kenharkey7
Re: [ROM][WIP-ALPHA5][CM10 PORT] Jelly for Optimus V
Im at the library right now, using alpha 5 with the test kernel and i've been on the wifi for the past 2 hours almost with zero issues.
Edit: I think I found the weather widget you guys wanted Weather Eye
I saw a couple of posts about this, but no real resolution. You guys using the test kernel, do you have working Wi-Fi? I flashed it, and it borked Wi-Fi, so I wiped and re-flashed without it and it seems to be working just fine, but would like to use what's recommended.
