05-01-2012 01:03 AM
1,740 ... 1516171819 ...
tools
  1. ashton4life's Avatar
    Question....I have the previous rom and was wondering what I need to do to get the same black menu and icons on top if I decide to install this one?
    BUMP
    04-06-2011 06:16 PM
  2. gattibom's Avatar
    I received a a top up MMS on this rom today and it worked fine. Is that an anomaly or a known non-issue related to the VM MMS encryption?
    04-06-2011 06:47 PM
  3. one80oneday's Avatar
    Anyone having trouble streaming audio? MLB at bat and a few other internet radio apps won't work. Might be network issue for me but just wanted to check here before I reflash everything.
    04-06-2011 07:33 PM
  4. mase123987's Avatar
    I used TuneIn Radio a few minutes ago and it worked just fine.
    04-06-2011 08:08 PM
  5. ashton4life's Avatar
    Do you mean a SMS? I just got the phone and am not sure but I would think top up reminders come in SMS format not MMS right?
    04-06-2011 09:29 PM
  6. shawayne21's Avatar
    is the 999999999 error only for MMS?
    04-06-2011 10:32 PM
  7. ashton4life's Avatar
    As far I have seen yes. Its part of the receiving message from MMS.
    04-06-2011 10:42 PM
  8. gattibom's Avatar
    I think you are correct. I believe I had my sms's and mms's mixed up. Sorry for any confusion.
    04-07-2011 12:34 AM
  9. justinh's Avatar
    how "close" exactly is MMS in this rom now?
    04-07-2011 02:13 AM
  10. Takenover83's Avatar
    After a recalibration, I think all is normal. Over a 4-hour period I lost 3% per hour. This is with Wifi-Keep alive activated (so I do not miss voip calls), and a few app's pulling in data. (weather every 6-hours, Launcher Pro widgets every 3 hours, and voip always sends it's heartbeat). I could bring that 3% down with a couple changes.
    Cell Standby = 33%
    WI-FI = 33%
    Phone idle = 33%
    ashton4life likes this.
    04-07-2011 09:24 AM
  11. one80oneday's Avatar
    How do I get quadrant up to 1600+? I have this Tom and overclock to 864 but the highest I can get quadrant is 1000. Just wondering, love the rom!
    04-08-2011 11:27 AM
  12. Chef_'s Avatar
    I noticed Quadrant plus gives a different number than quadrant free. I forget the number, but it was much higher.
    04-08-2011 11:35 AM
  13. valentinb102's Avatar
    I have a few questions about this rom.
    If I need to reprovision the phone is there any way of doing so without installing a stock rom to do it? Im referring to the activate app.
    Have the battery drain issues been fixed since the last update?
    Can I install this rom using the CWMA v1.2518.4 recovery that I got from Romtools?
    And finally, where can I find out whats been fixed? I've been on the romrepo page but that doesn't say much. It also seems like nobody's updated the site in a while.
    04-08-2011 12:06 PM
  14. Takenover83's Avatar
    I know this may not concern many folks but I thought I would mention it anyway.
    2.3.3, seems to have many problems with apps associated with video. It falls back to the OpenCore codec system that Google dropped starting with 2.3.1 from my understanding. Great Applications like "Plex" (Air Video for Android) fail to work. You will hear the audio but get no video. I am not sure if a simple edit of a few configs could fix the issue or not. But none the less, problems like this are not present in 2.2.1.
    04-08-2011 12:40 PM
  15. JerryScript's Avatar
    I haven't tried Plex yet, but I just browsed the forums and wiki at plexapp.com and noticed the video quality settings. Perhaps if you lower the video quality it will stream in?
    I also noticed info about plugins, which you may need:
    I cannot see my favorite plugin on Android - where is it!?
    1. Within your Plex Media Server go to Preferences/Advanced and check the box that says 'Disable Capabiliy Checking'.
    2. Restart the application - on Android you may need to kill or power cycle the device.
    3. Startup Plex for Android - they should now be in Plex Online if you've not yet installed them - you may do so now.
    4. After they're installed you will find plugins in 'Video Plugins', 'Photo Plugins', or 'Music Plugins' from the root menu.
    Have you tried VLC?
    04-09-2011 12:34 AM
  16. bman123's Avatar
    If someone has time can u please pm me, I am having nothing but trouble installing this, it constantly freezes at the android start up sign
    04-10-2011 12:59 PM
  17. 482123#AC's Avatar
    I was having the same problem at first. You need to make sure do a Wipe data/factory reset, and wipe cache partition. Then under Partitions menu (or Mounts & Storage in 3.0.0.6) in recovery: Format boot, system, data, cache. Under advanced: wipe Dalvik Cache.
    Then flash the Rom, then Gapps.
    04-10-2011 05:43 PM
  18. one80oneday's Avatar
    Battery drain seems worse on the newest release for me, can't figure out why. Haven't installed any different apps or anything. Anyone suggest some tips? I normally have everything off (GPS, Bluetooth, etc...) and other normal battery saving tricks. Maybe a new kernel would help me?
    04-10-2011 07:19 PM
  19. lfaber2006@gmail.com's Avatar
    My battery life only "looks" bad. The phone will drop to 50% battery within 2 hours of being off the charger but after 50% it drops extremely slow. I use the phone heavy for text web Facebook chat and the girl friend grabs it as soon as I set it down to play angry birds and I'm still getting 10-12 hours on this build. I have not done anything to it other then the 50% time without a signal fix and a reboot once a day. (Usually right after shutting off the alarm in the morn and before I get in the shower. Something I got used to dealing with on the hero.)
    Sent from my VM670 using Tapatalk
    04-10-2011 09:12 PM
  20. one80oneday's Avatar
    Well I'm a moderate to heavy user and I'm only getting about 6 hours per charge. I'm trying the 013 kernel, if that doesn't fix my battery life than I guess I'll just flash back to stock then to ASOP again and go from there. 50% mod changes nothing with mine and newest release fixed it.
    04-10-2011 09:22 PM
  21. JerryScript's Avatar
    I was just staring at my phone in amazement at the fact it is still at 79%. I took it off the charger at 8am, used it about every hour or so to check email, the status at the Masters, and made a few calls. It's now almost 7pm and I'm still at 79%.
    Those who are having battery issues with the 04/03 release most likely have some app that is causing their issues. I was using OpenSignal, a cell tower tracking app, and found that even when just running in the background, it took me down to 30% in about 8 hours. Since I stopped it via the services menu, I'm getting extremely good battery life with this ROM.
    One issue that has been mentioned in another thread is that the wifi can really drain the battery on CM7 04/03. I make sure I turn off wifi when I leave my house, and turn it back on when I get home.
    04-10-2011 09:48 PM
  22. bman123's Avatar
    I finally got this rom to work last night and it runs like a champ
    04-11-2011 09:06 AM
  23. Takenover83's Avatar
    CM7 final is out. So maybe we will see a fresh build for us Optimus V users.
    Engadget
    Cyanogenmod
    thexxoffspring likes this.
    04-11-2011 11:24 AM
  24. thexxoffspring's Avatar
    cm7 final is out. So maybe we will see a fresh build for us optimus v users.
    engadget
    cyanogenmod
    i. Want. Gingerbread. Now!
    04-11-2011 07:19 PM
  25. Eollie's Avatar
    THEN.BUY.A.PHONE.SUPPORTED.BY.THE.OFFICIAL.RELEASES.
    Otherwise give these guys a chance to get things worked out. Just because CM7 official is out doesnt mean its stable on all phones and most definately isnt stable on our phone. There are still issues being worked out.
    04-11-2011 07:25 PM
