05-01-2012 12:03 AM
1,740 ... 2223242526 ...
tools
  1. defcon545's Avatar
    I believe that it does that when background data is being used.
    04-21-2011 09:42 PM
  2. cheebs's Avatar
    I did not see this anywhere in the thread, I may have missed it, but for those of you who only care about the stereo bluetooth, it works just fine for playing music. I have a motorola s9-hd stereo headset and all the controls work as well. It only works for music and will not work for calls. This was the only reason I did not want to try this rom because I listen to music all day through the bluetooth while im working outside, the calls I really do not care about. After switching to the xionia 10 kernel the battery life has been great! I listened to the bluetooth about 5 hours today at work, and when I got home after 9 hours still at 62%.
    Aosp CM7 Optimus V
    Xionia 10 kernel
    844/245mhz ondemand
    PS: anyone know how to get UOT kitchen themes working on here??
    04-21-2011 10:09 PM
  3. idbl_fanatic's Avatar
    EDIT: Also every time I boot my phone it says I have two new voicemail messages when I really do not. Is there a fix for this?
    Sent from my Optimus V using Tapatalk
    call yourself, leave a VM, then clear it out. This happens if you hang up too soon after deleting a VM, or are in a poor service area at the time.
    04-21-2011 10:19 PM
  4. immascorpio1114's Avatar
    No. I wiped everything (that was required to wipe) and flashed it correctly. I changed my recovery image and flashed the rom, too. I keep getting the 3G signal when it's white, it never turns green like it does for Wi-Fi.
    04-21-2011 11:49 PM
  5. JerryScript's Avatar
    I believe white means you are connected to a tower, but no data connection exists. Green means you have data connection.
    I could be wrong. It may have something to do with 3G rev0 vs revA.
    04-22-2011 01:25 AM
  6. spaced's Avatar
    oops
    04-22-2011 03:59 AM
  7. spaced's Avatar
    I cleared it by clearing the storage for dialer. settings>applications>manage applications>all, scroll down to dialer and tap, tap clear data. Vmail indicator should disappear. This happened to my wifes v on the first day she had it. It was and still is bone stock and not rooted so im sure its not the ROMS fault.
    Sent from my VM670 using Tapatalk
    04-22-2011 04:04 AM
  8. immascorpio1114's Avatar
    How can I fix this?
    04-22-2011 07:56 AM
  9. nixie21's Avatar
    anyone else have this problem?
    I listen to Pandora through a cassette adapter in the car. before I installed this rom if I got a call i would answer and hear through the car speakers. now I could not hear anything and the caller could not hear me until I unplugged the adapter. not a deal breaker as I love this rom but would be great if it works.
    thanks
    04-22-2011 09:01 AM
  10. bjones72751's Avatar
    In the cyanogenmod settins under sound, what is attenuation of set volume?
    04-22-2011 03:34 PM
  11. nixie21's Avatar
    only one changed was rimgtone to 8
    04-22-2011 03:50 PM
  12. Kreatur3's Avatar
    I loved this ROM but switched back to Rodimus because I couldn't get my calls, or pandora, to work through my car stereo. It would recoginize I had "earphones" plugged in but no sound would come through to my stereo. Was sad since I was so stoked upon the MMS getting fixed.
    04-22-2011 04:56 PM
  13. xantus's Avatar
    from the 2.3 manual:
    Network status icons turn green if you have a Google Account added to your phone
    and the phone is connected to Google services, for syncing your Gmail, Calendar
    events, contacts, for backing up your settings, and so on.
    JerryScript likes this.
    04-22-2011 07:57 PM
  14. idbl_fanatic's Avatar
    Good to know!!! Thanks!
    04-22-2011 09:59 PM
  15. defcon545's Avatar
    is the camera issue because of the rom (the .1x, .2x etc..)?
    04-22-2011 11:44 PM
  16. tony5593's Avatar
    I need help... I flashed this Rom and it works but i can't restore my apps or data. Titanium backup force closes. I've uninstalled and reinstalled it. I've installed older versions and I've flashed the entire Rom over and i still have the same problem.
    04-23-2011 07:37 AM
  17. Kreatur3's Avatar
    You updated Titanium Backup. The update released yesterday force closes.
    You will have to find an installer for the previous one.
    04-23-2011 11:53 AM
  18. dburg's Avatar
    EDIT: Xda is reopened.
    Quickest way to get updates is to follow his twitter. Links in the OP and below. Be advised OV is for Optimus V, HC is for the HTC Hero CDMA. I will also try to keep this thread and the wiki up to date.
    Follow AOSPBOT on Twitter for latest updates
    04-23-2011 01:21 PM
  19. RavenSEAL's Avatar
    Facebook keeps force closing on me! >
    04-23-2011 01:41 PM
  20. Liquidplacidity's Avatar
    For the first time yesterday, it happened to me. Ever since, it won't even run. I guess we just have to wait for them to update it or we can go back to the version before this.
    04-23-2011 02:25 PM
  21. RavenSEAL's Avatar
    Yea, i still have the .zip file if anyone needs it.
    04-23-2011 02:40 PM
  22. thexxoffspring's Avatar
    twitter says 421. whats new in that one?
    04-23-2011 02:47 PM
  23. RavenSEAL's Avatar
    That's not for us, ours has the denotation "OV".
    04-23-2011 02:49 PM
  24. thexxoffspring's Avatar
    ohhh ok thank you for that lol
    04-23-2011 03:39 PM
  25. tony5593's Avatar
    I did... they all force close
    04-23-2011 03:51 PM
