nitestalkr
I'm pretty sure they should be r/w/x otherwise they won't execute.
Yea that's true, slipped my mind when I posted that.
sent from my Zom-"Bean'(CM10 JellyBean).
Which launcher? Apex or nova to be implemented into alpha 4
Just thought I'd mention this, but when I download my cover art using Cover Art Downloader it works until I reboot my phone, then all the album art disappears. Don't know if its a bug with the ROM or app but I thought I'd just throw that out there.
Its proly because of the sdcard issue where things seem to be gone after a reboot. The sd ext scripts will maybe fix it.
Well, if Zack(and I'm sure he will) implements those sd-ext init.d scripts, it will be worth it.
I've got 197 apps installed, using alpha3 + what I provided, and not a single app has caused me any issues.
Only annoying part so far, is the "Android is Upgrading: optimizing 'x' out of 'a lot' of apps..." at every boot.. I wonder how tdm fixed that in CM9, maybe the same method could be used for CM10?
I think imma leave trebuchet launcher and impliment the scripts when I get home, nitestalkr do I have to be partitioned for these scripts to work?
That happened to me once. I think it's cuz the a firmware has a smaller system partition.. .
@everyone.
This app 2 ext scripts I provided aren't meant to fix movement of apps to the SD card, after flashing the ROM after you pit the files into it, it automatically moves all apps to the ext partition, just like in quattrimus.
You can only apply it as directed in the zip I provided(or if Zack adds it to the next build).
Its app2ext, not app2sd.
I found out that it can only be added to the ROM.zip before install.
So follow the instructions within the zip, using a computer.
sent from my G-T-R.
@Zackman, instructions are included in the zip, this is NOT flashable(however, I will include this in all of my patches I made, by Saturday.), and this is to be implemented into the ROM.
@nitestalkr can you point me to your zip that you made.
Sent from my LG-LS670 using Android Central Forums
I'm still really stumped on this native app2sd problem. Replaced the vold files, that didnt work, replaced bin files with others from a different rom, that didnt work, replaced librarys, got bootloop :/ dang. This is going to be difficult.
