09-01-2012 12:07 PM
788 ... 678910 ...
tools
  1. jonny5449's Avatar
    For alpha 3 I'm adding small keyboard app2sd scripts and hopefully some one can get a mms fix. Or I'll try to.
    Then I will wait
    looking for good keyboards??
    visit
    jonskeyboards.com
    08-08-2012 06:46 PM
  2. eletendre84's Avatar
    Are you planning on using rashed's build to port/? I believe all audio has been fixed in that build. Including in call sound.
    Sent from my LG-LS670 using Android Central Forums
    08-08-2012 09:24 PM
  3. Zakman's Avatar
    All audio for the optimus One not our Optimus V
    08-08-2012 09:38 PM
  4. Zakman's Avatar
    "I had the same problem on 2 different versions of CM on 2 separate phones. This fix worked both times. Use root explorer, and make sure it is set to R/W mode (read/write). Navigate to /data/data/com.android.providers.telephony/databases/telephony.db and delete that file, then restart your phone. After the restart, you should be able to send and receive MMS messages."
    - Anyone try?
    08-08-2012 09:44 PM
  5. eletendre84's Avatar
    Ohh so we would need a source build to do it? Darn.
    08-08-2012 09:47 PM
  6. sellers86's Avatar
    No...
    08-08-2012 10:07 PM
  7. cammykool's Avatar
    the changelog says we have MMS?
    08-08-2012 10:07 PM
  8. andrewnelson23's Avatar
    Technically, we do. But it broke outgoing sms. soooo yeah. working on it now.
    08-08-2012 10:18 PM
  9. cammykool's Avatar
    when MMS works let me know xD to quattrimus i go
    08-08-2012 10:22 PM
  10. Zakman's Avatar
    Is it possible to use an optimus One kernel on our V?
    08-08-2012 11:29 PM
  11. sellers86's Avatar
    No we can't. Why?
    08-08-2012 11:32 PM
  12. Zakman's Avatar
    Alpha 3 is up!
    sellers86 and inceyet like this.
    08-08-2012 11:47 PM
  13. Zakman's Avatar
    also, since jb is different then ics, i don't think we can use an ics kernel.
    08-09-2012 12:16 AM
  14. andrewnelson23's Avatar
    why not? ics is different than gingerbread, but we use gingerbread kernels...
    08-09-2012 12:24 AM
  15. JadenBrown30's Avatar
    What are the changes in Alpha3?
    08-09-2012 12:28 AM
  16. Zakman's Avatar
    Check the Changelog.
    08-09-2012 12:34 AM
  17. JadenBrown30's Avatar
    Good work! I'll probably be flashing tomorrow, its already my DD
    Zakman likes this.
    08-09-2012 12:37 AM
  18. andrewnelson23's Avatar
    how'd the sd-ext scripts work?
    08-09-2012 01:26 AM
  19. ganggreen30's Avatar
    Encryption??? Can we encrypt our phones with the encryption setting?
    Sent from my LG-VM670 using Xparent Pink Tapatalk 2
    08-09-2012 01:43 AM
  20. Zakman's Avatar
    Well, in the next release imma use
    The cai alpha15 kernel. Run 10 times faster and probably has better battery life. Also, I've gotten the storage in system settings to work but now when I try to move an app it doesn't detect the SD.
    Master Gowa likes this.
    08-09-2012 02:09 AM
  21. Master Gowa's Avatar
    Couldn't wait to try this so I did a clean wipe and jumped on Alpha 1 right before Alpha 3 came out. So I did a dirty wipe and upgraded to Alpha 3. Seems like it's running great but I've got nobody to test the SMS and MMS with at the moment. I don't think the sd-ext scripts worked properly. I have a 1 gig EXT4 partition but Titanium Backup didn't list it. Also the roms storage menu crashes. Aside from that... I'm loving it. Thanks for the hardwork.
    How come some apps from the Playstore are fine but others are now incompatible? Will a Titanium Backup of an app from ICS work on JB or are some apps really incompatible now Viber and Instagram worked on ICS but the Playstore now won't let me download them.
    08-09-2012 02:16 AM
  22. Zakman's Avatar
    They're incompadable Cruz jellybean is a new os and not many app devs have updated yet.
    08-09-2012 02:21 AM
  23. jonny5449's Avatar
    You have pushed me to the breaking point of curiosity I'm flashing
    visit
    jonskeyboards.com
    08-09-2012 06:50 AM
  24. jonny5449's Avatar
    Is the moving apps 2 sdcard fixed because I plan on restoring a app that's at least 120 mb
    visit
    jonskeyboards.com
    08-09-2012 06:54 AM
  25. mcclain71's Avatar
    i checked the changelog for alpha 3, and the only thing i see mentioned is a new tiny keyboard. does this mean that the sms/mms issues are not fixed?
    08-09-2012 07:17 AM
788 ... 678910 ...
