05-01-2012 12:03 AM
1,740 ... 2728293031 ...
tools
  1. tony5593's Avatar
    Its the sprint recovery check out the s forum. Its what I used on my OS and now on my OV. I think the only difference is the lg wipe was removed and that it was set up for the new lcd drivers in the sprint phone which from what I can see has no effect on our phone. I know I don't have lg wipe I have data/factory reset.
    Sent from my VM670 using Tapatalk
    Well idk, Im gonna re-download and do a md5 check. Then ill wipe everything and re-flash the Rom. If it doesnt work then ill get six. Btw thanks for your help and responses.
    04-29-2011 10:19 AM
  2. prime0025's Avatar
    Why not just use clockworkmod recovery?
    04-29-2011 11:06 AM
  3. tony5593's Avatar
    I cant get that thing to install XD
    04-29-2011 11:11 AM
  4. anon(182107)'s Avatar
    is BT working properly now? I haven't had time to properly test. If it is feel free to update wiki or let me know and I will. Thanks aosp for all the hard work.
    I tested it last night on new build 04272011. Same issues for me. Connects perfectly fine but in call sound doesn't work at all. Media sound is nothing but beeps and static for me.
    Bluetooth headset device: Plantronics Explorer 390 mono
    (Haven't even had it for a week yet)
    It's good to know fixing bluetooth is a top priority. Well it is the only remaining work in progress. I've had to go back to froyo because I want my headset working. I'm still willing to help in any way I can with testing.
    Sent from my Optimus One CDMA using Tapatalk
    04-29-2011 12:49 PM
  5. unkuser's Avatar
    Bluetooth is now working for me and audio sounds great. I connect to Bluetooth stereo gateway to my stereo. It would not work prior to the v.04/27 build
    Great this is the message I was waiting for.
    04-29-2011 02:38 PM
  6. idbl_fanatic's Avatar
    Same here, I have the Plantronics stereo headset, and all I get is static, on the ear piece (jawbone) no sound at all
    04-29-2011 02:42 PM
  7. nstyle47's Avatar
    anyone elses gmail not working also alot of my widgets arent showing up either
    04-29-2011 06:17 PM
  8. justinh's Avatar
    anybody having a problem with the gps detecting correct location?
    bump
    04-29-2011 06:24 PM
  9. easyguy's Avatar
    Let me start by saying thanks.
    Everything work great. My only issue is with streaming music via bluetooth. It connects, but constantly drops the audio. I have the LG Optimus V, the factory rom worked great with the bluetooth, rarely any drop in audio while streaming music.
    04-29-2011 11:12 PM
  10. theboundless's Avatar
    I thought my push gmail was working, but now it doesn't seem like it. I may go back to the 4/15 version if I can't find out what's going on.
    04-30-2011 05:02 AM
  11. idbl_fanatic's Avatar
    Mine is working fine
    04-30-2011 11:23 AM
  12. MidtownHD's Avatar
    You could delete the cache and data, then let it re-synch again
    It should work again
    04-30-2011 02:08 PM
  13. MrMACHOMAN86's Avatar
    Everything works fine for me. I don't use bluetooth so I can't test it but other that everything works. I really don't notice a difference from the 4/15 version.
    Still waiting for the stock headset button fix
    04-30-2011 02:17 PM
  14. zedorda's Avatar
    I have the Plantronics Back Beat 903+ Bluetooth Headset/Advanced Stereo and my media audio has been working fine since the 0325 release of AOSP but like the rest the headset function for the phone gets no audio or mic function. just my data to toss in
    P.S. What ever work that is done with Bluetooth to fix it please don't lose HID support over Bluetooth. I love my Wiimote it still the best Android game controller.
    04-30-2011 03:08 PM
  15. sk8dayfuknight's Avatar
    Does any one have a problem with how quite speaker phone is?
    04-30-2011 05:44 PM
  16. sk8dayfuknight's Avatar
    Anyone having problems with text messaging? I send a text and the reciever is getting the same texts sent to them twice. Swapped roms and back to normal. Anyone have any ideas? Could it be virgin mobile service?
    i think it was VM...cuz that was happening to me the other day, but only lasted a day
    05-01-2011 12:31 AM
  17. 00_wrath_00's Avatar
    It also happened to me. And my 3g went to 1x. Works fine now must of been vm.
    05-01-2011 01:00 AM
  18. theboundless's Avatar
    thanks!
    05-01-2011 07:45 AM
  19. one80oneday's Avatar
    If your Gmail isn't syncing check account settings and make sure it's marked to sync. One time I switched ROMs and for some reason it got unchecked.
    Has anyone had any luck using newer custom kernels?
    05-01-2011 09:38 AM
  20. nstyle47's Avatar
    no that wasnt it i uninstalled gmail then reinstalled from the market and it works now...weird oh well anybody elses widgets not working i noticed i only have about half of my widgets showing up in the menu even though there still in my app drawer ... maybe its because of the spb launcher tho this launchers starting to annoy me now that the 3d effect has lost some of its luster
    05-01-2011 10:02 AM
  21. pcp135's Avatar
    I am using the Samsung WEP450 BT headset and the audio is very gargled, mostly heard static. I can understand some of the conversation but mostly it's like TV-without-reception sound.
    05-01-2011 11:35 AM
  22. 00_wrath_00's Avatar
    To my understanding from what I read the Bluetooth problem with calling most likely
    Wouldn't be fixed unless we get the gingerbread update
    05-01-2011 11:46 AM
  23. zedorda's Avatar
    I have been noticing with the 0427 release my messages take longer to send and I dont receive messages like before (as in when someone sends one i did get it soon after) but now I get them in chunks like 5-6 at a time. I was using handcent but quit 2 days ago thinking it was the problem but it didn't fix it.
    05-01-2011 03:36 PM
  24. kgill7#CB's Avatar
    i was wondering my vibration went to down after i flash 4/27 its very low, does anyone else have that problem???
    is there a quick fix??
    05-01-2011 03:39 PM
  25. Liquidplacidity's Avatar
    I noticed the same problem last night. I use Gosms
    05-01-2011 03:45 PM
