09-01-2012 12:07 PM
788 ... 2324252627 ...
tools
  1. ZackVortex's Avatar
    I think the kernel caused the button swap
    I flashed the test 15 kernel and they where the way it's supposed to be without the kernel they are swapped
    08-20-2012 03:43 AM
  2. nitestalkr's Avatar
    It is the new kernel.
    sent from my Zom-"Bean'(CM10 JellyBean).
    08-20-2012 04:08 AM
  3. StumDroid's Avatar
    Alpha 7 is amazing!! Great work, am now using this as my daily
    08-20-2012 04:15 AM
  4. jonny5449's Avatar
    Will be fixing my build later
    Sent from my LG-LS670 using Tapatalk 2
    08-20-2012 07:21 AM
  5. sdxben's Avatar
    Running Alpha6 since last night- I cant get the Bluetooth to work- It will connect to a couple different devices, but when I play my podcasts the sound still comes out of my phone speaker and Not my Bluetooth device. Do I have a bad flash or is this a common problem- I have searched the thread and seen no mention of this.
    08-20-2012 10:25 AM
  6. androidCHEECH's Avatar
    So I've been running alpha 7 since 6 this morning and I love the ROM. Besides the camera, home key, Google now issues everything else is workin within means and I can work my basic apps and call and text then I'm good, great improvement on alpha 7 yo
    08-20-2012 11:24 AM
  7. Zakman's Avatar
    Anyway that can be fixed easily?
    08-20-2012 11:52 AM
  8. ZackVortex's Avatar
    Changing serten files (I don't know witch 1) could possibly fix it
    08-20-2012 12:42 PM
  9. Zakman's Avatar
    If I find the right input.so file...
    08-20-2012 01:43 PM
  10. drm1992's Avatar
    Any luck on the camera?
    08-20-2012 03:12 PM
  11. ShadowEO's Avatar
    Camera is less important than getting the system to work properly. Be patient.
    Sent from my LG-LS670 using Android Central Forums
    08-20-2012 03:52 PM
  12. drm1992's Avatar
    Not being impatient. Didn't mean to come off like that. Just curious...
    08-20-2012 05:33 PM
  13. mcclain71's Avatar
    can anyone confirm alpha 7 mms is broken again? also, wifi cant connect anymore
    home key issue fixed with flashing of test kernal btw
    08-20-2012 05:45 PM
  14. StumDroid's Avatar
    I don't really use MMS so can't confirm that but WiFi is fine in Alpha 7
    08-20-2012 05:48 PM
  15. androidCHEECH's Avatar
    My MMS works
    08-20-2012 06:17 PM
  16. mcclain71's Avatar
    weird...i did a complete reflash. wifi works and mms works. now :/
    08-20-2012 06:26 PM
  17. terthii's Avatar
    Does this have that wonderful clock lag issue?
    08-20-2012 07:23 PM
  18. Zakman's Avatar
    Nope
    08-20-2012 08:18 PM
  19. StumDroid's Avatar
    Nah it's not weird at all! Just a bad flash
    08-20-2012 09:22 PM
  20. mcclain71's Avatar
    thats what i thought too...however mms was only going through on wifi
    just flashed again. used harmonias prep for a new rom zip. ran it 3 times
    edit... apparently that worked mms comes through on 3g now
    08-20-2012 09:25 PM
  21. Katnuk's Avatar
    I seem to have fixed the switched home and menu key problem, by going to /system/usr/keylayout/thunderc-keypad.kl and changing a few keys (139 and 102) around.
    key 139 HOME WAKE_DROPPED
    and
    key 102 MENU WAKE
    Simply switch the HOME and MENU text around:
    key 139 MENU WAKE_DROPPED
    and
    key 102 HOME WAKE
    Then save the file, and reboot. Works so far for me.
    08-20-2012 10:35 PM
  22. Zakman's Avatar
    and
    key 102 MENU WAKE
    and
    key 102 HOME WAKE
    Encorperating into new rom and reuploading as we speak.
    08-21-2012 12:05 AM
  23. Zakman's Avatar
    Re-UPLOADED WITH FIXES
    08-21-2012 12:38 AM
  24. YoshinJaa's Avatar
    How is the battery drain on this rom since you have implemented 4.1 kernel? Still the same? improved?
    08-21-2012 12:48 AM
  25. Zakman's Avatar
    Gapps With Google Now Added.
    08-21-2012 12:59 AM
