09-01-2012 12:07 PM
788 ... 2021222324 ...
tools
  1. kenharkey7's Avatar
    Weather Eye came up in a reverse image search, either way its a pretty cool little app
    08-17-2012 03:43 PM
  2. ThatGuyLurkin's Avatar
    I'm gonna download, if it is it, I can't believe how stupid I am.
    I used this app for thr month of July.
    No go, and I believe it's not Status bar weather. Its behind it, a widget.
    08-17-2012 03:49 PM
  3. androidCHEECH's Avatar
    I tried to flash with the test kernal but it wouldn't boot, so I did another full wipe and flashed without the kernal and it worked just fine but when i was using wifi my data was constantly in use and when I got a call I tried to use my headphones but the phone didn't recognize them and the speaker didnt work and the sound was mad low I don't know if that's a known issue but as for those issues everything else seemed to be workin
    08-17-2012 03:50 PM
  4. kobequintana's Avatar
    Try to re-download every thing than re-flash
    08-17-2012 03:57 PM
  5. androidCHEECH's Avatar
    I'm bouta give it another go
    08-17-2012 04:00 PM
  6. irish-68's Avatar
    But they want the status bar weather
    Beautiful Widgets has an option for displaying current outside temp in the status bar, and current conditions in the pull down notifications.
    08-17-2012 06:49 PM
  7. ThatGuyLurkin's Avatar
    Yes, but its NOT in the status bar. Its behind it.
    08-17-2012 07:09 PM
  8. JadenBrown30's Avatar
    Click to view quoted image
    What launcher is that????
    08-17-2012 08:26 PM
  9. ThatGuyLurkin's Avatar
    Xperia S slightly modded. No share button, faster paging, themes stick.
    08-17-2012 08:58 PM
  10. Zakman's Avatar
    Weather in screenshots is a screenshot of the Lock screen. It's weather enabled in the lock screen.
    08-17-2012 10:24 PM
  11. Zakman's Avatar
    Currently working on RIL files, Signal doesnt seem very stable.
    jonny5449 and nitestalkr like this.
    08-17-2012 10:38 PM
  12. kobequintana's Avatar
    Every time I reboot my phone it says optimizing X of X after the boot animation is that a bug or what
    08-17-2012 10:46 PM
  13. lattimorej1986's Avatar
    That would be a known issue
    Zakman likes this.
    08-17-2012 11:01 PM
  14. JadenBrown30's Avatar
    Where'd you get it???
    08-17-2012 11:14 PM
  15. ThatGuyLurkin's Avatar
    Why is it so low? Is some XML files modded?
    I ripped it from a rom I found. I'll upload and PM you
    08-17-2012 11:28 PM
  16. mcclain71's Avatar
    can i get in on this too? lol
    08-17-2012 11:35 PM
  17. ThatGuyLurkin's Avatar
    Get into what?
    08-17-2012 11:41 PM
  18. Zakman's Avatar
    it's not low lol I took a screenshot and the screenshot was still in the notification tray xD
    08-17-2012 11:45 PM
  19. Zakman's Avatar
    Just looked as Maclaw's CM10 and his vold file is different then everyone elses, trying now..
    08-17-2012 11:54 PM
  20. Rayz321's Avatar
    I'm not sure if this is a bug but when you first install it and you're at the welcome screen it says "mother" for the button that open the emergency dialer.
    08-18-2012 12:48 AM
  21. ThatGuyLurkin's Avatar
    That's a Gapps problem.
    Rayz321 likes this.
    08-18-2012 12:54 AM
  22. Rayz321's Avatar
    okay thanks
    I think you probably know about this already but there seems to be a problem with app spacing as seen in my screenshot below
    edit: also when you hold the lock button to get to the phone options it opens then closes then opens again.
    edit: I know this is a gapps thing but it's weird how I'll get weather notifications in my notification bar from google now but if I try to click it I get a force close thing.
    edit again: If you go in setting and try to open the storage part it just says "settings has stopped"
    edit: I'm not sure if this is a bug but in the setting > About Phone > status it shows the serial number as "unknown"
    edit: The Slider shortcuts setting seems to be a little messed up.
    edit: I can't seem to get "Owner info" to show up on the lock screen.
    edit: If you have mobile data off, wifi on(and connect), and you try to go into airplane mode it turns 3g on.
    08-18-2012 01:27 AM
  23. kenharkey7's Avatar
    @tgl,would you be so kind as to shoot me an launcher as, well? Much appreciated
    Oh another thing I noticed, I always check kill apps via long press in the development settings but holding back actually does not kill the app like it's supposed to.
    08-18-2012 02:43 AM
  24. ThatGuyLurkin's Avatar
    Here's thr launcher I use. Sorry for posting her, can't remember everyone's names to PM
    http://db.tt/t11Tdg3a
    @Zak, how much space does Google Now take?
    08-18-2012 03:23 AM
  25. kenharkey7's Avatar
    I appreciate it
    08-18-2012 03:26 AM
