jonny5449
AC Citizen
Lol so I'll just use ur rom as a base. I'll help you out with stuff too.
Okay will update my rom tomorrow I'm stuck on mms
Sent from my LG-LS670 using Tapatalk 2
Try switching your apns file to the one from cold as ice
Tried it its also in framework.jar I think in Cdmas.smali and I'm lost when I have to edit it
You can't edit the cdma file, with the one from ics, its WAY different code
Zakman I just started using you ROM and its pretty kool Google now is this close to working. I hope you keep working on the ROM thanks
Yeah I Would wait till Bob releases his next build as well with the data radio issue worked out.
Will update slimmed gapps tomorrow, with scrolling google now. But a warning gapps has gotten bigger. It's 56.1mb now.
Won't that only make like, the first 10 Apps in the zip flash?
The optimus V has 179mb of space. Im sure it'll work.
