05-01-2012 01:03 AM
1,740 ... 1617181920 ...
tools
  1. lfaber2006@gmail.com's Avatar
    Have you tried changing your governor settings? I get my best results using ondemand but that seems to slow wake-up time. Interactive only gives me good batery life if I clock to 787 Max and 245 min. Also I set the display to 50% and never mess with it. But for whatever difference it may make I am always in a service area. And the 50% time without a signal has made a huge difference as well as getting a full charge and then wiping battery stats.
    Sent from my VM670 using Tapatalk
    04-11-2011 07:31 PM
  2. RavenSEAL's Avatar
    Can anyone explain to me how to perfectly install this ROM? I've already flashed the recovery using ROMTools.
    I'd really appreciate the help! Thank you!
    Also backed up, i have the CWMA v1.2518.4 Xionia
    04-11-2011 07:56 PM
  3. JerryScript's Avatar
    1-- Make sure it was the recovery posted with this ROM, other recoveries might not work
    ClockWorkMod Recovery v3.0.2.4
    2-- Plug your phone into your computer via USB and enable USB mass storage
    (this should make your phone act like a USB flash drive)
    3-- Copy the CM7's ROM zip file to your sdcard, and copy the gapps.zip as well
    4-- Use your computer to eject your phone's sdcard
    5-- Turn off your phone
    6-- Hold the following three keys down till the LG logo appears and goes away
    Home+Down_Volume+Power
    7-- If you flashed the appropriate recovery in ROMTools, you should now see
    Note-- The volume up/down buttons moves the selection box
    The menu button activates the current selection
    The back button takes you back one step in the menus
    8-- VERY IMPORTANT STEP -- Select "backup and restore", then select "Backup"
    this will create a complete backup of your phone in case you have problems
    9-- From the main menu, select "wipe cache partition", then "Yes - Wipe Cache"
    10-- From the main menu, select "advanced", then select "Wipe Dalvik Cache"
    11-- From the main menu, select "advanced", then select "Wipe Battery Stats"
    Note-- Some people like to format various mounts, I never have, not necessary, though you may want to reset to factory defaults
    12-- From the main menu, select "install zip from sdcard",
    then select "choose zip from sdcard",
    then select the CM7 ROM's zip file, and install
    13-- From the main menu, select "install zip from sdcard",
    then select the gapps.zip file, and install
    14-- Once it's done, from the main menu, select "reboot system now"
    No messy ADB commands, just move a couple of files around using your computer, then reboot into recovery, wipe caches, install the zips, and reboot.
    Hope that helps!
    thexxoffspring likes this.
    04-11-2011 08:26 PM
  4. RavenSEAL's Avatar
    Got it all working! Thanks to the guys at the aosp chat room and jerry, thanks for the help! I'll give feedback as much as possible!
    P.s. How do i give thanks to someone on the forums? :P
    04-11-2011 08:37 PM
  5. thexxoffspring's Avatar
    THEN.BUY.A.PHONE.SUPPORTED.BY.THE.OFFICIAL.RELEASES.
    Otherwise give these guys a chance to get things worked out. Just because CM7 official is out doesnt mean its stable on all phones and most definately isnt stable on our phone. There are still issues being worked out.
    yes sir
    04-11-2011 08:49 PM
  6. thexxoffspring's Avatar
    besides MMS what other issues are there?
    04-11-2011 08:53 PM
  7. JerryScript's Avatar
    Bluetooth isn't fully functional at this time.
    04-11-2011 08:54 PM
  8. thexxoffspring's Avatar
    well i dont use blue tooth so i guess i can give this a run. wish me luck! haha
    04-11-2011 09:12 PM
  9. RavenSEAL's Avatar
    Nothing is syncing from google, any ideas?
    04-11-2011 09:24 PM
  10. RavenSEAL's Avatar
    nvm, all fixed after rebooting
    04-11-2011 09:49 PM
  11. RavenSEAL's Avatar
    btw, has anyone had any issues renewing service with the ROM? or it won't have any effects?
    04-11-2011 09:58 PM
  12. JerryScript's Avatar
    Haven't heard of any problems.
    04-12-2011 01:40 AM
  13. dEris's Avatar
    Learn how to edit a post bro.
    [ Sent from an LG Optimus V ]
    04-12-2011 11:01 AM
  14. nixie21's Avatar
    Thanks so much for this.... Quick questions (sorry if already posted)
    Besides MMS issue (and Bluetooth) anything else I should know?
    What is the advantage of this Rom over Rodimus, I know this is Gingerbread, but what is the advantage of having gingerbread??
    I understand (if I am correct) battery life on Rodimus is better, how much better overall?
    Hope that helps!
    04-12-2011 01:17 PM
  15. mmarz's Avatar
    This much better: http://forum.androidcentral.com/opti...-part-2-a.html
    04-12-2011 01:28 PM
  16. RavenSEAL's Avatar
    Calm down, it's just a forum board...bro.
    04-12-2011 03:34 PM
  17. aeroseek's Avatar
    Anyone know where to change the delay time for wifi sleep? What I mean is I have wifi sleep policy set to "When screen turns off" but it doesn't turn off for like 15min after screen off. Gotta be some variable in some file.
    04-13-2011 10:24 AM
  18. Lunacy1134's Avatar
    I've used the last 5 releases with no problem but am having trouble with the 04/03/2011 build. I am getting Force Close messages after unlocking my screen, when my launcher, Zeam, starts.
    logcat: http://dl.dropbox.com/u/5477013/logcat.txt
    Before installing this release I wiped cache and dalvik, but did not do a full data wipe.
    04-13-2011 04:53 PM
  19. pfer10's Avatar
    I had the same problem. I downloaded the new seam and it seems to work.
    04-13-2011 05:23 PM
  20. mase123987's Avatar
    Has anyone else noticed that their phone seems to charge on an outlet a lot faster than it did with stock or some of the other roms? I thought this was kind of weird.
    04-13-2011 07:42 PM
  21. Takenover83's Avatar
    The Xionia 005 kernel and maybe a couple of the others, had a charging bug. I use Xionia version 010 and the charge bug has been fixed. Stock using stock kernel always charged quickly.
    04-13-2011 07:46 PM
  22. scoutconnor's Avatar
    One thing I've noticed with this ROM is that the phone no longer vibrates when I get an email or Google Voice notification.
    I have both set to vibrate on every message.
    04-13-2011 11:21 PM
  23. ashton4life's Avatar
    MMS!!!!!! PLEASE!!!!!!MMS!!!!!! .......Amen!
    04-14-2011 01:36 AM
  24. pfer10's Avatar
    MMS works fine on this.
    04-14-2011 08:49 PM
  25. Takenover83's Avatar
    Now lets not stretch the truth. Incoming MMS does not work. Outgoing MMS is working.
    04-14-2011 08:54 PM
