09-01-2012 01:07 PM
788 ... 1516171819 ...
tools
  1. Zakman's Avatar
    the mini/medium etc isn't about screen size. it's about the total size of the gapps. gapps mini is a very slimmed down version of gapps.
    I can confirm that sending and receiving mms works, as well as sending and receiving sms with only swapping out the apns-config.xml. :facepalm: can't believe I didn't think of only doing that.
    WOOOOHOOOOO MMS WORKING!!!!
    Edit: uploading.
    Edit: Here
    Andrew, please do not reupload the whole rom, Give me the MMS fix(apns file) and I will impliment it. Thank you.
    08-15-2012 12:42 AM
  2. andrewnelson23's Avatar
    Sorry! And I totally would but had to finish packing for college and packed up my computer. Mediafire is impossible on this phone. I'll try 4shared since it's only for you anyyway
    08-15-2012 01:14 AM
  3. Zakman's Avatar
    Well, Ill just take it from your upload sir.
    08-15-2012 01:15 AM
  4. andrewnelson23's Avatar
    Again, sorry. Here's the .xml. here.
    Zakman likes this.
    08-15-2012 01:17 AM
  5. Zakman's Avatar
    Thank you sir.
    08-15-2012 01:35 AM
  6. nitestalkr's Avatar
    Just installed this after being too lazy to figure out why the jellybean ROM I just ported didn't boot and was not surprised by the errors occurring when I booted this ROM. However, I want to test Google now and after running a logcat and seeing that the problem is all related to the missing library google_endpointer_jni I figured that its a simple .so file we need or something. Of course it seems that none of the people on any forums understand this issue and I was just wondering if anyone has looked at the jellybean source code to look for what its asking for.
    Cant you just build the rom straight from google source and pull that lib?
    I don't know how to read source code All I know how to do is switch files and such. haha. You can't just swap the lib's out with one from a previous rom?
    Its a new lib(I think), so I doubt it.
    sent from my Zom-"Bean'(CM10 JellyBean).
    andrewnelson23 likes this.
    08-15-2012 02:09 AM
  7. Zakman's Avatar
    Mms will be fixed in next release and hopefully theme Chooser added
    08-15-2012 02:25 AM
  8. nitestalkr's Avatar
    I'm looking forward to that theme chooser!
    08-15-2012 03:02 AM
  9. JadenBrown30's Avatar
    So I'm just curious, but why does Google Now not work? Is it a hardware issue?
    08-15-2012 03:06 AM
  10. nitestalkr's Avatar
    Its a combination of several things.
    Missing lib files, the ARM encoder, the drop of ARMv6 support and a shift to ARMv7 standard, partial technical hardware incombatibilty, and the fact that the Optimus one line was not built for anything passed gingerbread in mind.
    08-15-2012 03:16 AM
  11. JadenBrown30's Avatar
    Missing lib files, the ARM decoder, the drop of ARMv6 support and a shift to ARMv7 standard, partial technical hardware incombatibilty, and the fact that the Optimus one line was not built for anything passed gingerbread in mind.
    Is there any chance that we'll ever see it fully working?
    08-15-2012 03:17 AM
  12. kobequintana's Avatar
    If we get all the stuff we need and its compatible with it
    08-15-2012 03:21 AM
  13. nitestalkr's Avatar
    Most likely, yes. But itd be a hacked up version made for ARMv6. (Just like many of the other ARMv7 apps working on ARMv6 devices)
    Its just a matter of time.
    08-15-2012 03:21 AM
  14. nitestalkr's Avatar
    Even with all of the missing lib files, it doesn't work, it goes deeper than having the missing files, a little bit of reverse engineering and code work is need as well.
    08-15-2012 03:24 AM
  15. bluespekk's Avatar
    For some reason when I download it it gets aborted and suggestions help?
    08-15-2012 03:26 AM
  16. nitestalkr's Avatar
    When you download, or install?
    If download, just redownload from a computer.
    If install, disable signature verification.
    08-15-2012 04:31 AM
  17. anthonycr's Avatar
    How can you be sure of that. We don't even have the lib files so you can't be sure it won't work if we get them.
    08-15-2012 06:23 AM
  18. nitestalkr's Avatar
    Just an educated guess.
    ~60% of the time, it's as simple as replacing the libs(or other files), the other ~40% requires something done to said libs(or other involved files).
    I'd say, find a JellyBean ROM(for any phone) that has Google Now fully functional, dissect the ROM, and see what can be done from there.
    08-15-2012 06:32 AM
  19. adamhos's Avatar
    So is mms fixed in alpha 4?
    Thanks
    08-15-2012 10:00 AM
  20. Zakman's Avatar
    Alpha 5 will be uploaded shortly with MMS fix and hopefully theme chooser, trying to fix theme chooser fc atm.
    adamhos and JadenBrown30 like this.
    08-15-2012 10:23 AM
  21. Zakman's Avatar
    Alpha 5 Uploaded, MMS fixed (Hopefully), added new youtube apk, Rashed97's Catapult launcher will be implemented when he releases it, Theme chooser FC's Right now guys, I dont know whats wrong with it and didnt have the time to fix it atm.
    adamhos, nitestalkr and inceyet like this.
    08-15-2012 10:48 AM
  22. Rudeco's Avatar
    Do I def need to flash the kernel? The link to it on the OP won't work.
    08-15-2012 11:36 AM
  23. Zakman's Avatar
    You do not needs it but it is recommended, I'll reup it when I get home
    08-15-2012 02:13 PM
  24. mcclain71's Avatar
    with alpha 5 mms fixed...does that apply to sms as well?
    08-15-2012 04:50 PM
  25. redrunner1985's Avatar
    alpha 5 seems to be running well. the only issue I can find is the WiFi doesn't want to turn on. is it possible that testkernal16 which I flashed is to blame?
    08-15-2012 05:19 PM
