05-01-2012 12:03 AM
1,740 ... 2526272829 ...
tools
  1. Eollie's Avatar
    I'm not seeing more than one of each ringtone file ".ogg". I'm in [system/media/audio/...], don't know if this is the right directory to be looking in.
    look on the sdcard in the same folder there. sdcard/media/ringtones
    04-28-2011 04:57 AM
  2. theboundless's Avatar
    LOCATION SERVICES WORKING (gps off) !!! Now everything is working!
    04-28-2011 06:26 AM
  3. Liquidplacidity's Avatar
    What notification bar tweek? I can't find anything different (maybe my settings aren't showing it).
    Cyanogen mod settings > Interface > Status bar tweaks.
    04-28-2011 07:04 AM
  4. nixie21's Avatar
    maybe I am a complete *****... can someone explain in ***** terms for me the process of going from the 4/15 to the 4/27? I would love not to start over but will if necessary. thanks so much
    Sent from my VM670 using Tapatalk
    04-28-2011 07:40 AM
  5. plantucha's Avatar
    Really?
    How about :
    1. headphone music
    2. bluetooth
    3. Battery life
    04-28-2011 07:49 AM
  6. sk8dayfuknight's Avatar
    MAKE FULL BACKUP of STOCK ROM FIRST!!!
    make a back up of your user apps using titanium pro(optional). take the aospcwmodrecovery.img and place it on the root of your sdcard, be sure there is the flash_image file the root of your sdcard also..then using terminal emulator punch in
    su
    flash_image recovery /sdcard/(revovery.img name)
    after done flashing boot into recovery to be sure it flashed correctly..now go ahead and put the debug.zip from zephies cm7 thread on the root of your sdcard then put gapps.zip and aospcmod427.zip on your sdcard
    then boot into recovery, install the debug.zip, then wipe data/factory resest, go to advanced and wiped dalvik cache, then wipe battery stats if u want...then install aospcmod.zip, then install the gapps. reboot. your done
    04-28-2011 07:52 AM
  7. nixie21's Avatar
    thanks for that. does that mean I can't just. 'upgrade' to the 4/27 without wiping?
    04-28-2011 08:24 AM
  8. Godbilla's Avatar
    Really?
    How about :
    1. headphone music
    2. bluetooth
    3. Battery life
    Battery life on this rom is just as good if not better than any of the 2.2 roms I've used imho..:P
    04-28-2011 08:30 AM
  9. dEris's Avatar
    A changelog would be nice so we all know whats new...
    04-28-2011 08:37 AM
  10. sdxben's Avatar
    su
    I use to use zephies cm7 debug.zip on his recov, does it work effectively on clockworkmod recov? Essentialy debug.zip formats your system/data/boot/cache. I know this would be quicker than manually going through all of the prompts to format each part manually.
    04-28-2011 08:51 AM
  11. sk8dayfuknight's Avatar
    You don't have to wipe. But it may cause problems. If it does just redo it
    04-28-2011 08:52 AM
  12. sk8dayfuknight's Avatar
    Yes I'm running the 427 build now and everything.is as smooth as butter.I used his debug zip
    04-28-2011 09:01 AM
  13. Nit3H8wk's Avatar
    Does the wired headset work yet?
    04-28-2011 09:03 AM
  14. sk8dayfuknight's Avatar
    Poor sound quality
    04-28-2011 09:11 AM
  15. nixie21's Avatar
    Thanks all set up without wiping so far so good. Anyone else have the problem While listening to pandora through a cassette adapter And a call comes in the sound will not come through the speakers like it used to and the caller. an not hear me until I unplugged the adapter?
    thanks
    04-28-2011 09:34 AM
  16. tony5593's Avatar
    Can anyone help me get from Xionia CWMA v1.2518.4 & Rodimus to this Rom. Because I've tried and nothing works. I've gotten this Rom to start and what not but after a few mins it'll reboot by itself and get stuck on the LG logo boot screen. And ill make backups of this Rom and when I try to restore, it wont work...
    04-28-2011 12:14 PM
  17. 00_wrath_00's Avatar
    I'm using xionia 1.2518.6 and I'm running this rom with no problems. Did you do a complete wipe? In recovery wipe data/factory reset wipe cache wipe boot, system , cache,and data reflash the zip. If I missed something let me know but that should fix the boot loop.
    04-28-2011 12:33 PM
  18. Prenominal's Avatar
    I only have a notifications folder and that just contains the Facebook Pop. Anything else I can do?
    04-28-2011 01:23 PM
  19. Deal Trees's Avatar
    Great ROM!!!!!
    04-28-2011 02:07 PM
  20. Eollie's Avatar
    make sure if your using something like ringdroid you dont have dups in there.
    04-28-2011 03:09 PM
  21. theboundless's Avatar
    Really?
    How about :
    1. headphone music
    2. bluetooth
    3. Battery life
    1. The wired headphones work well, no problems with audio quality.
    2. I don't use bluetooth, so I have nothing to test it with, sorry.
    3. Using the 2gtoggle app, it seems like I idle around 1% an hour with data connected all the time (2g auto switch when screen is off, 3g when screen is on). This in my estimation is really great, I don't know if I can really ask more of my phone than that. Think if I turned off that data! Who knows, it may last 1% every two hours or something like that
    [APP] Toggle 2G/3G (Home widget&Tasker/Locale plugin) [v0.0.15 / 04-06] - xda-developers
    04-28-2011 05:01 PM
  22. drezliok's Avatar
    Make the ringtones folder yourself and put them in there. Should work just fine.
    04-28-2011 06:49 PM
  23. TekOne's Avatar
    What's update on this new 4/27 release? It seem like take long to log back in 3g when off to on.. I turn 3g off for battery save when screen off.
    04-28-2011 07:41 PM
  24. prime0025's Avatar
    I do the same and don't see any difference from the previous release in terms of how fast 3g turns on or off.
    04-28-2011 08:27 PM
  25. 00_wrath_00's Avatar
    Anyone having problems with text messaging? I send a text and the reciever is getting the same texts sent to them twice. Swapped roms and back to normal. Anyone have any ideas? Could it be virgin mobile service?
    04-28-2011 09:04 PM
