Both alpha 4 and 5.
Did you do a clean you flash or dirty flash
It could be your phone's processor problem. Or it could be the kernel. Try switching the kernel. If that doesn't work, it might not. It could be that this rom on your phone on this rom is just too unstable at the default oc settings, and you can't change the defaults unless you're booted...
If that doesn't work try downloading every thing again than flashOk. I do flash test kernel 15 after gapps, so will try without flashing kravens kernel. If that doesn't work, I can change the default clock speeds on my first boot (its the second boot that's giving me problems) , so we will see if either of those help. I will report back. Thanks guys, and please feel free to come forward with any other ideas as to what the problem could be.
It's just odd it boots the first time, but not the second. I've never encountered this problem.
buy a new sdcard... or try reformatting the one you have... (copy sd to pc)(copy back after formatting)... ?
Overlooked.....
What Weather widget are you using in the Screenies?
Ok guys, for some reason reformatting and repartioning my sd card allowed me to boot the second time. Can anyone shed any insight as to why this made a difference? After all, I replaced all the files back onto the sd card that were there before the format. This one has me scratching my head in confusion. At any rate, it worked, and thats all that really matters.
Thanks guys.
Probably filesystem errors. You don't need to format. A simple chkdsk on the card would've sufficed.
Sent from my LG-LS670 using Android Central Forums
