09-01-2012 01:07 PM
788 ... 2223242526 ...
tools
  1. Zakman's Avatar
    Thank you also does the voice search work?
    No we gotta use a work around with gb voice search
    08-19-2012 04:55 PM
  2. StumDroid's Avatar
    Am I the only one who cant hear anyone when i make a call?
    08-19-2012 05:14 PM
  3. jonny5449's Avatar
    Would that one work if we pulled the voice search apk from a data folder then delete voice search from jb gapps then install voice search apk?
    08-19-2012 05:39 PM
  4. williek113's Avatar
    ok so am i the only one who has a messed up launcher???
    08-19-2012 07:13 PM
  5. jonny5449's Avatar
    Nope
    08-19-2012 07:31 PM
  6. Zakman's Avatar
    Nope
    That'll be fixed in the next release tonight!
    08-19-2012 07:38 PM
  7. jonny5449's Avatar
    Cool gnow and fixed launcher will sync tomorrow for sure
    08-19-2012 08:53 PM
  8. Zakman's Avatar
    Also some rild changes and also tonight ima learn how to build from source
    08-19-2012 09:07 PM
  9. jonny5449's Avatar
    Will be easier to get it working I can't build from source because I'm on a 90 gb windows 7 starter netbook and uploading source just plain confuses me
    Sent from my LG-LS670 using Tapatalk 2
    08-19-2012 10:16 PM
  10. YoshinJaa's Avatar
    Best of luck to building from source. I wish I knew how to too
    sellers86 likes this.
    08-19-2012 10:23 PM
  11. anthonycr's Avatar
    You're probably in for a nasty surprise... AFAIK Bobzhome is the only person in the community that has gotten JB booting at all. Some of the other devs (and semi-devs) have tried and failed.
    08-19-2012 10:26 PM
  12. sellers86's Avatar
    I couldn't get it compiled, though my fixes for the errors probably broke everything else. I may try again sometime, but right now I'm busy with two secret projects (both compile, one boots but is very glitchy, the other doesn't boot).
    08-19-2012 11:52 PM
  13. StumDroid's Avatar
    Ummm I guess I'll ask again lol. My speaker phone broke while on Alpha ICS, and I can't hear any calls while on jelly bean, is that normal? Cause I don't see anything about this in the not working section, this is the only rom I use that does this. I'd love to be able to hear my calls lol
    Also I bring up that my speaker phone broke cause I can't use that as an alternative
    08-20-2012 12:43 AM
  14. Zakman's Avatar
    Alpha 7 almost finished Gonna be a big one.
    08-20-2012 01:14 AM
  15. KidFr3sH's Avatar
    Awesome Man
    08-20-2012 01:32 AM
  16. Zakman's Avatar
    Alpha 7 Finished but with a bug. Bug: Home key and Menu Key switched.
    08-20-2012 02:19 AM
  17. ZackVortex's Avatar
    Awesome for alpha 7
    Aaawww for the bouttons but I can deal with it lolz
    08-20-2012 02:21 AM
  18. StumDroid's Avatar
    That's awesome!! I can deal with the button switch. Can't wait to flash
    08-20-2012 02:22 AM
  19. Zakman's Avatar
    Alpha 7 UP!
    r0gu3dev1pr and StumDroid like this.
    08-20-2012 02:39 AM
  20. kenharkey7's Avatar
    I knew I smelled alpha 7, good work I will download and flash tomorrow at the library they have fast wifi. One dumb question though whats ril?
    Zakman likes this.
    08-20-2012 02:42 AM
  21. Zakman's Avatar
    Radio Interface Layer, It controls our signal and data quality.
    kenharkey7 likes this.
    08-20-2012 02:46 AM
  22. nitestalkr's Avatar
    I posted earlier about the same issue, usually a reboot fixes it. Just reboot when it occurs(kinda sucks though).
    Gonna flash alpha 7 now.
    sent from my Zom-"Bean'(CM10 JellyBean).
    StumDroid likes this.
    08-20-2012 02:46 AM
  23. kenharkey7's Avatar
    Thank you ^_^ any luck fixing the updating x out of x apps thing?
    08-20-2012 02:49 AM
  24. Zakman's Avatar
    No, I think is an jb dalvik cache issue
    ZackVortex likes this.
    08-20-2012 03:09 AM
  25. nitestalkr's Avatar
    It is.
    I think its getting wiped after every reboot.
    08-20-2012 03:39 AM
