09-01-2012 12:07 PM
788 ... 1617181920 ...
tools
  1. Zakman's Avatar
    alpha 5 seems to be running well. the only issue I can find is the WiFi doesn't want to turn on. is it possible that testkernal16 which I flashed is to blame?
    Yes, probably, also ive found that 3g goes in and out sometimes. I'm also currently working on that
    08-15-2012 04:30 PM
  2. Zakman's Avatar
    Kernel reuploaded
    08-15-2012 04:38 PM
  3. Master Gowa's Avatar
    Something worth looking into is the Playstore. I don't know how it decides if your device can run certian apps but that particular permission might be broken. Today I noticed something that I felt like pointing out here. I can download some apps that I used to use on ICS just fine (like Opera and Kik). While others that ran on ICS instead tell me "Your device isn't compatible with this version". Anyways I was looking to see if Viber worked again and it clearly says it has JB support in the version notes. Yet it's listed as incompatible. I didn't think anything of it yet until I looked at Illusia 2 (a game that I started playing while on ICS). I've got Illusia 2 on my phone still and it works. I must have installed it from a Titanium Backup because the Playstore lists Illusia 2 as incompatible. So I've got one app that the store says I shouldn't and there is one app that the developers say should work... makes me think it's just the Playstore that is somewhat broken. The Playstore works but I'm guessing not perfectly. The moral of this story is... double check your apps and backups. There might be more apps running on JB than the Playstore leads us to believe.
    08-15-2012 04:51 PM
  4. Zakman's Avatar
    Play store doesn't work because most devs haven't added jb support yet. If you haven't notices jb and ics look the same but there coding is completely different
    08-15-2012 05:08 PM
  5. anthonycr's Avatar
    All it requires to upgrade your app to jellybean is to change to target API in the manifest pretty much. Its quite simple, because they haven't removed any code just added code so there aren't any methods that need to be changed.
    08-15-2012 05:15 PM
  6. nitestalkr's Avatar
    Most apps are saying its not compatible due to official support is dropping for several ARMv6 devices. You can still use the app, just can't get it from the playstore anymore.
    And it has something to do with the device model, and android version combo.
    sent from my Zom-"Bean'(CM10 JellyBean).
    Master Gowa likes this.
    08-15-2012 05:26 PM
  7. Master Gowa's Avatar
    Thanks nitestalkr. That's what I was trying to say. Some of your old apps still work. Not all of them broke with the change to JB (even if the Playstore thinks so). I've noticed a few comments on various Android forums about the lack of JB apps. Well everyone doesn't have to be discouraged if they have backups from ICS.
    08-15-2012 05:48 PM
  8. Rudeco's Avatar
    Kernel reuploaded
    Kernel Link on OP still seems dead for me, anyone else had any luck?
    08-15-2012 07:11 PM
  9. JadenBrown30's Avatar
    I can just dirty flash Alpha5 right?
    08-15-2012 07:23 PM
  10. kobequintana's Avatar
    If you are already on this ROM yes from a different ROM like ICS no
    JadenBrown30 likes this.
    08-15-2012 07:30 PM
  11. anthonycr's Avatar
    Dirty flash from froyo
    08-15-2012 07:36 PM
  12. JadenBrown30's Avatar
    I've noticed that the "manage apps" and "storage" parts in the settings FC on alpha 5
    08-15-2012 08:05 PM
  13. nitestalkr's Avatar
    I pointed this out in alpha1/3.
    I'd say its a minor bug that doesn't need immediate attention.
    08-15-2012 08:39 PM
  14. kobequintana's Avatar
    Out of curiosity what would course that
    08-15-2012 08:44 PM
  15. nitestalkr's Avatar
    I'm assuming something in the framework.
    Not entirely sure.
    jonny5449 likes this.
    08-15-2012 08:47 PM
  16. JadenBrown30's Avatar
    It was just odd because it didn't FC on me in Alpha 1
    08-15-2012 08:50 PM
  17. JadenBrown30's Avatar
    When I go to download things from the Play Store it just hangs at downloading, any ideas?
    08-15-2012 08:51 PM
  18. nitestalkr's Avatar
    3G or Wifi.
    I'll see if i can recreate it.
    08-15-2012 08:54 PM
  19. JadenBrown30's Avatar
    3G or Wifi.
    3G
    08-15-2012 09:00 PM
  20. jonny5449's Avatar
    3G
    If you just flashed and syncing Google give it some time
    If after 20 minutes it still doesn't download reflash
    Sent from my LG-LS670 using Tapatalk 2
    08-15-2012 09:36 PM
  21. Zakman's Avatar
    Works for me.
    08-15-2012 10:39 PM
  22. Zakman's Avatar
    Not entirely sure.
    I was actually gonna replace the framework with one from a different p500 rom, that has everything working.
    nitestalkr likes this.
    08-15-2012 10:40 PM
  23. kobequintana's Avatar
    Is any one else having MMS issues I can't receive or send
    08-15-2012 10:52 PM
  24. andrewnelson23's Avatar
    Did you try the latest build?
    08-15-2012 11:25 PM
  25. kobequintana's Avatar
    Yes
    08-15-2012 11:29 PM
