09-01-2012 12:07 PM
788 ... 56789 ...
tools
  1. anthonycr's Avatar
    tried to replace the cdma folder, that started producing an error "unfortunately, the process com.android.phone has stopped." That happened over and over and over again. No service. I then tried replacing the entire telephony folder. Gives me the same error. So far we're best with the cdmasmsdispatcher just replace. I guess I (or maybe someone more knowledgeable??) will have to go into the cdmasmsdispatcher.smali and maybe edit the info in there.
    I just helped a Nexus S 4G owner port jellybeand from the Nexus S. He was able to get everything working and he replaced the /system/etc/permissions with CDMA permissions and I think it worked for him. Run a logcat
    08-08-2012 11:40 AM
  2. mcclain71's Avatar
    im so abouta try this
    everything in alpha 1 worked great except the camera. since my camera seems to have a mind of its own lately (whether it wants to work or not) i might just go to this JB rom and stay there
    08-08-2012 11:42 AM
  3. andrewnelson23's Avatar
    Beast. haha okay. Ill run the logcat with cm10 alpha2.
    08-08-2012 11:42 AM
  4. mcclain71's Avatar
    noticed something, and i dont know if it could be classified as a bug. im using wp7 notification plus, and on the banner (top part of the screen) when a message comes in, its supposed to be a colored bar...in my case its lime green. but theres no colored bar, just the text
    edit...all of a sudden, my sms isnt working. and im using the same file i did previously. weird :/
    08-08-2012 12:18 PM
  5. andrewnelson23's Avatar
    New thread about mms fixing. please go here for logcat and cdmasmsdispatcher.smali files.
    08-08-2012 12:23 PM
  6. jonny5449's Avatar
    Stupid question but does this have jellybean animations???
    looking for good keyboards??
    visit
    jonskeyboards.com
    08-08-2012 01:44 PM
  7. jonny5449's Avatar
    @zakman
    Also did u figure out where the battery drain is coming from??
    visit
    jonskeyboards.com
    08-08-2012 01:55 PM
  8. sellers86's Avatar
    visit
    jonskeyboards.com
    well its jellybean, so yes lol
    08-08-2012 02:23 PM
  9. jonny5449's Avatar
    Just asking but as I said stupid question
    After battery drain is fixed I might use nitestalkrs patch and flash
    visit
    jonskeyboards.com
    08-08-2012 02:25 PM
  10. sellers86's Avatar
    visit
    jonskeyboards.com
    I never had battery issues with drews rom when I ran it.
    08-08-2012 02:30 PM
  11. nitestalkr's Avatar
    visit
    jonskeyboards.com
    I don't experience a significant battery drain, in fact, I'm experiencing extraordinary battery life!
    sent from my un-dead sammich.
    andrewnelson23 likes this.
    08-08-2012 03:00 PM
  12. mcclain71's Avatar
    wonder why my alpha 1 copy is acting up now...
    08-08-2012 04:00 PM
  13. andrewnelson23's Avatar
    Zakman, for alpha 3, are you looking at removing the mms fix and (hopefully) adding SD-ext scripts and the keyboard swap? Or are you working on something bigger?
    08-08-2012 04:06 PM
  14. jonny5449's Avatar
    It says under
    Issues
    Battery drain
    For this rom
    visit
    jonskeyboards.com
    08-08-2012 04:10 PM
  15. sellers86's Avatar
    It says under
    Issues
    Battery drain
    For this rom
    visit
    jonskeyboards.com
    Pretty sure it was fixed
    08-08-2012 04:29 PM
  16. r0gu3dev1pr's Avatar
    Bug Report
    Use of headphones during a phone call, I have to toggle the mute button in order for the sound to be heard.
    Sent from my LG-LS670 using Android Central Forums
    08-08-2012 04:56 PM
  17. nitestalkr's Avatar
    I'm pretty sure too. I mean Drew's has slightly better battery life, but this ROM has pretty good battery life too.
    08-08-2012 05:05 PM
  18. sellers86's Avatar
    I could've swore I saw that he found a fix in the support thread.
    08-08-2012 05:42 PM
  19. jonny5449's Avatar
    One last question
    Is this more cm'ish
    Or aosp'ish
    visit
    jonskeyboards.com
    08-08-2012 06:03 PM
  20. andrewnelson23's Avatar
    cm-ish it has all the goodies except themes.
    08-08-2012 06:07 PM
  21. jonny5449's Avatar
    I can live without those
    I will prolly flash when next alpha is out
    visit
    jonskeyboards.com
    inceyet likes this.
    08-08-2012 06:11 PM
  22. eletendre84's Avatar
    Would the mms fix work for sprint as well?
    08-08-2012 06:12 PM
  23. andrewnelson23's Avatar
    the mms was fixed, but it broke the outgoing sms. I wouldn't do it unless you just wanna send mms texts all the time :P working on it, but I don't know what I'm doing.... :P
    08-08-2012 06:20 PM
  24. Zakman's Avatar
    For alpha 3 I'm adding small keyboard app2sd scripts and hopefully some one can get a mms fix. Or I'll try to.
    08-08-2012 06:34 PM
  25. andrewnelson23's Avatar
    I'm working on it, but you should totally too! hahah. swapping the cdmasmsdispatcher fixed the mms, but broke the outgoing sms. so I'm going to try editing the items in the quattrimus cdmasmsdispatcher to keep the outgoing messages coding from the cm10 one. which will probably take more than just a couple of days :P
    08-08-2012 06:44 PM
788 ... 56789 ...
