09-01-2012 12:07 PM
788 ... 1819202122 ...
tools
  1. nitestalkr's Avatar
    Kids these days...
    We're the same age, remember?(give or take a few months)
    I'm able to function on minimum sleep, due to my sleeping patterns being the way they are, since I was 2, or 3. Its not full blown insomnia, because there will be some nights where I'd get 8+ hrs of sleep. As I said, random. Its odd, but I've learnt to live with it.
    flashed latest alpha 5. fc on theme provider. market store works. sms works both ways. mms sends but hangs on downloading on receiving part sometimes
    did anyone look into the wp7 notifications bug? lol
    Wp7 notification?
    Last I checked, this had android notifications.
    If you have questions pertaining to a certain app, please either start a new thread, or search for an existing one.
    sent from my Zom-"Bean'(CM10 JellyBean).
    08-16-2012 10:07 AM
  2. mcclain71's Avatar
    Wp7 notification?
    wp7 notifications basically give u a popup on the banner for things like email, sms etc...it allows to to still use the phone w/o answering the msg the banner can be colored to anything u want...but in this JB port, the colors dont show (at least on the testing screen...but they work)
    i know ICS has the optioin to remove the google search bar. does JB?
    edit...
    08-16-2012 11:22 AM
  3. anthonycr's Avatar
    I know we're the same age, I was just being sarcastic
    I function on around 7 hours and even then I fall asleep on the couch when I get home from work... I love sleeping
    sellers86 and nitestalkr like this.
    08-16-2012 11:24 AM
  4. sellers86's Avatar
    yeah I do too. sucks I have to go back to school tomorrow
    08-16-2012 11:27 AM
  5. anthonycr's Avatar
    That is a launcher option that CyanogenMod implemented, so they most likely will implement that setting in CMX, it's just a matter of time.
    08-16-2012 11:46 AM
  6. ThatGuyLurkin's Avatar
    You're only 3 hours ahead of me.
    My sleep is all out of whack, due to random insomnia lol.
    Sad thing is, I gotta be up in 2 hours, have a tight schedule ahead of me. Time for a power nap!
    With that said, I need to be prepared for the Adult life. I usually sleep from 6AM - 2PM. Sleeping disorder
    08-16-2012 01:30 PM
  7. Zakman's Avatar
    Here is the play store with device restrictions removed, just rename the apk to Phonesky.apk and replace the one in system apps,reboot and enjoy
    https://www.box.com/shared/a06006eb59e368d4dacb
    Sent from my Jelly beaned optimus V
    Hmmmm should I put this in the rom???
    08-16-2012 01:31 PM
  8. ThatGuyLurkin's Avatar
    What weather widget are you using in Screenie?
    08-16-2012 01:31 PM
  9. YoshinJaa's Avatar
    Yes
    Sent from my Optimus V via Tapatalk
    08-16-2012 02:00 PM
  10. anthonycr's Avatar
    12 AM - 6 AM here. I actually have things to do during daylight hours
    08-16-2012 03:17 PM
  11. Zakman's Avatar
    New playsotre is in the new gapps link
    Master Gowa and nitestalkr like this.
    08-16-2012 03:29 PM
  12. kobequintana's Avatar
    For the voice search to be fixed can we port the one from ICS
    08-16-2012 04:32 PM
  13. anthonycr's Avatar
    I've never gotten the ICS voice search to work... I've always had to install it from the play store instead. Am I missing something?
    08-16-2012 04:48 PM
  14. kobequintana's Avatar
    Oh yeah ha lol I forgot it didn't work woops
    08-16-2012 04:53 PM
  15. cammykool's Avatar
    I used the play store apk on my nexus because it hadn't updated lol who is using this ROM as a daily?
    08-16-2012 05:14 PM
  16. Zakman's Avatar
    I was but i went back to gb for netflix
    08-16-2012 05:39 PM
  17. reaper420's Avatar
    I've been using it daily and love it, I just can't wait for the theme chooser
    08-16-2012 05:51 PM
  18. cammykool's Avatar
    Has anyone tried the gnow for ics project? The apk in there works on ics
    08-16-2012 06:00 PM
  19. jonny5449's Avatar
    Does not work on jb
    Sent from my LG-LS670 using Tapatalk 2
    08-16-2012 06:03 PM
  20. cammykool's Avatar
    Tgl might lose my business from his rom
    ThatGuyLurkin likes this.
    08-16-2012 06:09 PM
  21. ShadowEO's Avatar
    Does not work on jb
    It does work but it's quirky.
    I'll upload a screen of it running on my device soon. I installed a lot of Google now packages before it started working so I'm not sure what I did honestly.
    Sent from my LG-LS670 using Android Central Forums
    08-16-2012 06:56 PM
  22. cammykool's Avatar
    With voice or?
    08-16-2012 07:26 PM
  23. ShadowEO's Avatar
    With voice or?
    Without. It also does not scroll.
    08-16-2012 10:31 PM
  24. lattimorej1986's Avatar
    This rom just absolutely refuses to boot for me the second time around. 1st boot after flashing goes fine, but then when I reboot, it hangs on SID (the boot animation). I've let it sit for atleast 20 minutes, with nothing. Does anyone know a cause/solution for this? It makes no sense to me.
    I can literally boot up the 1st time after flashing, and reboot right away (before signing into Google or anything) and then it hangs.
    (confused)
    Thanks in advanced.
    08-17-2012 12:13 AM
  25. Zakman's Avatar
    (confused)
    Thanks in advanced.
    Whitch alpha?
    08-17-2012 12:15 AM
