom xD
@Andrew, if I somehow successfully flash to ZVJ and root it, I will write out everything I did, so you could try too.
sent from my un-dead sammich.
I believe he did it already. I believe it was him when I did it too. I don't recommend it though if your a busy person. You miss ALOT of Phone calls and messaging. It's kinda a long process.
The patch should work on here ither way.
Is this based on Stock? If so, MMS will fail to work.
Yes it is nitestalkr was talking about a mms fix sooooooo maybe and maybe not
Unless Jonny managed to find a fix for it
Anyone want screenshots?????
Or should I wait until I release
REMEMBER PEOPLE FLASH HYDRO KERNEL OR IT WILL NOT OC AND IT WILL BE SLOW I KNOW I TRIED IT
Can't you add the boot.img from HydroROM?
Sent from my Optimus V running OSZVJ firmware on MetroPCS using HydroROM.
Wouldn't that bring the
TEAM HYDRO
PRESENTS
Yes I could but permission whatz I needs so I go ask drew
Didn't you just read that disclaimer? He denied permission already. Plus, adding the boot.img will add Team Hydro's trademark.
Just release with stock kernel and direct to HydroKernel thread. Its bot a big deal.
Post em!
Screen shots are usually a good teaser before a ROM gets released.
It's not good to have a WIP up with nothing released but text for to long.
