[ROM][WIP-ALPHA7][CM10 PORT] Jelly for Optimus V
Status
Not open for further replies.
eletendre84
#sarcasm
Jul 15, 2011
386
80
What camera fix
Would love to fix camera
Sent from my LG-LS670 using Tapatalk 2
Swapping thekravens camera libs fr ICS won't work. Needs to be fixed @ source level first. I can live without camera. Any progress made on an MMS fix?
jonny5449
AC Citizen
Dec 14, 2011
2,553
286
Sort of the the OS forums theirs an MMS fix I may be able to modify it for sprint /virgin mobile
mcclain71
173
8
Re: [ROM][WIP-ALPHA4][CM10 PORT] Jelly for Optimus V
pardon my ignorance here, but if alpha 1 had both the mms and sms working perfectly...then why all not just revert back to it? :)
nitestalkr
889
261
Question... why CAI kernel? Not trying to second guess you. Just curious.
I thought I read that Cold As Ice died and was merged into or became Quattrimus. If so... wouldn't that make the latest Quattrimus kernels superior?
CAI and Quattrimus are 2 different ROMs, they never merged.
sent from my G-T-R Reloaded V
Reactions: jonny5449
andrewnelson23
795
145
No it didn't. It fixed mms, yes, but it broke outgoing sms. Try it and see. Nitestalkr, thekraven quit working on his cai project for awhile and gave tdm everything. So they are kinda the same in certain things, I think.
andrewnelson23
795
145
anyway, it doesn't matter about the merge between quattrimus and cai. cai's kernel was updated after thekraven started working on it again. so the kernel is different than quattrimus's. possibly better. haven't tried.
inceyet
393
121
Is there a update on the mms /SMS fix as well as perhaps the camera fix all which are stopping this from being my dd . Thanks to all involved
Sent from REKCITY.com
andrewnelson23
795
145
two problems with the go fix. first, it only fixes one sided. (I think outgoing). You still can't receive mms. Second, it's a third party app. Which sucks because it adds folders and stuff. Personally, I love go sms, but a lot of people don't.
Reactions: drm1992
drm1992
267
45
I agree with the last part.
Zakman
492
185
I'm working on the camera fix, thekraven is assisting me, he's currently telling me what files should fix the camera, for now MMS, download go sms pro and enter in the settings.
Reactions: inceyet
Zakman
492
185
Hmmm when I saved an IMG from the web it said it saved in sdcard0, in my file explorer it just says sdcard, so maybe its a cm10 coding error
Master Gowa
Active member
Jun 24, 2012
28
4
I think it's a bug in the sd-ext script. It seems to be functioning but Titanium Backup still lacks the 4th blue storage bar at the bottom. Recently SD Maid displayed "storage/sdcard0". I don't think SD Maid listed that before Alpha 4. I'm guessing it's something in the way it mounts the sd card now.
Status
WillyC
