[ROM][WIP-ALPHA7][CM10 PORT] Jelly for Optimus V
Status
Not open for further replies.
Zakman
492
185
Re: [ROM][WIP-ALPHA3][CM10 PORT] Jelly for Optimus V
Uploading a build, and I was also wondering should i put in ICS google search for now or leave the broken google now?
Reactions: JadenBrown30
JadenBrown30
131
31
Can I use the CAI kernel on Alpha 1(because I have yet to flash Alpha 4 :p)? More importantly, how do I flash it? I've never flashed a kernel.
hansgroter
Active member
Jun 3, 2012
40
Re: [ROM][WIP-ALPHA4][CM10 PORT] Jelly for Optimus V
this worked great for me
Reactions: Zakman
Master Gowa
Active member
Jun 24, 2012
28
4
Question... why CAI kernel? Not trying to second guess you. Just curious.
I thought I read that Cold As Ice died and was merged into or became Quattrimus. If so... wouldn't that make the latest Quattrimus kernels superior?
jonny5449
AC Citizen
Dec 14, 2011
2,553
286
Its just smoother
Sent from my LG-LS670 using Tapatalk 2
ShadowEO
337
96
Hey Zakman, what did you do to get the microphone working? Over on the OptiS it doesn't work on either CM10 versions. Also, I was going to try Kraven's Camera Libs but drew said it was a kernel issue so I decided against it.
Sent from my Toshiba NB305 running Android-x86 4.0 using Android Central Forums.
Zakman
492
185
Btw, to fix voicemail, go into the phone app, menu button, settings, voicemail settings, Voicemail Number and change it to your phone number.
Status
Dawncompton
