09-01-2012 01:07 PM
788 ... 1718192021 ...
tools
  1. andrewnelson23's Avatar
    hmm, I don't know. i don't use this as daily. but if all he did was change out the apns-config.xml, you shouldn't have any problems. maybe try doing a full wipe before flashing it.
    08-16-2012 12:32 AM
  2. kobequintana's Avatar
    Km I'll report back
    08-16-2012 12:33 AM
  3. nitestalkr's Avatar
    3G
    On 3G, when pressing Accept and download, Google Play force closes, are you experiencing this?
    I'm experiencing it on wifi as well... this is a new bug to me, will try a fresh install of gapps and alpha5 and report back.
    sent from my Zom-"Bean'(CM10 JellyBean).
    08-16-2012 12:36 AM
  4. kobequintana's Avatar
    OK my MMS works now
    08-16-2012 01:30 AM
  5. JadenBrown30's Avatar
    Is any one else having MMS issues I can't receive or send
    Same
    08-16-2012 01:39 AM
  6. JadenBrown30's Avatar
    It doesn't FC it just stays at "starting download"
    08-16-2012 01:40 AM
  7. Zakman's Avatar
    Uploading New build to fix that problem(Manage Apps FC). The problem you are dealing with you have to go into manage apps, Play store and clear the data to fix it. Also Uploading a fast-charge Kernel if anyone wants to test it.
    JadenBrown30 likes this.
    08-16-2012 01:55 AM
  8. Zakman's Avatar
    Reuploaded cm-10-Alpha5.zip
    08-16-2012 02:33 AM
  9. nitestalkr's Avatar
    By fast-charge, are you referring to the higher voltage USB charge?
    08-16-2012 02:57 AM
  10. Zakman's Avatar
    yes sir, wanna test?
    08-16-2012 02:58 AM
  11. nitestalkr's Avatar
    Sure why not.
    08-16-2012 03:01 AM
  12. Zakman's Avatar
    Here's the link: Test15-Kernel-Fast-Charge.zip
    Sammyz compiled the Zimage but didn't test it, so have the regular test 15 kernel available as well, if this kernel messes up, you can always go back.
    nitestalkr likes this.
    08-16-2012 03:04 AM
  13. nitestalkr's Avatar
    I'll test it with alpha5 and let you know how it goes.
    08-16-2012 03:08 AM
  14. nitestalkr's Avatar
    Well it booted and is running.
    Going to test the fast charge tomorrow.
    For some rreason, the Play store is still force closing after I tap "Accept & Download". I did a complete fresh install, so I'm stumped. Even tried wiping its data and cache from manage apps, still persists.
    EDIT:
    When you lock the phone(with the fast charge kernel) it gets stuck on a black screen when you 'wake' the phone. The backlight comes on, but its just a black screen.
    I still think that you should use tdm's kernel, it would fix the Bluetooth issue(reboots when turned off), and possibly others(as he progresses with his kernel)
    08-16-2012 03:31 AM
  15. reaper420's Avatar
    I downloaded a play store modified to remove device restrictions if anyone wants it I'll upload it
    08-16-2012 03:44 AM
  16. ThatGuyLurkin's Avatar
    What weather widget are you using in Screenie?
    08-16-2012 04:26 AM
  17. nitestalkr's Avatar
    Do not hesitate to upload it
    08-16-2012 04:27 AM
  18. Rudeco's Avatar
    I still can't download the reg test 15 kernel from the op.
    08-16-2012 05:24 AM
  19. nitestalkr's Avatar
    For some reason, Google Play just stopped the force closing I was running into.
    I did nothing special, I just kept trying to download, and suddenly it worked.... that was probably the strangest occurrence I've experienced... it basically just fixed itself.
    Skynet O_O
    08-16-2012 06:49 AM
  20. reaper420's Avatar
    Here is the play store with device restrictions removed, just rename the apk to Phonesky.apk and replace the one in system apps,reboot and enjoy
    https://www.box.com/shared/a06006eb59e368d4dacb
    Sent from my Jelly beaned optimus V
    nitestalkr and Master Gowa like this.
    08-16-2012 06:55 AM
  21. nitestalkr's Avatar
    I'll be sure to check it out when I wake up! Thanks!
    08-16-2012 07:36 AM
  22. anthonycr's Avatar
    You're sleeping?? Its 8 AM where I live... I'm already at work.
    08-16-2012 08:16 AM
  23. nitestalkr's Avatar
    You're only 3 hours ahead of me.
    My sleep is all out of whack, due to random insomnia lol.
    Sad thing is, I gotta be up in 2 hours, have a tight schedule ahead of me. Time for a power nap!
    08-16-2012 08:39 AM
  24. anthonycr's Avatar
    Kids these days...
    08-16-2012 09:03 AM
  25. mcclain71's Avatar
    flashed latest alpha 5. fc on theme provider. market store works. sms works both ways. mms sends but hangs on downloading on receiving part sometimes
    did anyone look into the wp7 notifications bug? lol
    08-16-2012 10:00 AM
