05-01-2012 01:03 AM
1,740 ... 3536373839 ...
tools
  1. justinh's Avatar
    Don't be scared to share feedback , I can't DL til tomorrow night!
    will do..right now the download is at 20.7mb out of 48 with about 34 min left..ill flash it right as i get it..so ill let you know...now i just dont know if i need a complete wipe..i hope not
    05-16-2011 11:58 PM
  2. llamadon's Avatar
    Installed and now every once in awhile I get a blinking triangle by the clock and it lists Digital Roaming as the network. I have no service here at all, not even Sprint so I don't know if it does anything.
    Sent from my HTC Vision using Tapatalk
    05-17-2011 12:03 AM
  3. justinh's Avatar
    so you also did NOT have service before the update..or did the update made it where you had no service?
    05-17-2011 12:06 AM
  4. munkyvirus's Avatar
    My phone runs like its on steroids with the new update, but it borked the camera.
    05-17-2011 12:41 AM
  5. anon(182107)'s Avatar
    Okay I just flashed this and mono BLUETOOTH WORKS for me! However I seem to be having very bad issues with networking (3G/wifi) Its very slow on 3G and wifi and almost nothing Internet-enabled loads. The network icons no longer change from white to green when connected. Is anyone else experiencing this?
    Great job fixing Bluetooth by the way!
    EDIT: Waited a few hours and the networking improved to normal speeds.
    05-17-2011 12:46 AM
  6. sdxben's Avatar
    The thread should be renamed as AOSP 2.3.4 now!
    05-17-2011 12:46 AM
  7. justinh's Avatar
    can you explain?..i just flashed it..dosnt seem to do anything new?
    05-17-2011 12:46 AM
  8. munkyvirus's Avatar
    Also, in my notifications
    Unexpected error...
    Please click here to help us fix the problem and when I click it nothing happens.
    05-17-2011 12:53 AM
  9. justinh's Avatar
    Unexpected error...
    im not getting any of that as of yet..im running benchmarks now..but still nothing really out of the orindary
    05-17-2011 12:55 AM
  10. sdxben's Avatar
    Unexpected error...
    Did you just wipe cache or do a full wipe?
    05-17-2011 12:56 AM
  11. JerryScript's Avatar
    The only issue I've had so far is the camera is a bit borked. The video camera still white-screens once you are done recording, and the app FCs if you then switch back to the camera. The camera itself freezes if you use any of the pre-focus settings, the only way I can get it to take a picture is by setting one of the volume buttons to snap the picture. The onscreen button and the physical camera button both start the focus square and it freezes.
    Have not had any notification issues, did you wipe cache and dalvik cache prior to flashing the new rom?
    05-17-2011 01:20 AM
  12. justinh's Avatar
    confirm the camera probem..after a few fc and trying to reopen it finally did..
    05-17-2011 01:27 AM
  13. framirezferrer's Avatar
    Any changes on using a wired mic\headphone? Thanks!
    05-17-2011 01:29 AM
  14. overthinkingme's Avatar
    On my test, the mic on the wired headset didn't work. The button on my wired headset couldn't answer the call either.
    Unfortunately :/
    Sent from my VM670 using Tapatalk
    05-17-2011 01:34 AM
  15. justinh's Avatar
    well with all this..not quite sure what it did or "fixed" lol :/
    05-17-2011 01:35 AM
  16. 00_wrath_00's Avatar
    Camera problem here to. Mine will open just wont take any pictures and refuses to go into video.
    05-17-2011 01:35 AM
  17. munkyvirus's Avatar
    Didn't wipe anything. Gonna try it now. brb.
    05-17-2011 01:37 AM
  18. Eollie's Avatar
    2.3.4 is a upgrade...
    05-17-2011 02:20 AM
  19. daddy4life09's Avatar
    how do you flash a .img file?
    05-17-2011 02:51 AM
  20. JerryScript's Avatar
    Place the ROM zip file and the recovery img file on your sdcard, then open terminal emulator, type in the following commands:
    su
    flash_image recovery /sdcard/name_of_recovery.img
    Wait till it's done copying the files, then type in:
    reboot recovery
    Now you will be in your new recovery, and you can proceed to wipe cache, wipe dalvik cache, and install your new ROM from zip, reboot, be patient as first reboot takes a while, and your done.
    05-17-2011 03:09 AM
  21. gallerocks's Avatar
    So is this new update worth getting or should we wait for an update??
    05-17-2011 03:21 AM
  22. JerryScript's Avatar
    Do a nandroid backup, try it out, and tell us!
    The point of these releases is for us to test them and report back, that's why it's free.
    05-17-2011 03:27 AM
  23. thexxoffspring's Avatar
    for sure the 2.3.4 update. i flashed it over 2.3. due to me not having time to wipe. seems pretty solid. CAMERA IS FIXED THANK YOU JESUS. alright well im off to school. have a nice day everyone
    05-17-2011 06:23 AM
  24. riggerman's Avatar
    Updated mine about 2 hours ago. Runs great, and love camera fix. Looks like the battery even lasts longer. Been surfing on 3g and playing Angry Birds since the update and only lost 20% battery. Screen has been on constantly. Much better than some other roms I've tried.
    05-17-2011 07:40 AM
  25. one80oneday's Avatar
    I tried to update last night but it kept failing so the download must have been jacked. Do we have to reinstall everything with the new update or can we flash over like old updates?
    05-17-2011 07:44 AM
