05-01-2012 01:03 AM
1,740 ... 2829303132 ...
tools
  1. 00_wrath_00's Avatar
    I also noticed that the SMS mms was slow sending and receiving. You're not alone.
    05-01-2011 04:47 PM
  2. Liquidplacidity's Avatar
    If you're expecting a text or..5, and you didn't receive any, reboot your phone. Right after I rebooted, I got them all at the same time.
    05-01-2011 05:21 PM
  3. zedorda's Avatar
    I did the reboot and now i dont even get audio alert when i receive sms/mms lol oh boy!
    05-01-2011 05:34 PM
  4. Eollie's Avatar
    I would say reflash but also wipe everything including your hinny this time.
    I want to put this out there also.
    I tried to update this today and like I normally do flash rom, then gAPPS, and then the data2ext zip from romrepo. When my phone rebooted I was missing a ton of stuff.
    I did this three times. FInally on the fourth try I flashed rom,apps, and then rebooted. did the commands and rebooted to recovery. Flashed the data2ext zip and everything works fine now. I havent noticed delays in text as my gf hasnt sent me any today. /shrug
    05-01-2011 07:33 PM
  5. Irate Iguana's Avatar
    Is the audio while recording videos fixed yet?
    05-01-2011 09:09 PM
  6. bjones72751's Avatar
    Does anyone else Jane problems with the GPS signal. I tried to use it the other day and after 20 minutes I was still searching for GPS service. Also when I disable the GPS the icon still stays in my status bar.
    05-02-2011 12:41 AM
  7. JerryScript's Avatar
    GPS works fine for me, has on every build.
    Have you tried flashing another ROM to see if it's still not working, indicating a hardware issue?
    05-02-2011 01:06 AM
  8. ghostv714's Avatar
    i have had this mod for about 2-3 weeks now ive had a few issues like wifi signal indicter flashing of and on wifi dose not want to connect unless i pull bat. freezing on lock screen litle stuff like that but i wanted to know if i can safely factory reset my phone what is the best option .. through the setting or the recovery menu ? and can any one tell me when an update will come out . ?
    05-02-2011 02:58 AM
  9. Eollie's Avatar
    No dont use the any of the reset to factory settings.
    Check the stickied thread up top of this subforum.
    To be honest it sounds like you need reflash your rom and start over again.
    05-02-2011 03:32 AM
  10. riggerman's Avatar
    I agree. I've been running this rom since the last build and have not had any issues other than the reported bugs. Make sure when you reflash you wipe everything from the recovery menu.
    05-02-2011 05:25 AM
  11. dburg's Avatar
    Does any one have a problem with how quite speaker phone is?
    Did you try playing with the DSPManager? You can bump it up on the EQ. Mine was quiet as well until I played with the DSPManager. Rumor has it that 2.3.4 is in the oven.
    05-02-2011 07:20 AM
  12. sk8dayfuknight's Avatar
    I will give that try. Thanks
    05-02-2011 08:06 AM
  13. justinh's Avatar
    anybody know why the link was pulled to the rom?
    05-02-2011 12:18 PM
  14. easyguy's Avatar
    Tried the latest build 4/29 I think and it is still having issues with connecting to other bluetooth audio devices.
    LG V.
    05-02-2011 12:30 PM
  15. 00_wrath_00's Avatar
    LG V.
    Worked fine for me
    05-02-2011 12:34 PM
  16. easyguy's Avatar
    Worked fine for me
    What did you connect it to? bluetooth headset or car stereo head unit with bluetooth?
    The reason I brought this up is because with the stock LG rom it worked flawlessly, but with this it cannot get a stable connection. Dont get me wrong this rom is great, just not being able to connect to my car head unit which I use all the time to stream music from Pandora.
    05-02-2011 01:26 PM
  17. 00_wrath_00's Avatar
    Sorry misread your post. I haven't tried Bluetooth for music just file transfers. But now that you posted this its something Ill have to try. Sorry for the misunderstanding.
    05-02-2011 01:35 PM
  18. riggerman's Avatar
    LG V.
    If you are using the 4-29 build I hope you don't have an optimus v. that one is for the HTC Hero. If you look at the letters HC= Hero, OV= Optimus V. The latest build for the optimus v is the 4-27 build.
    05-02-2011 02:03 PM
  19. gallerocks's Avatar
    why was the link for the rom removed??
    05-02-2011 02:07 PM
  20. 00_wrath_00's Avatar
    Romrepo still has the link up.
    05-02-2011 02:25 PM
  21. MrMACHOMAN86's Avatar
    What's new in this update?
    05-02-2011 05:42 PM
  22. easyguy's Avatar
    I meant the 4/27 build
    aospCMod-OV-20110427-signed
    05-02-2011 06:56 PM
  23. easyguy's Avatar
    here you go.
    LG Optimus V Changelog - ROMRepo
    They are playing with the bluetooth issues...hopefully it will be fixed soon.
    05-02-2011 06:57 PM
  24. MrMACHOMAN86's Avatar
    here you go.
    Thanks! I thought there was an update because of the new title "[ROM][WIP][ALPHA] aospCMod | AOSP 2.3.3 / CM7 (Gingerbread)" lol
    05-02-2011 07:00 PM
  25. justinh's Avatar
    they dont even have a link to the download anymore..
    05-02-2011 07:10 PM
