09-01-2012 01:07 PM
788 ... 1920212223 ...
tools
  1. lattimorej1986's Avatar
    Both alpha 4 and 5.
    08-17-2012 01:18 AM
  2. kobequintana's Avatar
    Both alpha 4 and 5.
    Did you do a clean you flash or dirty flash
    08-17-2012 01:25 AM
  3. lattimorej1986's Avatar
    Clean, always.
    08-17-2012 01:34 AM
  4. andrewnelson23's Avatar
    It could be your phone's processor problem. Or it could be the kernel. Try switching the kernel. If that doesn't work, it might not. It could be that this rom on your phone on this rom is just too unstable at the default oc settings, and you can't change the defaults unless you're booted...
    lattimorej1986 likes this.
    08-17-2012 02:08 AM
  5. lattimorej1986's Avatar
    Ok. I do flash test kernel 15 after gapps, so will try without flashing kravens kernel. If that doesn't work, I can change the default clock speeds on my first boot (its the second boot that's giving me problems) , so we will see if either of those help. I will report back. Thanks guys, and please feel free to come forward with any other ideas as to what the problem could be.
    It's just odd it boots the first time, but not the second. I've never encountered this problem.
    08-17-2012 02:16 AM
  6. samson lamadine's Avatar
    Roaming indicator off..how u put it on?
    08-17-2012 03:07 AM
  7. kobequintana's Avatar
    If that doesn't work try downloading every thing again than flash
    08-17-2012 03:08 AM
  8. ThatGuyLurkin's Avatar
    Overlooked.....
    What Weather widget are you using in the Screenies?
    andrewnelson23 likes this.
    08-17-2012 03:43 AM
  9. lattimorej1986's Avatar
    Tried all three of these, with no luck. Can still boot the first time, after installation, but a reboot after that just hangs at the boot animation. Any more suggestions guys? This is bizarre, and i would really like to figure it out. I will do some more Google'ing, but if you have any ideas, please share!
    08-17-2012 03:57 AM
  10. clodfelterac's Avatar
    buy a new sdcard... or try reformatting the one you have... (copy sd to pc)(copy back after formatting)... ?
    08-17-2012 04:48 AM
  11. lattimorej1986's Avatar
    The sd card that I have is relatively new, a class 10 16 gig. But I will try to reformat once I get home (3 hrs) and post back with the results of that as well. Thanks for all the suggestions so far guys! Someone has to know what's going on here...
    08-17-2012 04:53 AM
  12. andrewnelson23's Avatar
    Overlooked.....
    I think it might be one of the p500 screenshots. :P I'd like to know as well though!!
    ThatGuyLurkin likes this.
    08-17-2012 09:49 AM
  13. lattimorej1986's Avatar
    Ok guys, for some reason reformatting and repartioning my sd card allowed me to boot the second time. Can anyone shed any insight as to why this made a difference? After all, I replaced all the files back onto the sd card that were there before the format. This one has me scratching my head in confusion. At any rate, it worked, and thats all that really matters.
    Thanks guys.
    08-17-2012 10:29 AM
  14. ShadowEO's Avatar
    Thanks guys.
    Probably filesystem errors. You don't need to format. A simple chkdsk on the card would've sufficed.
    Sent from my LG-LS670 using Android Central Forums
    08-17-2012 11:27 AM
  15. lattimorej1986's Avatar
    Thanks, I'll keep that in mind in case I (or someone else else) runs into that problem in the future.
    Sent From My JeLLyBeaN'd / MiRaGe'D Optimus V
    08-17-2012 12:34 PM
  16. androidCHEECH's Avatar
    I'm bout to try this ive been using cm9 Bobz rom for a good month now waiting on a steady jelly bean from from what I'm seeing its steady enough for me , great job on the steady updates
    08-17-2012 01:46 PM
  17. ThatGuyLurkin's Avatar
    http://desmond.imageshack.us/Himg259...ng&res=landing
    I'm gonna search for it..... it looks like the Yahoo Weather on lockscreen.
    08-17-2012 03:18 PM
  18. kenharkey7's Avatar
    Great work with the rom so far. Everything I need is working, and haven't had any problems with this. Using the test kernel really helped a lot too. Can't wait to see how this one goes.
    08-17-2012 03:40 PM
  19. 10069618's Avatar
    Everything runs very smoothly so far
    The only problem I have is that when I dial a number there doesn't seem to be any dialing tone when it's connecting to a call. I know that it's connected since I dialed my house phone and it rang, but is there any option to turn the dialing tone back on?
    Edit: Fixed it by flashing the kernel.
    08-17-2012 03:49 PM
  20. cole2kb's Avatar
    I saw a couple of posts about this, but no real resolution. You guys using the test kernel, do you have working Wi-Fi? I flashed it, and it borked Wi-Fi, so I wiped and re-flashed without it and it seems to be working just fine, but would like to use what's recommended.
    08-17-2012 04:27 PM
  21. kenharkey7's Avatar
    Im at the library right now, using alpha 5 with the test kernel and i've been on the wifi for the past 2 hours almost with zero issues.
    Edit: I think I found the weather widget you guys wanted Weather Eye
    08-17-2012 04:29 PM
  22. cole2kb's Avatar
    Weird. I'll give it another shot then. Thanks.
    08-17-2012 04:33 PM
  23. kenharkey7's Avatar
    It probably doesn't make a difference but i didn't flash the test kernel right away, i flashed the rom after a full wipe, booted into it then rebooted and flashed the test kernel
    08-17-2012 04:34 PM
  24. r0gu3dev1pr's Avatar
    I believe the weather widget you are talking about is already part of the rom. Its a lockscreen widget.. Go to Settings-> Lock screen -> Weather then check the box next to Display weather. It uses Yahoo! Weather.
    08-17-2012 04:38 PM
  25. kobequintana's Avatar
    But they want the status bar weather
    08-17-2012 04:42 PM
