05-01-2012 01:03 AM
1,740 ... 1213141516 ...
tools
  1. ashton4life's Avatar
    Hello, Does this new updated 20110326 Rom have MMS working now? In Romrepo it's marked as yes. Can anyone confirm?
    Nevermind my bad, I was looking at the HTC info instead of the V. The answer is no it doesnt work. My outgoing MMS died on mine a few days ago too. Too bad!
    03-31-2011 12:05 AM
  2. dEris's Avatar
    I would be the first on to say it's impossible to get more than 24 hours on a single charge on this rom, but I have achieved it. I'm going 12th hours with 76% with moderate to heavy use. My secret? Use Tasker to disable 3G once screen is off and to turn it back on when screen is unlocked. I don't have it set to turn on when screen turns on because sometimes I turn my screen on to check the time. So that would be pointless. Try it guys.
    [ Sent from an LG Optimus V ]
    03-31-2011 12:19 AM
  3. whyaphoenix's Avatar
    delete
    03-31-2011 12:21 AM
  4. dEris's Avatar
    I successfully sent about 10 MMS messages using GO SMS over the last 3 days.
    Havent received any, but i got confirmation that the ones I sent worked
    Ya, sending mms works bro. You must be confused lol.
    03-31-2011 12:50 AM
  5. ashton4life's Avatar
    Yes my MMS send worked for a little while then it died for some reason. I dont know why. Kinda sux!
    03-31-2011 02:11 AM
  6. ashton4life's Avatar
    I was doing this since the day I bought the phone and it made a huge difference. Now I have this ROM. Today I used it for 9 hours taking lots pics at the fair and surfing at times and had 75% left when I got home! Cutting off 3G is the best way to get the most life out of your battery. Regarding turning your phone on to check the time, as long as you dont unlock it the 3G will not come on if you set 3G ON only when unlocking phone with Tasker. You can see the time in the phone lock screen.
    As some have noticed this Rom drains the heck out of the battery in WiFi. My phone gets pretty hot too. I know its normal to warm up but the drain is pretty fast. I go from 100% to 90% in 30-40 mins of WiFi regardless if I am downloading or surfing, it just has to be on. I hope some fix comes out for this because 2.2 wasnt that bad.
    03-31-2011 02:15 AM
  7. dEris's Avatar
    It's odd too because having Wifi turn off when screen shuts off is a built in Android feature and it shouldn't eat up the battery. It should mirror what disabling 3G does... to an extent. Odd!
    03-31-2011 04:08 AM
  8. dburg's Avatar
    You can off 3G with power control widget or notification widget as well. Data on in bad service area = death of battery.
    03-31-2011 08:32 AM
  9. ashton4life's Avatar
    No my Wifi stays on when screen locks unless I was to add it in Tasker same as my 3G shut off. I was just commenting it uses alot more battery then 3G especially on GB, alot more then Froyo.
    03-31-2011 06:57 PM
  10. ashton4life's Avatar
    I know, I had that before but I kept leaving it on so the auto on and off in Tasker really helps. I can always disable Tasker when I want it to stay on while in screen lock mode, Like when I am wifi tethering. It all works perfect, i cant complain at all.
    03-31-2011 07:00 PM
  11. shawayne21's Avatar
    How do you downgrade to a 2.2 rom, and change the recovery on this. Everytime i try, it sends me to a blue fastboot screen instead of the recovery i was tryin to instal...
    03-31-2011 07:00 PM
  12. Kreatur3's Avatar
    http://forum.androidcentral.com/opti...-features.html Not sure how to post the nicer looking links but this thread a bit below this one tells you how to flash a new recovery, really easy. going back to 2.2 just takes flashing a 2.2 rom just like the one you flashed to get to this one.
    03-31-2011 07:06 PM
  13. Liquidplacidity's Avatar
    Thought there was supposed to be a new release tonight at midnight?
    04-01-2011 12:12 AM
  14. Chef_'s Avatar
    I think he meant Pacific time...
    04-01-2011 12:19 AM
  15. JerryScript's Avatar
    At midnite, it becomes April Fools Day. I hope that doesn't apply here!
    Liquidplacidity likes this.
    04-01-2011 12:53 AM
  16. silverhawknike's Avatar
    what happen to other color in theme changer? I like the blue one in ZCM7
    04-01-2011 03:03 AM
  17. radiotecha1234's Avatar
    I use the program "WIFI Keep Alive" from the market. It lets you choose what the wifi does, I.e. stay on with screen off, go off with screen off, or stay on only on power plug. It works great and saves me a ton of battery. Last night I used it and before I go to bed I would lose like 20%. I only lost 5% with this enabled.
    04-01-2011 08:38 AM
  18. dburg's Avatar
    This is a built in feature of android. Goto Wi-fi Settings...Menu...advanced...wifi sleep policy
    denshigomi likes this.
    04-01-2011 11:32 AM
  19. dburg's Avatar
    took out to keep file size down. Download CyanbreadX from the market.
    silverhawknike likes this.
    04-01-2011 11:32 AM
  20. silverhawknike's Avatar
    i have a question. so far i loving both roms ZCM7 and AOSP CM7 too but i prefer to have stable rom so do you know where to get Gingerbread blue keyboard?
    04-02-2011 03:10 AM
  21. ashton4life's Avatar
    I need a ROM God to get full MMS working on this! PLEASE!!!
    04-02-2011 05:11 PM
  22. whyaphoenix's Avatar
    delete
    04-02-2011 05:19 PM
  23. ashton4life's Avatar
    Bluetooth seems to have more problems then just the headset. I cant get it to pair with my windows 7 desktop bluetooth. The passkey numbers are different and Bluesoleil doesnt let me change it. I guess bluetooth is pretty useless with this ROM. ?
    04-02-2011 08:53 PM
  24. jmars125's Avatar
    Bluetooth worked fine on this rom when transfering files to another phone
    ashton4life likes this.
    04-03-2011 12:44 AM
  25. Eollie's Avatar
    This has been addressed so many times.
    Posting you need a rom god to get it working might make you feel better, but in reality its just filling the thread with more drivel.
    First off the way Virgin sends mms is almost at pentagon encryption levels. Some of the best devs have took a crack at it and walked away scratching their heads. Its a very proprietary method and nobody wants to spend the amount of time required.
    Second if you need mms soooooooooooo bad the best bet is to go back to a stock rom. Otherwise tell people to email you the pictures and funny messages at your email. It is pretty much the only way right now.
    04-03-2011 04:05 AM
