09-01-2012 12:07 PM
788 ... 2526272829 ...
tools
  1. nitestalkr's Avatar
    It says:
    set_perm: some changes failed
    E:Error in /sdcard/cm-10-Alpha8.zip
    (Status 7)
    Installation aborted.
    Redownload, disable signature verification in recovery, flash. That should work.
    sent from my Zom-"Bean'(CM10 JellyBean).
    08-23-2012 03:26 AM
  2. nitestalkr's Avatar
    Here's Alpha 8 for testing only: cm-10-Alpha8.zip
    I loves me some Ports 'n Beans.
    Flashing as soon as it downloads.
    I believe alpha 8 test has an update-scripting error??
    Redownloaded at least 10 times(persistent aren't i?) And each returned the status 7 error as mentioned earlier.
    08-23-2012 03:29 AM
  3. jonny5449's Avatar
    What's changed in alpha 8
    Sent from my LG-LS670 using Tapatalk 2
    08-23-2012 08:18 AM
  4. Zakman's Avatar
    Yuppp simple update script fix. I'll do it when I get home, alpha 8 is a complete lib and etc overhall. It fixes app2 SD native (hopefully) and camera.
    joerivera17 and nitestalkr like this.
    08-23-2012 12:41 PM
  5. capslock118's Avatar
    I'm sure this wont matter with alpha8 and going forward, but when I loaded alpha7_2 I used link2sd to force all of my apps into sd-ext, dalvik-cache, etc; basically had it set to move as much as it could and to do so for every new app install. I've had no problems with it. As in to say I have not yet had the problems others have reported where the apps would just disappear.
    Also wanted to point out that native AP tethering doesn't work; similar to the various ICS roms you can find here.
    08-23-2012 01:11 PM
  6. andrewnelson23's Avatar
    Fixes camera???!! a;lsdkfj;alskdjf;laksdjf;lkj I'm so pumped. As soon as the update scripts get fixed, it's becoming my new daily.
    08-23-2012 02:42 PM
  7. adamhos's Avatar
    NICE!!!
    08-23-2012 03:49 PM
  8. jonny5449's Avatar
    Cmon zakman release alpha 8
    Lol lol jkjk
    Take your time can't wait to fix camera in my rom
    08-23-2012 04:08 PM
  9. bxray's Avatar
    No plans for Navigation bar??
    08-23-2012 04:27 PM
  10. jonny5449's Avatar
    Why that's aokp whole other story
    A-android-B likes this.
    08-23-2012 04:58 PM
  11. nitestalkr's Avatar
    You're not supposed to use link2sd.
    There's already native app2ext support, just like quattrimus.
    Link2sd doesn't play well with the app2ext scripts. If you have any future issues, you've been warned, and will have to remove link2sd, and wipe your sd-ext partition, and thus losing all of you're apps.
    And until the known issues in ICS are fixed, they will persist in jellybean (Wifi AP, choppy HD streaming, Netflix, etc).
    08-23-2012 05:08 PM
  12. Nico72's Avatar
    Our phone's screen is way too small for a nav bar. The phone has buttons, so there is no need for it.
    kenharkey7 and purpulehaze like this.
    08-23-2012 06:06 PM
  13. reaper420's Avatar
    the nav bar fits perfectly fine if you reduce the size a little, and comes in real handy when not all the buttons on the phone work
    08-23-2012 07:41 PM
  14. jonny5449's Avatar
    That would be something for aokp jellybean
    08-23-2012 07:44 PM
  15. reaper420's Avatar
    I would jump on that quick
    08-23-2012 07:48 PM
  16. jonny5449's Avatar
    Lots of people would hopefully zakman,bob,or I will port it after jellybean is almost fully functional like ics but that will be awhile
    My new Godzilla might have nav bar maybe
    08-23-2012 08:18 PM
  17. Rudeco's Avatar
    @jonny. I don't personally know you but I wanted to say u remind me of myself 17 yrs ago when I was ur age. 17 years ago I was learning HTML, and Modding Windows games lol. Anyway. Keep up the great work! While I love that both my God sons that are about your age are playing football...... I secretly wish they were porting and developing ROMs too lolz.
    jonny5449 likes this.
    08-23-2012 08:29 PM
  18. jonny5449's Avatar
    Lol ya I see where that comes into play
    The fun part is making Godzilla for the nexus 7 I'm gonna get one 40 bucks in 160 more to go
    08-23-2012 09:00 PM
  19. anthonycr's Avatar
    Didn't you say you already have a nexus 7?
    08-23-2012 09:21 PM
  20. ShadowEO's Avatar
    Mine's being shipped :-) got no notice of it shipping but the receipt email said that the card would be charged when it shipped and it was charged. only wish they'd given me a tracking number.
    Sent from my LG-LS670 using Android Central Forums
    08-23-2012 09:25 PM
  21. capslock118's Avatar
    Yes, I know. I was just pointing out that link2sd worked well for me for the last couple days while others here have posted that the built in doesn't work too well.
    Not trying to encourage its use, rather, perhaps see why link2sd works and the built in does not. Like I said though, probably not worth the effort if alpha8 has a fix for native support.
    08-23-2012 09:30 PM
  22. jonny5449's Avatar
    No Anthony I didn't
    I'm saving up
    08-23-2012 09:59 PM
  23. A-android-B's Avatar
    Wish I had the money I'd buy us both one right now Jonny
    08-23-2012 10:42 PM
  24. sellers86's Avatar
    or maybe tdm could keep his quattrimus legacy going... But back on topic guys.
    08-23-2012 10:46 PM
  25. capslock118's Avatar
    [ignore this post] - bluetooth tethering works great
    08-24-2012 11:15 AM
