09-01-2012 01:07 PM
788 ... 89101112 ...
tools
  1. nitestalkr's Avatar
    I'm just curious, but what made the launcher have the icons overlap things? I've never seen it before
    I'm assuming that its due to our screen resolution, and the launcher was probably made for a larger resolution.
    sent from my Zom-"Bean"(CM10 JellyBean) .
    08-09-2012 07:48 PM
  2. JadenBrown30's Avatar
    Yeah that's what I was thinking, is it an easy fix? :o
    08-09-2012 07:50 PM
  3. andrewnelson23's Avatar
    Use a different launcher xD maybe zakman could put a different one in alpha 4
    08-09-2012 07:55 PM
  4. JadenBrown30's Avatar
    Haha yeah, I'm using Apex right now
    08-09-2012 08:08 PM
  5. Master Gowa's Avatar
    Nova launcher works great on this rom too.
    08-09-2012 09:37 PM
  6. jonny5449's Avatar
    ya im guessing the launchers jb and ics are not that different
    got dsixda kitchen setup
    but when i extract boot image i get Z image
    and ramdisk something
    i searched for kernel file and could not find it
    08-09-2012 10:14 PM
  7. anthonycr's Avatar
    The launchers aren't that different but there are differences. The jellybean source cannot be compiled against the ICS framework so there are some significant differences, but its probably under the hood
    08-09-2012 10:17 PM
  8. andrewnelson23's Avatar
    I'm pretty sure z image is the kernel.
    08-09-2012 10:18 PM
  9. inceyet's Avatar
    Yo y'all are killing it with this rom so much progress is unreal great work guys , my hat goes off to y'all . Just waiting for the borked SMS to be fixed and the camera cause I need that and as soon as that is fixed it'll be dd
    REKCITY
    08-09-2012 10:21 PM
  10. jonny5449's Avatar
    hey all i have a question
    would the apps2ext fix the apps going bye bye problem
    08-09-2012 10:31 PM
  11. jonny5449's Avatar
    if z image is kernel i will do a test now
    08-09-2012 10:33 PM
  12. jonny5449's Avatar
    Okay boot image won't repack
    The kitchen does not have an option to repack help :o:o
    looking for good keyboards??
    visit
    jonskeyboards.com
    08-09-2012 10:44 PM
  13. jonny5449's Avatar
    Okay just about done just says I don't have working folder any suggestions
    visit
    jonskeyboards.com
    08-09-2012 10:56 PM
  14. nitestalkr's Avatar
    I am currently working on the app2ext issue, and i'll be testing it via flashable zip on top of alpha3, and if i am successful, i'll upload it to be implemented into the ROM.
    jonny5449 likes this.
    08-09-2012 11:19 PM
  15. jonny5449's Avatar
    I'm sooooo close to repacking boot.img but it keeps saying no working folder found
    visit
    jonskeyboards.com
    08-09-2012 11:23 PM
  16. andrewnelson23's Avatar
    Yes, the sd-ext scripts will fix the app disappearing problem. Make a working folder haha I don't know. :P
    08-09-2012 11:24 PM
  17. nitestalkr's Avatar
    @Zackman, i noticed that the following isn't included in the update-script of the ROM, I'm not exactly sure if its needed or not, or what significance it serves, of if it's even needed at all.
    Code:
    assert(getprop("ro.product.device") == "thunderc" || getprop("ro.build.product") == "thunderc" ||
           getprop("ro.product.device") == "VM670" || getprop("ro.build.product") == "VM670" ||
           getprop("ro.product.device") == "thunderc_VM670" || getprop("ro.build.product") == "thunderc_VM670");
    EDIT:
    Backing up my phone now, and going to try out the sd-ext scripts
    EDIT:
    Now testing if the sd-ext scripts worked, by installing as many random apps from the market as i possibly can
    EDIT:
    Well, I'd say after installing 153 random apps, it's safe to assume the scripts work xD
    andrewnelson23 likes this.
    08-09-2012 11:26 PM
  18. Zakman's Avatar
    Which launcher? Apex or nova to be implemented into alpha 4
    08-10-2012 12:31 AM
  19. andrewnelson23's Avatar
    NOVA. Allows the resizing of widgets
    (and lots of customization)
    Edit: idk if apex does. never used it.
    08-10-2012 12:41 AM
  20. JadenBrown30's Avatar
    LOL I'll sure miss the Jelly Bean animations :o
    08-10-2012 12:48 AM
  21. nitestalkr's Avatar
    I say NOVA, its what I always install afterwards
    And, I'll upload the sd-ext fixes for you to use in alpha 4.
    I'm not sure if the scripts caused it, or if it was in alpha3, but when i access storage from settings, it force closes..
    but at least the scripts work
    sent from my un-dead sammich.
    08-10-2012 12:49 AM
  22. nitestalkr's Avatar
    @Zackman, instructions are included in the zip, this is NOT flashable(however, I will include this in all of my patches I made, by Saturday.), and this is to be implemented into the ROM.
    08-10-2012 01:05 AM
  23. andrewnelson23's Avatar
    how is it different than your super fix that included the sd ext scripts in it??
    08-10-2012 01:10 AM
  24. nitestalkr's Avatar
    These ones do not require the ROM to be booted first, and they are init.d scripts, so they work upon install of the ROM.
    I manually pushed these scripts into Alpha3 to see if it works upon install of the ROM, and it does. So, I'm going to put these into my super fix as well, 'cause these are easier to install than the ones i already have.
    These also produce absolutely 0 install errors, where as the ones in the Super fix will produce an error due to them needing to be booted before installation.
    These are just overall better than the ones I used originally.
    08-10-2012 01:20 AM
  25. andrewnelson23's Avatar
    I'm at a loss for mms, guys.
    LASDFKJ A;LSDFKJ;ALSDK FJ;LASKDFJ;LASKDFJ;ALSDKJF ;IDUF OEWIL ,.CXKJVH;LSF!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! .
    I was SO close! stupid sending sms. ugh. I'm just still too much of a noob for this. -_-
    08-10-2012 01:20 AM
