09-01-2012 01:07 PM
788 ... 2425262728 ...
tools
  1. andrewnelson23's Avatar
    Why google now of it doesn't work? How's the camera going? I need that before I switch to this as my daily.
    08-21-2012 10:49 AM
  2. ZackVortex's Avatar
    I have a bug in gnow when I scroll the search bar scrolls not the page
    08-21-2012 01:15 PM
  3. Zakman's Avatar
    That's a bug of Google now
    ZackVortex likes this.
    08-21-2012 01:35 PM
  4. jonny5449's Avatar
    Alright Zack awesome job
    Sent from my LG-LS670 using Tapatalk 2
    08-21-2012 05:46 PM
  5. mcclain71's Avatar
    I seem to have fixed the switched home and menu key problem, by going to /system/usr/keylayout/thunderc-keypad.kl and changing a few keys (139 and 102) around.
    key 139 HOME WAKE_DROPPED
    and
    key 102 MENU WAKE
    Simply switch the HOME and MENU text around:
    key 139 MENU WAKE_DROPPED
    and
    key 102 HOME WAKE
    Then save the file, and reboot. Works so far for me.
    i have tried this like 5 times....and nothing happens :/ i go back into the settings, and its like it never saved even though i saved it. lol
    08-21-2012 06:24 PM
  6. Zakman's Avatar
    and
    key 102 MENU WAKE
    and
    key 102 HOME WAKE
    I reuploaded the ROM with the keys fix, just redownload alpha 7
    08-21-2012 07:28 PM
  7. jonny5449's Avatar
    Thanks again Zack
    Sent from my LG-LS670 using Android Central Forums
    08-21-2012 08:01 PM
  8. nitestalkr's Avatar
    How is the battery drain on this rom since you have implemented 4.1 kernel? Still the same? improved?
    I can get several hours (3-5) of playing Celes Arca MMORPG and it will drain to 30%-40% in that time... soooo I'd say it's GREATLY IMPROVED!
    08-21-2012 10:58 PM
  9. eletendre84's Avatar
    Good job Zak. Looks like hephappy fixed camera on xda.
    08-22-2012 07:00 AM
  10. jonny5449's Avatar
    1. havent noticed yet, but only had it a day.
    2. mp3 cannot be used directly as ringtone, but easily can be made into a ringtone using Ringdroid, free android app off of android market. This app can also be used to edit/chop up mp3s to get exactly the loop you want...pretty sweet. honestly though, I would like if mp3 could be selected straight up as a ringtone.
    3. You can check gmail through the gmail.com webpage on the phone, or you can also log into "Gmail" application on the phone which appears to only handle 1 gmail account at a time. So, no, no-multiaccount notifications, I would say. Very probable that someone will come out with this in a custom app though.
    Custom apps man...get what you want out of the phone.
    :what:
    I will DEFINATLY look into it
    EDIT:wrong quote:o
    08-22-2012 08:34 AM
  11. jonny5449's Avatar
    His thread is closed....
    Edit:nvm
    08-22-2012 08:42 AM
  12. kenharkey7's Avatar
    So I've been away for a couple days. The latest alpha 7 had the button fix AND the new kernel correct?
    08-22-2012 03:22 PM
  13. jonny5449's Avatar
    Yup
    08-22-2012 05:10 PM
  14. ZackVortex's Avatar
    awesome battery life
    I left the sync, gps, and 3g off in airplane mode and it stayed at 100% for the whole school day (7:20-2:36)
    Zakman likes this.
    08-22-2012 08:56 PM
  15. Zakman's Avatar
    Updated OP with latest custom Gapps, Now with working google ears.
    08-22-2012 10:16 PM
  16. jonny5449's Avatar
    Getting better and better huh
    08-22-2012 10:24 PM
  17. joerivera17's Avatar
    Do you think you can include the camera fix from bob rom?
    08-22-2012 11:08 PM
  18. Zakman's Avatar
    I can try.
    joerivera17 and mcrumps like this.
    08-23-2012 12:08 AM
  19. Zakman's Avatar
    Anyone willing to beta test? I dont have my phone with me atm
    08-23-2012 12:24 AM
  20. mcrumps's Avatar
    I was just about to reflash alpha 7... I can test for you first if you like...
    08-23-2012 12:40 AM
  21. Zakman's Avatar
    Here's Alpha 8 for testing only: cm-10-Alpha8.zip
    08-23-2012 12:57 AM
  22. mcrumps's Avatar
    I don't think I have access to that download link... it says something about "authorize download"
    edit: never mind... it's late for me... lol
    08-23-2012 01:05 AM
  23. mcrumps's Avatar
    I tried to flash alpha 8, but it's not letting me... I went back to alpha7_2
    08-23-2012 01:49 AM
  24. Zakman's Avatar
    What's it say?
    08-23-2012 01:56 AM
  25. mcrumps's Avatar
    What's it say?
    It says:
    set_perm: some changes failed
    E:Error in /sdcard/cm-10-Alpha8.zip
    (Status 7)
    Installation aborted.
    08-23-2012 02:01 AM
