WARNING!
Hello, First I would like to tell you that I am not responsible for anything that happens to your phone by flashing this! If you have a problem, post here and we will try and help you with your issue! Thanks!
Also:
THIS IS A WORK IN PROGRESS! THERE WILL BE BUGS! If you see a bug, please report it! Thank you.
Credits
Most of this rom was an original port from drewwalton19216801 and his team! His Cm10 Port Most of the things working in this rom are from them. So thanks to them! Other things were taken from laz3r69's p500 port: CM10 p500 So thanks to him also
Screenshots
INFO
What works and what doesn't:
Working:
Calls (including microphone!)
SMS
3G data
Wi-Fi
Graphics Acceleration (for the UI)
Sensors (Accelerometor, Proximity Sensor)
GPS
Sound(Speakers and Headphones)
MMS
Bluetooth
Not working:
Camera
Google Now
Mic On Voice Search and or Google Ears.
Issues(Any help from anyone on how to fix these would be appreciated ):
Moving Apps to the SD Card(They move fine to the card but when you reboot they are gone)
Play store(Store does not have much on it yet, because the Android OS isn't officially released yet)(Fixed! Modded Play store added in Gapps )
Battery Drain
Menu and Home Button Keys are switched. FIXED
Work Arounds:
USB Mass Storage(App Installed)
MMS: http://forums.androidcentral.com/op...cold-ice-working-optimus-v-9.html#post1758086
INFO
To install:
1. mount phone and move Zips to the SD Card
2. Boot into Recovery
3.DO a FULL WIPE
4. format /system/
5. Flash ROM
6. Flash jb mini Gapps
7. Flash Beats Audio (Optional)
8. Reboot
Download
Download Link:
links removed by moderator.
CM10 LIGHT Gapps(56.1mb):
Gapps
CM10 Mini Gapps With Google NOW! (Read instructions below to get voice working) AND NEW GOOGLE EARS!(15mb)
Gapps + Google Now + Google Ears
Beats Audio(Optional): Beats
GNOW Voice Search
CHANGELOG
08-06-2012-
Original Upload
08-08-2012-
Tiny Keyboard added (Only 2mb!) (Thanks to Andrew!) (Link for credit: Link )
08-12-2012
app2ext (added, Thanks to Nitestalkr and his int.d scripts)
Replaced libwmsts.so for better connection speeds
Re-uploaded Gapps
Added a YouTube app
08-15-2012
Added new Youtube apk
MMS Fixed (Hopefully)
Theme chooser added but not working atm.
08-16-2012
Alpha 5 Reuploaded
Gapps Reuploaded (Added Play store without incompatibility issues. ) (Thanks to reaper420)
08-18-2012
RIL Changes (Added libnv.so for improved RIL reliability.)
Build prop changes
New GPS file for Improved accuracy
08-20-2012
New RIL files added (Thanks to BobzHome) (WAY Better Reliability!)
Bobzhome's 4.1 Kernel Added (No Need to flash test15 anymore!) (Thanks to BobzHome)
Launcher Sizing Fixed
All audio Files fixed (When you call someone now you can hear them through to front speaker)
08-21-2012
Reuploaded with Key swap fix (Hopefully) (Thanks to Katnuk)
08-22-2012
Added working google ears to gapps
08-24-2012
Added Beats audio (Optional)
08-30-2012
Added new LIGHT Gapps with scrolling google now, voice still doesn't work, it could possibly never work. (Moded from Rashed His Rom )
Thanks!
Special Thanks!
andrewnelson2
reaper420
and laz3r69!
Current
Currently working on:
App to SD Problem.
Using a different Kernel
Fixing Home and Menu Keys
Google Now Flashable Zip
Donations
Donations are welcome but not needed for download
Donate
Thank you
