05-01-2012 12:03 AM
1,740 ... 2425262728 ...
tools
  1. 00_wrath_00's Avatar
    Not if its compatible...
    Just use aosp's or Xionia's(<---i use this one and everything works fine)
    I was using soap recovery and I'd get constant force closes nomatter how many times i wiped and flashed. I switched to xionia. 6 version and i haven't had any problems that's why i asked.
    Sent from my VM670 using Tapatalk
    04-27-2011 11:35 AM
  2. 00_wrath_00's Avatar
    AOSP sorry typo
    04-27-2011 11:37 AM
  3. Kotton's Avatar
    Any way to enable the smiley key instead of the enter key? Without an external app?
    EDIT: Also market will not update to the newest release.
    04-27-2011 08:12 PM
  4. 00_wrath_00's Avatar
    Anyone running the 427 build? If so how well does it run?
    04-27-2011 08:33 PM
  5. Jokie's Avatar
    Do i have to wipe, and flash on every build that comes out? Is there a way to just update the current build i'm using if so' how?
    04-27-2011 09:23 PM
  6. 00_wrath_00's Avatar
    Wont download tried 7 times
    04-27-2011 10:18 PM
  7. Kreatur3's Avatar
    Downloaded fine for me.
    04-27-2011 10:29 PM
  8. idbl_fanatic's Avatar
    me too, but it is only 47 megs
    04-27-2011 10:39 PM
  9. 00_wrath_00's Avatar
    Must my connection
    04-27-2011 10:39 PM
  10. zedorda's Avatar
    47mg is correct
    04-27-2011 10:49 PM
  11. sk8dayfuknight's Avatar
    seems exactly the same as the last build, maybe a little smoother?
    anyone know of any bug fixes or differences?
    04-27-2011 10:52 PM
  12. munkyvirus's Avatar
    Flash new build, flash gapps. Done. Make a backup just in case something goes screwy.
    04-27-2011 11:03 PM
  13. sdxben's Avatar
    Is the recovery a new version of clock work mod or did he just change the date?
    Also just to to let those know that aren't sure-- type this into terminal emulator to put on the new recovery, just make sure the file is on the root of your sdcard.
    su
    flash_image recovery /sdcard/aospCWMod-OV-20110427.img
    reboot recovery
    It seems as if the recov instructions were taken off of the romrepo site because it was redesigned.
    PS- I didn't even think about following aosp on twitter-- He posts all the links to his new builds on there, easy way to download from mobile if you aren't already using tapatalk or some alternative http://twitter.com/#!/aospbot
    04-27-2011 11:06 PM
  14. RavenSEAL's Avatar
    You can just flash the ROM, but it's recommended doing the wipe just in case anything happens.
    04-27-2011 11:37 PM
  15. Eollie's Avatar
    bleh too many issues getting it to run.
    04-27-2011 11:45 PM
  16. 00_wrath_00's Avatar
    I noticed a notification bar tweek and runs smoother
    04-28-2011 12:05 AM
  17. overthinkingme's Avatar
    Wired headset, people still can't hear me.
    Phone rings normally though.
    Waiting on that headset issue before I make it a daily driver
    04-28-2011 01:21 AM
  18. sk8dayfuknight's Avatar
    Yes. I've noticed the whole interface is a bit smoother
    04-28-2011 01:57 AM
  19. bn's Avatar
    Hi, can anyone tell me what the *.img file is for? I know what to do with zips, but not sure how to utilize that aospCWMod-OV-20110427.img file. Thanks in advance.
    04-28-2011 02:12 AM
  20. Prenominal's Avatar
    With the 4/27 build and previous builds, my phone only rings once and then doesn't ring anymore for an incoming call. Is there anyway I can fix this?
    04-28-2011 02:57 AM
  21. Liquidplacidity's Avatar
    This has already been discussed somewhere in here. It's not the 4/27 build. It's because there are doubles of the ringtones in the folders. Delete one of each and they'll work fine.
    04-28-2011 03:11 AM
  22. JerryScript's Avatar
    What notification bar tweek? I can't find anything different (maybe my settings aren't showing it).
    04-28-2011 03:20 AM
  23. Prenominal's Avatar
    I'm not seeing more than one of each ringtone file ".ogg". I'm in [system/media/audio/...], don't know if this is the right directory to be looking in.
    04-28-2011 03:45 AM
  24. sk8dayfuknight's Avatar
    su
    Flash_image recovery /sdcard/ aospCWMod-OV-20110427.img
    in terminal emulator or use adb* shell with out the su. Make sure the. Img. Is on the root of your SD card before u flash
    sent from my LG-VM670 using Tapatalk
    bn likes this.
    04-28-2011 04:07 AM
  25. sk8dayfuknight's Avatar
    Try reflashing. Should be an am/pm tweak and the size of the carrier name tweak
    04-28-2011 04:09 AM
