09-01-2012 12:07 PM
788 ... 1415161718 ...
tools
  1. nitestalkr's Avatar
    And for the voice search, would that be a kernel thing too?? Probably need voice recording capabilities as well for the camcorder.
    Anything that involves hardware can most like be fixed with the kernel, since the kernel handles hardware/software interactions.
    And voice search would be an issue with the app i think, since the mic is obviously working(calls).
    sent from my Zom-"Bean'(CM10 JellyBean).
    08-14-2012 01:13 PM
  2. andrewnelson23's Avatar
    hmmm. i even tried backing up the voice search from ics and restoring in jb. didn't work. lib issue?
    08-14-2012 01:20 PM
  3. nitestalkr's Avatar
    Its possible.
    Either that, or voice search isn't compatible with jb yet? Even though that is starting to seem like the answer to all app issues lol.
    08-14-2012 01:58 PM
  4. martinez41613's Avatar
    We're already using then ravens cm kernel which has the changes already
    Yeah, but those changes were to fix camera for ICS. It needs to be updated to support jb camera.
    Edit: Fixed MMS! ^_^
    It was just a matter of replacing apns-config with the one from quattrimus and nothing else lol.
    andrewnelson23 likes this.
    08-14-2012 04:04 PM
  5. jonny5449's Avatar
    Holy shizzle
    Sent from my LG-LS670 using Tapatalk 2
    08-14-2012 05:22 PM
  6. andrewnelson23's Avatar
    whaaaat. let me try. upload please! or I guess I could do it real quick haha
    08-14-2012 06:10 PM
  7. nitestalkr's Avatar
    Are you sure that fixes mms? Cause i tried that when I made the flashable patches(thanks again Zack for getting em started) and it supposedly never worked. The apns-config only fixes part of mms.
    08-14-2012 06:20 PM
  8. andrewnelson23's Avatar
    flashing now, gonna test.
    08-14-2012 06:28 PM
  9. needlez667's Avatar
    Not sure if you noticed this but your GAPPS arent mini, they're medium. Not trying to be an butt about it. But can you please post the mini or small Gapps so that they fit my screen correctly. If not ill see if I can find a link and post it myself for you.
    08-14-2012 06:48 PM
  10. kobequintana's Avatar
    So what's wrong with Google now
    08-14-2012 06:55 PM
  11. andrewnelson23's Avatar
    the mini/medium etc isn't about screen size. it's about the total size of the gapps. gapps mini is a very slimmed down version of gapps.
    I can confirm that sending and receiving mms works, as well as sending and receiving sms with only swapping out the apns-config.xml. :facepalm: can't believe I didn't think of only doing that.
    WOOOOHOOOOO MMS WORKING!!!!
    Edit: uploading.
    Edit: Here
    08-14-2012 07:02 PM
  12. capslock118's Avatar
    Not trying to be rude here, just a disclaimer:
    Why does MMS matter so much if there is no working camera to send through MMS?
    Congrats on the milestone though .
    08-14-2012 07:14 PM
  13. andrewnelson23's Avatar
    Screenshots also, the camera's only a matter of time. plus, fixing incoming mms is nice if your friends send pictures a lot(like my friends do)
    djboi2011 likes this.
    08-14-2012 07:16 PM
  14. nitestalkr's Avatar
    Edit: uploading.
    Edit: Here
    I'm still stumped as to why that fixed it now, but not when I did that not to long ago.. o.o
    Well I guess I'm going to flash it over alpha3(sdext modified).
    I didnt flash alpha4 because I technically I manually patched it myself
    08-14-2012 07:33 PM
  15. jonny5449's Avatar
    I have to track down files I messed with most mms so before I fix I must do that
    08-14-2012 08:06 PM
  16. eletendre84's Avatar
    Will the new alpha 4 mms fix work on sprint?
    08-14-2012 09:11 PM
  17. jonny5449's Avatar
    Nope because those are files from the vm670 quattrimus
    Use the files from the ls670 quattrimus and then it will work hopefully
    08-14-2012 09:34 PM
  18. andrewnelson23's Avatar
    It should if you use the optimus s quattrimus.
    08-14-2012 09:36 PM
  19. kobequintana's Avatar
    Edit: uploading.
    Edit: Here
    OK so I flashed it and gapps but the play store FC's any solution
    08-14-2012 09:53 PM
  20. andrewnelson23's Avatar
    That's weird. It wasn't fc-ing for me. And the fix has nothing to do with play store. Try wiping the play store data.
    08-14-2012 10:01 PM
  21. anthonycr's Avatar
    Just installed this after being too lazy to figure out why the jellybean ROM I just ported didn't boot and was not surprised by the errors occurring when I booted this ROM. However, I want to test Google now and after running a logcat and seeing that the problem is all related to the missing library google_endpointer_jni I figured that its a simple .so file we need or something. Of course it seems that none of the people on any forums understand this issue and I was just wondering if anyone has looked at the jellybean source code to look for what its asking for.
    08-14-2012 10:02 PM
  22. andrewnelson23's Avatar
    I don't know how to read source code All I know how to do is switch files and such. haha. You can't just swap the lib's out with one from a previous rom?
    08-14-2012 10:12 PM
  23. kobequintana's Avatar
    I just did a clean flash and re-flashed every thing
    08-14-2012 10:13 PM
  24. kobequintana's Avatar
    Found a new bug
    When turning of BT it freezes than reboots
    08-14-2012 11:11 PM
  25. sellers86's Avatar
    Found a new bug
    Kernel problem, it needs tdms new kernel and that should work.
    Sent from my VM670 using Tapatalk
    08-14-2012 11:33 PM
