two problems with the go fix. first, it only fixes one sided. (I think outgoing). You still can't receive mms. Second, it's a third party app. Which sucks because it adds folders and stuff. Personally, I love go sms, but a lot of people don't.
Is there a update on the mms /SMS fix as well as perhaps the camera fix all which are stopping this from being my dd . Thanks to all involved
Sent from REKCITY.com
I'm working on the camera fix, thekraven is assisting me, he's currently telling me what files should fix the camera, for now MMS, download go sms pro and enter in the settings.
I think it's a bug in the sd-ext script. It seems to be functioning but Titanium Backup still lacks the 4th blue storage bar at the bottom. Recently SD Maid displayed "storage/sdcard0". I don't think SD Maid listed that before Alpha 4. I'm guessing it's something in the way it mounts the sd card now.
No I think I read somewhere that Google changed that. Storage is now sdcard0 for a mount point
I specifically remember seeing it in previous versions. I might have even said something about it...Thanks for the clarification zakman!!! Here I was thinking it was the other way around!!! I never send other people pictures, but when otheres send me them I like to be able to see them. As soon as you get the camera fixed, it'll be ready for dd for me
Word good looking out zakman so go SMS pro will fix both SMS and mms out going and incoming
Every time I have to reboot the phone for various issues, it goes through the whole optimizing applications process all 70apps. Is this a known issue? Other than that appears pretty smooth
I do believe its a ics thing I know this is jb but its also on tdm's ics roms , from what I understand its really nothing
Storage/sdcard0 is the new default location of the SD card in jellybean, mnt/sdcard and /sdcard are still there, they're just no longer defaults. They all access the same exact thing.
The optimization of applications at every boot, is really annoying, and is a known issue. I've asked tdm about how he fixed it last week, but he never replied.
And I think some kernel work is going to be needed for jellybean, just had a random reboot after the second paragraph of this post(luckily tapatalk saved it as a draft lol). Random reboots dont happen very often(surprisingly), which is good.
