09-01-2012 12:07 PM
788 ... 2122232425 ...
tools
  1. nitestalkr's Avatar
    @tgl,would you be so kind as to shoot me an launcher as, well? Much appreciated
    Oh another thing I noticed, I always check kill apps via long press in the development settings but holding back actually does not kill the app like it's supposed to.
    The kill action is VERY delayed, so just hold it for 5-10 seconds instead of the usual -2 seconds in other ROMs.
    @Zack, I say you should use the launcher that TGL provided as default, since some people are taking a liking to it.
    sent from my Zom-"Bean'(CM10 JellyBean).
    08-18-2012 07:04 AM
  2. lattimorej1986's Avatar
    Agreed. I downloaded it and have been playing with it for a few hours now, and i have to say it's very smooth, and one of the better launchers I've installed. If you don't want to include it in the rom, then maybe a flashable zip that would replace the default launcher with this one.
    Just a thought.
    Sent From My MiRaGe'D / JeLLyBeaN'd Optimus V
    08-18-2012 07:46 AM
  3. inceyet's Avatar
    Here's thr launcher I use. Sorry for posting her, can't remember everyone's names to PM
    http://db.tt/t11Tdg3a
    @Zak, how much space does Google Now take?
    Is this launcher only for jb
    08-18-2012 07:47 AM
  4. adamhos's Avatar
    Beautiful Widgets has an option for displaying current outside temp in the status bar, and current conditions in the pull down notifications.
    I'm not running this rom right now but palmary weather gives you the status bar weather
    Running xperia launcher
    08-18-2012 07:47 AM
  5. ShadowEO's Avatar
    depends, without the srec folder it's rather small. With it, ~58MB.
    Sent from my LG-LS670 using Android Central Forums
    08-18-2012 08:03 AM
  6. adamhos's Avatar
    Any word on a cam fix?
    I love this rom btw!
    08-18-2012 08:29 AM
  7. mcclain71's Avatar
    thanks for the xperia launcher its frickin' awesome
    08-18-2012 08:45 AM
  8. mcclain71's Avatar
    how did you get your status bar weather to show up so big? lol. im using weatherbug elite, and my status bar icon is small :/
    08-18-2012 08:53 AM
  9. bxray's Avatar
    Just wanted to say thank you for making this Rom..I downloaded da rom and it works perfect..it got a couple of bugs but you did a great job!
    08-18-2012 10:08 AM
  10. ThatGuyLurkin's Avatar
    What's the Srec folder?
    Doesnt google have like, an Offline function?
    08-18-2012 12:51 PM
  11. ShadowEO's Avatar
    The /usr/srec folder contains the files for the offline recognition. However, we can't use them as the updated libvoicesearch files that use these files for Google Now are ARMv7 only.
    08-18-2012 03:38 PM
  12. ZackVortex's Avatar
    What if we get the files that make voice search work from ICS and port them here
    I am not new I created a new account for a reason
    08-18-2012 04:53 PM
  13. ShadowEO's Avatar
    They would work in their present form, but we don't have a working microphone yet. We still would not have offline recognition as those require the ARMv7 jelly bean voice search libraries (of which are Google proprietary software, meaning that we don't have the source needed to build ARMv6 versions of them)
    ZackVortex likes this.
    08-18-2012 05:03 PM
  14. mcclain71's Avatar
    any one experiencing an abnormal amount of battery drain?
    plantucha likes this.
    08-18-2012 05:37 PM
  15. ShadowEO's Avatar
    I am in the optimus S version and having a huge amount of drain. I'm using SetCPU to compensate through profiles though.
    08-18-2012 05:41 PM
  16. 10069618's Avatar
    Yea I've been having this problem as well, went from 100% to 67% in an hour after I unplugged it.
    Does anyone else have the problem with the speaker not being loud enough with making calls?
    Is there any easy fix for this? I also can't get the loud speaker to work.
    08-18-2012 05:46 PM
  17. willmon22's Avatar
    I decided to try this out and see how well it worked. Seems to work fine the mms works to it seems I send a message to myself and it responded with the message I sent. Only thing I see wrong right now is there seems to be some graphical issues with it seeming to jerk a little when it is doing the animation of some things. Also I have tried the latest gooinsideme gapps and it would seem they work fine I am able to get all apps to show up in the google play store. And a better alternative for using the web for a computer I think is the easy tether. It may not be a hotspot but it seems to be stable and works fine. It would be nice if the built in hotspot would work eventually on the ics and jelly bean roms.
    08-19-2012 01:33 AM
  18. morimar's Avatar
    Thanks for this rom - its great! I know its still an alpha, but it seems stable enough to use it as a daily driver
    I've seen a huge difference in my battery drain by turning WiFi off - more than I can recall with other roms [Alpha6 w/o test15 kernel - SavageZen 245/600]
    08-19-2012 02:08 AM
  19. Zakman's Avatar
    08-19-2012 02:14 AM
  20. kenharkey7's Avatar
    Do I smell an alpha 7? Lol
    nitestalkr and jonny5449 like this.
    08-19-2012 02:30 AM
  21. nitestalkr's Avatar
    One bug that I have noticed:
    Sometimes, when receiving/making a call, the speaker just doesnt work.
    And its usually sometime after I play a game(and then close it), but also occurs just randomly. And it persists until I reboot(which takes a while still).
    I still use this my DD despite the quirks.
    08-19-2012 03:51 AM
  22. mcclain71's Avatar
    i get that initial screen too, and it cycles through all of the features. but when its done, you get the FC's everytime u access google search
    08-19-2012 09:21 AM
  23. jonny5449's Avatar
    As soon its released will update my rom how did u do it
    Sent from my LS670 using Tapatalk 2
    08-19-2012 09:27 AM
  24. Zakman's Avatar
    Its the armv6 one for ics. Ima make a flashable zip with everything you need
    08-19-2012 11:24 AM
  25. jonny5449's Avatar
    Thank you also does the voice search work?
    08-19-2012 03:36 PM
