nitestalkr
I'm sure this wont matter with alpha8 and going forward, but when I loaded alpha7_2 I used link2sd to force all of my apps into sd-ext, dalvik-cache, etc; basically had it set to move as much as it could and to do so for every new app install. I've had no problems with it. As in to say I have not yet had the problems others have reported where the apps would just disappear.
Also wanted to point out that native AP tethering doesn't work; similar to the various ICS roms you can find here.
You're not supposed to use link2sd.
There's already native app2ext support, just like quattrimus.
Link2sd doesn't play well with the app2ext scripts. If you have any future issues, you've been warned, and will have to remove link2sd, and wipe your sd-ext partition, and thus losing all of you're apps.
And until the known issues in ICS are fixed, they will persist in jellybean (Wifi AP, choppy HD streaming, Netflix, etc).
sent from my Zom-"Bean'(CM10 JellyBean).
