05-01-2012 01:03 AM
1,740 ... 4041424344 ...
tools
  1. prime0025's Avatar
    Is there a video fix for the latest release? White screen and freeze up after video is recorded. Shows up in gallery with no thumbnail then says video can not be played.
    05-20-2011 06:07 PM
  2. jmart981's Avatar
    hey all, i just rooted and verified root access/busy box through root checker. everything seems to be a go, i tried installing CWM recovery from the wiki link in the OP, but after following step after step, no go, while verifying root, cmd comes up as $, not #, thus, its asking me to root, however setcpu and superuser show "granting root access" before opening app, which i know is a good thing. any help on how to install recovery? would installing ROM mgr. and flashing the latest recovery through the app work? any help would be appreciated
    05-20-2011 06:34 PM
  3. duke_4386's Avatar
    I never got my camera to work perfectly again, though sometimes it can record videos with no problem.
    I also discovered it only white screens and crashes when recording in High or YouTube modes, Low and MMS qualities work fine.
    05-20-2011 06:48 PM
  4. JerryScript's Avatar
    In the cmd window, when you get the $ sign, try typing su and see if you get the # sign.
    If not, try using SuperOneClick to get a shell root, it will only be temporary, then when you open cmd and type adb shell you should get the # sign. Once you have the # sign, and have the recovery img file on your sdcard, you can follow the rest of the steps to install the recovery.
    05-21-2011 01:28 AM
  5. JerryScript's Avatar
    I just noticed that the camera doesn't work at all, not that i care lol, but anyone got any possible fixes?
    Posted a couple of pages back, click menu, open advanced options, uncheck EVERYTHING, then check either power up or power down to snap a picture. Anything that attempts to activate the pre focus seems to freeze the app.
    05-21-2011 01:30 AM
  6. jmart981's Avatar
    Camera works using search button, but could be tweaked a little. Is voice control on keyboard Absent on purpose?
    05-21-2011 02:26 AM
  7. JerryScript's Avatar
    The voice control mic is there by default I believe, at least it is on mine.
    Go to settings>>language & keyboard>>android keyboard and scroll down to Voice Input and choose on main keyboard.
    05-21-2011 02:38 AM
  8. jmart981's Avatar
    ^^ just downloaded the google voice app, automatically showed up in all applications
    05-21-2011 03:52 AM
  9. cr8rec's Avatar
    my bluetooth headphones are getting barely any signal since switching from 2.2... although sound quality is better. how is 2.3.3 compared to this one in that aspect...
    05-21-2011 04:21 AM
  10. JerryScript's Avatar
    Keep your eyes on twitter today!
    05-21-2011 11:38 AM
  11. 00_wrath_00's Avatar
    I assume there's an update coming out?
    05-21-2011 11:48 AM
  12. dburg's Avatar
    Either that or Jerry just really likes Twitter
    05-21-2011 01:57 PM
  13. jmart981's Avatar
    Everything seems to work good, but as I stated before, some tweaking to the camera would make this that much better :-)
    05-21-2011 03:32 PM
  14. gbeaguilar's Avatar
    I just flashed this rom for the very first time yesterday (originally a Harmonia/ Aphrodite user)... gota say it's pretty sweet!
    Mostly everything is pretty stable, but I did have a problem with the camera and gallery having very very high partial wake times and thus causing battery drain. I noticed these after opening both apps and experiencing erratic behavior from both (the camera bug has already been mentioned here numerous times, but the gallery would just get stuck in a loop when loading pictures). Freezing these apps did not fix this, the partial wake times continued to increase even after. I cleared my cache in recovery then rebooted and all was well. I am keeping these apps frozen, as I do not want to open them again and kill my battery.
    Anyone else experience this?
    05-21-2011 06:21 PM
  15. asadullah's Avatar
    I don't know if this has been mentioned ( I'm not reading 104 pages ) but you can access es file explorers root functions with cyanogenmod. No more paying 3.99 for root explorer.
    just download es file explorer ( it's free on the market )
    click settings/root
    then check both buttons
    success saved 4 bucks ( 3.99 ) to you technically speaking types
    05-21-2011 06:35 PM
  16. SM0k3's Avatar
    This rom is perfect, the only issue that has been bothering me is when using PLEXapp(streaming video/music) the video shows up blank but the audio still plays. I can't say that it is for sure a problem with the rom but when I went back to stock, PLEX worked perfect.
    I'll be watching for that potential update today.
    05-21-2011 07:09 PM
  17. jmart981's Avatar
    Noticed that whatever baseband the roms using, its not as stable, 3G goes in and out and has a tendency to go from white to green, can someone shed light on this
    05-21-2011 07:33 PM
  18. overthinkingme's Avatar
    I don't think this rom changes the baseband
    Sent from my VM670 using Tapatalk
    05-21-2011 07:51 PM
  19. jralabate's Avatar
    That is just gingerbread it is normal for it to do that
    05-21-2011 07:52 PM
  20. jmart981's Avatar
    Thanks, baseband "unknown " is what's listed
    05-21-2011 07:55 PM
  21. asadullah's Avatar
    The baseband is what radio image is in the phone. Roms don't typically if ever have radio images in them
    05-21-2011 08:30 PM
  22. takehull's Avatar
    That means your phone is connecting/disconnecting from Google servers. Green indicated that your phone is connected.
    05-21-2011 08:31 PM
  23. thexxoffspring's Avatar
    nothing on twitter
    05-21-2011 10:45 PM
  24. JerryScript's Avatar
    I know, but I'm still keeping my fingers crossed, like the End Of The World people keep saying, it's still not the end of the day all over the world!
    05-22-2011 12:06 AM
  25. thexxoffspring's Avatar
    i cant wait for an update. ive been missing the goodyness from this rom lol
    jmart981 likes this.
    05-22-2011 12:12 AM
