Re: [ROM][WIP-ALPHA6][CM10 PORT] Jelly for Optimus V
That's a Gapps problem.
okay thanks
I think you probably know about this already but there seems to be a problem with app spacing as seen in my screenshot below
edit: also when you hold the lock button to get to the phone options it opens then closes then opens again.
edit: I know this is a gapps thing but it's weird how I'll get weather notifications in my notification bar from google now but if I try to click it I get a force close thing.
edit again: If you go in setting and try to open the storage part it just says "settings has stopped"
edit: I'm not sure if this is a bug but in the setting > About Phone > status it shows the serial number as "unknown"
edit: The Slider shortcuts setting seems to be a little messed up.
edit: I can't seem to get "Owner info" to show up on the lock screen.
edit: If you have mobile data off, wifi on(and connect), and you try to go into airplane mode it turns 3g on.
