09-01-2012 01:07 PM
788 1234 ...
tools
  1. andrewnelson23's Avatar
    Actually it is very cm-ish.Only thing I've seen not implemented is themes.
    I did not get the gapps installer, but I was able to sign in to my gmail account just fine when I opened the play store.
    08-06-2012 10:12 AM
  2. poweredge99's Avatar
    I was having problems signing in to my Google account after first time setup, and I think I noticed "Google search has unfortunately stopped" popping up each time I tried to type, so I went and disabled voice typing and keyboard now works.
    Also flashed jellybean super fix, and seems to be working well. sd-ext works as well too.
    I had to follow this route also.. Awesome work.. Thank you.
    Sent from my VM670 using Tapatalk to here.
    08-06-2012 10:23 AM
  3. andrewnelson23's Avatar
    could you put up the md5 sum of both the rom and gapps? I did it again and again, never got the setup at the beginning, and again, home button doesn't work..
    08-06-2012 11:12 AM
  4. Zakman's Avatar
    Did u format system?
    08-06-2012 12:21 PM
  5. andrewnelson23's Avatar
    yes. I think the problem was that I was on zvd radio. I moved to zv5 and got the setup. home button works for me now. I also have lockscreen. WOW, so many things depended on the radio....that's strange.
    08-06-2012 12:29 PM
  6. YoshinJaa's Avatar
    I came across a few issues, nothing minor, but wanted to let you know Zakman:
    - color banding was not patched via super fix
    - keyboard does not display the punctuation bar at the top of the keyboard, only within the keys
    the keyboard issue may be related to it being installed on the sd-ext partition, but most likely not. Very good and stable rom for being in alpha, nice work.
    08-06-2012 12:40 PM
  7. andrewnelson23's Avatar
    So I went into google now, and got the expected force close. after that I rebooted and found a weather card in my status bar
    08-06-2012 12:46 PM
  8. StingDrop's Avatar
    Cant seem to download cm10
    Sent from my LG-VM670 using Xparent ICS Tapatalk 2
    08-06-2012 12:57 PM
  9. Zakman's Avatar
    I'm not getting color banding. Are you on an optimus v?
    08-06-2012 01:21 PM
  10. YoshinJaa's Avatar
    Yep its noticeable in settings, idk I flashed super fix after first boot because of sd-ext.
    Sent from my Quattrimus ICS Optimus V
    08-06-2012 01:30 PM
  11. ThatGuyLurkin's Avatar
    eALPHA. Lol.
    08-06-2012 03:42 PM
  12. poweredge99's Avatar
    Thought this was cool. Didn't notice the Google at first.
    08-06-2012 04:42 PM
  13. andrewnelson23's Avatar
    But Chrome doesn't work on armv 6?
    StumDroid likes this.
    08-06-2012 05:47 PM
  14. poweredge99's Avatar
    I just meant the "G" in landscape mode. My chrome works.... Not sure how or why it does...
    Maybe it's a knock off... But I use it.
    08-06-2012 06:00 PM
  15. ThatGuyLurkin's Avatar
    Its not chrome. xD
    Its most likely that Miren Browser.
    08-06-2012 06:19 PM
  16. andrewnelson23's Avatar
    Ohhhh. hahaha. I was like. : |____|
    what are the various bugs that people have reported? I thought that overall, it was fantastic!!!
    The only two things that stop it from being a daily rom for me is the lack of camera, and how many big apps still aren't available on the play store yet. I possibly fix mms.
    08-06-2012 06:23 PM
  17. YoshinJaa's Avatar
    The only issue I have with it besides what I mentioned earlier is battery drain. Maybe I was unlucky, but I unplugged for 30 minutes and it went to 91%. Albeit I was tinkering with it quite a bit too.
    How are you guys battery holding up?
    08-06-2012 06:28 PM
  18. andrewnelson23's Avatar
    Mine was probably about the same. (I was also messing around with it quite a bit). But actually, I thought it seemed really good for how early the development for this is!
    08-06-2012 06:31 PM
  19. YoshinJaa's Avatar
    Definitely. Its practically good enough for daily use. Hopefully tdm ICS kernel comes out soon, with that this can be really great.
    08-06-2012 06:41 PM
  20. andrewnelson23's Avatar
    +1 that's exactly what I've been thinking since this came out. Like I said earlier, I would use this as a daily rom if it had the camera. (I don't even mind so much about the apps since they can be restored from TB). Anybody know how to fix camera??
    08-06-2012 06:46 PM
  21. JadenBrown30's Avatar
    So far I love it and I love the fact that it has the default live wallpapers. The only bug that I've noticed other than the ones you've mentioned is the launcher, the icons are a bit out of place
    andrewnelson23 and tvall like this.
    08-06-2012 07:18 PM
  22. bigsupersquid's Avatar
    Flashing baseband changes more than just the radio.
    That's why the home/menu keys get reversed with Sprint basebands, among other changes like the size of the /system partition.
    08-06-2012 08:26 PM
  23. JadenBrown30's Avatar
    I've also noticed that the data doesn't toggle on and off very well when using the power toggles in the notification tray
    08-06-2012 09:03 PM
  24. StumDroid's Avatar
    Am I the only one who can't install Gapps? I can use the one used in CM10 for Optimus S but this one won't work!
    08-06-2012 09:39 PM
  25. nitestalkr's Avatar
    Try using a different JB gapps zip?
    sent from my Zom-"Bean"(AOSP JellyBean).
    08-06-2012 09:40 PM
788 1234 ...
