09-01-2012 12:07 PM
788 ... 1112131415 ...
tools
  1. jonny5449's Avatar
    You dont move them, the scripts move them for you automatically, even upon install of new apps, instead of them installing to /data/apps they install to /sd-ext/data/apps (<-- may not be exact location, just an example) all by themselves.
    sent from my Zom-"Bean'(CM10 JellyBean).
    On the s rom I included these scripts and after every reboot its back on my phone not on SD and when I click move to SD it moves but after reboot its back on phone ??? Suggestions
    Sent from my LG-LS670 using Tapatalk 2
    08-11-2012 07:51 AM
  2. nitestalkr's Avatar
    You do not move them to sdcard, the apps are no longer on the phone, but instead on the sd-ext, just like quattrimus.
    jonny5449 likes this.
    08-11-2012 07:56 AM
  3. r0gu3dev1pr's Avatar
    Just to reiterate what @nitestalkr is saying. With app2ext there is no need to manually move apps to the sd card. The app2ext script relocates your apps automatically to the ext partition on your sdcard. I personal like using Xionia CWM Recovery to partition my SD Card since it has the ability to convert ext2 to ext3 or ext4 which are more efficient.
    http://forums.androidcentral.com/lg-...-2518-6-a.html
    First back up your SD Card to your PC. Boot into your recovery. Then under the Advanced Menu there is an option to Partition your SD Card. I chose to set my ext partition to 1024MB. You can skip adding a SWAP. By default your partition is ext2, however If you are using Xionia, there is an option to convert to ext3. After your convert it to ext3 you can convert it to ext4. Once your ext partition has been created, then you can restore your SD Card.
    Also, Quattrimus works with or without the ext partition, however you won't take advantage of the app2ext script and you will run out of space.
    jonny5449 and nitestalkr like this.
    08-11-2012 09:11 AM
  4. jonny5449's Avatar
    Couldn't we use a theme engine from another arm6 mdpi cm10 ROM?
    08-11-2012 10:09 AM
  5. nitestalkr's Avatar
    If you port it, yea.
    08-11-2012 10:14 AM
  6. jonny5449's Avatar
    Hmmmmm can anyone point me to one????
    08-11-2012 10:32 AM
  7. Zakman's Avatar
    OK, I'll add the scripts to my ROM asap.
    08-11-2012 12:24 PM
  8. jonny5449's Avatar
    Good I already did
    08-11-2012 12:27 PM
  9. kobequintana's Avatar
    Could I get the gapps I tried the link but it went to medifire error page
    08-11-2012 12:58 PM
  10. JadenBrown30's Avatar
    Is there a workaround with voicemail? I can't get the icon to go away :o
    08-11-2012 01:13 PM
  11. inceyet's Avatar
    Wait for another call to go to voicemail
    JadenBrown30 and jonny5449 like this.
    08-11-2012 02:29 PM
  12. nitestalkr's Avatar
    Or just dial your own number, call it, and listen to your voicemail
    08-11-2012 04:44 PM
  13. jonny5449's Avatar
    @ zakman
    Do you plan on including apex or nova in the ROM? I just asked permission for both (I'm putting both)
    08-11-2012 07:14 PM
  14. jonny5449's Avatar
    @zakman
    i think this is the right boot image try it and tell me it has kravens 15th kernel the one you wanted
    http://www.mediafire.com/?4l8j1c8rw06y3yj
    Zakman likes this.
    08-11-2012 07:48 PM
  15. heloworld's Avatar
    Gapps link not working.
    08-11-2012 08:08 PM
  16. kobequintana's Avatar
    Just flashed this ROM
    Looks like theirs not many apps for JB yet
    08-11-2012 08:08 PM
  17. jonny5449's Avatar
    True because the original porter has not included them
    08-11-2012 09:08 PM
  18. jonny5449's Avatar
    @zakman
    Link is down I will upload mine if you object I will take off
    08-11-2012 09:10 PM
  19. Zakman's Avatar
    @zakman
    boot.img
    Bootlooped.
    08-11-2012 11:24 PM
  20. jonny5449's Avatar
    Bootlooped.
    I know just tried
    Weird I unpackaged and repackaged with dsixda kitchen weird
    08-11-2012 11:35 PM
  21. Zakman's Avatar
    Uploading a build, and I was also wondering should i put in ICS google search for now or leave the broken google now?
    JadenBrown30 likes this.
    08-12-2012 12:08 AM
  22. jonny5449's Avatar
    Broken Google now
    08-12-2012 12:09 AM
  23. sellers86's Avatar
    I like your taste in music
    08-12-2012 01:46 AM
  24. Master Gowa's Avatar
    Will the CAI Test15 Kernel change my baseband?
    08-12-2012 08:21 AM
  25. jonny5449's Avatar
    Nope
    08-12-2012 08:41 AM
