09-01-2012 01:07 PM
788 ... 29303132
tools
  1. Zakman's Avatar
    Will update slimmed gapps tomorrow, with scrolling google now. But a warning gapps has gotten bigger. It's 56.1mb now.
    08-30-2012 03:31 AM
  2. ThatGuyLurkin's Avatar
    Won't that only make like, the first 10 Apps in the zip flash?
    08-30-2012 04:18 AM
  3. ThatTechHead's Avatar
    I think I'm going to flash this on the old optimus v laying around. I rooted with gingerbreak last night and I'm gonna flash cwm today. Should I just flash this first or start with another ROM?
    Edit: flashing!
    Re-edit: flashed! And its awesome!
    Sent from my LG-VM696 using Android Central Forums
    08-30-2012 07:16 AM
  4. jonny5449's Avatar
    Why
    Sent from my LG-LS670 using Tapatalk 2
    08-30-2012 07:47 AM
  5. ThatGuyLurkin's Avatar
    Hence the word ' Update ' Jonny.
    08-30-2012 11:27 AM
  6. Zakman's Avatar
    The optimus V has 179mb of space. Im sure it'll work.
    08-30-2012 01:14 PM
  7. Zakman's Avatar
    New Gapps added. OP updated.
    Badboytoast and ZackVortex like this.
    08-30-2012 01:41 PM
  8. ThatGuyLurkin's Avatar
    Data partition, system has less ?
    08-30-2012 03:21 PM
  9. redrunner1985's Avatar
    Will flashing ur gapps with bobz rom fix the home key?
    08-30-2012 04:14 PM
  10. jonny5449's Avatar
    @tgl
    No I mean why's it so big
    08-30-2012 05:00 PM
  11. redrunner1985's Avatar
    Is theme chooser up and running on ur ROM yet?
    08-30-2012 07:02 PM
  12. Zakman's Avatar
    It will be once bobzhome releases his new build and then jonny5449 updates his build I'm going to port from jonny5449.
    08-30-2012 07:12 PM
  13. Zakman's Avatar
    It should fix the gapps problem yes.
    08-30-2012 07:13 PM
  14. jonny5449's Avatar
    Can't wait till we get theme chooser
    08-30-2012 08:16 PM
  15. ThatGuyLurkin's Avatar
    Im confused, your porting a V version rom ported to the S? :what:
    08-30-2012 08:21 PM
  16. Zakman's Avatar
    Bob wouldn't give me permission because he has ported the rom to the V, he gave jonny permission because he is porting a V to S. So Jonny is giving me permission to port his lol. A little work around
    08-30-2012 08:31 PM
  17. Ryuk6666's Avatar
    Hey, zakman. I flashed the new gapps package and when I go to scroll, the only thing that scrolls is the Google search bar.... nothing else lol.
    Sent from my Paranoid OV
    08-30-2012 08:48 PM
  18. jonny5449's Avatar
    Yup lol he said he might make for the s though
    08-30-2012 08:52 PM
  19. ThatGuyLurkin's Avatar
    Is that even right.....? Jonny didnt port anything, he judt chabged stuff to Sprint. Taking it back and making it VM, wouldn't that be like taking Bobz rom still....?
    08-30-2012 09:15 PM
  20. Zakman's Avatar
    Flash the one that just says gapps
    Ryuk6666 likes this.
    08-30-2012 09:17 PM
  21. jonny5449's Avatar
    Not if I added a little snazz and slim down
    08-30-2012 09:17 PM
  22. Zakman's Avatar
    Not if I port it from Johnny's rom. I would still add in my own tweaks and lib files. And apps
    08-30-2012 09:18 PM
  23. Ryuk6666's Avatar
    Also I dont know if anyone has brought this up, but when you click on storage in settings, it force closes....
    Sent from my Android 4.1 Jelly Bean OV
    08-30-2012 09:50 PM
  24. ThatGuyLurkin's Avatar
    Thats still Bobz rom, lol. xD
    jonny5449 likes this.
    08-30-2012 09:56 PM
  25. Ryuk6666's Avatar
    That is the one I downloaded...... :/
    Sent from my Android 4.1 Jelly Bean OV.
    08-30-2012 09:57 PM
788 ... 29303132
