05-01-2012 12:03 AM
1,740 ... 4142434445 ...
tools
  1. rockneo's Avatar
    Same here, I won't update from the last build because of all of the bugs.
    05-22-2011 12:44 AM
  2. marekjjones's Avatar
    I'm hoping a new version comes out again soon. Guess I should follow on twitter, eh?
    05-22-2011 12:30 PM
  3. one80oneday's Avatar
    Me too. I even have SMS update for their twitter. Only bug I have is seen rotation lag.
    05-22-2011 12:35 PM
  4. Takenover83's Avatar
    This rom is perfect, the only issue that has been bothering me is when using PLEXapp(streaming video/music) the video shows up blank but the audio still plays. I can't say that it is for sure a problem with the rom but when I went back to stock, PLEX worked perfect.
    I'll be watching for that potential update today.
    Yep, which is one of the reasons I am not running this rom. Seems like a common problem on 2.3 roms looking at the plex forums.
    05-22-2011 12:37 PM
  5. whyaphoenix's Avatar
    delete
    05-22-2011 02:24 PM
  6. basketthis's Avatar
    Just wanted to stick this: Flashable zips for using aospCMod OV ROM on Sprint Optimus S in here because I love this ROM and use it on my Sprint Optimus S.
    We see the same bugs that are reported by Optimus V users. The only additional bug that isn't worked out on our phone yet is we can't receive mms (picture mail). Hoping for some more Optimus S support soon! But until then, this is what we have available and it works GREAT!
    05-22-2011 02:40 PM
  7. rockneo's Avatar
    Love seeing you optimus S guys showin' some love over here. :P
    05-22-2011 06:00 PM
  8. RavenSEAL's Avatar
    Camera is still dead for me...anyone?
    05-22-2011 06:03 PM
  9. marekjjones's Avatar
    Me too, so I went back to prior release.
    05-22-2011 11:41 PM
  10. JerryScript's Avatar
    You can use the camera, open it, press menu button, choose advanced options, uncheck EVERYTHING, then check volume buttons to snap picture. Now you take a picture by pressing either of the volume buttons.
    05-23-2011 01:54 AM
  11. tony5593's Avatar
    I have that clock issue, and what jerryScript said, worked.
    I noticed Fancy Widget skins don't show.
    And the clock app FCs when I open it.
    Plus, Browser randomly FCs, It did it while I was trying to post this last time.
    If I notice more problems, ill post them.
    05-23-2011 08:47 AM
  12. moto_android_mick's Avatar
    I would think that the devs will fix the camera/clock bugs soon enough. I use my camera quite a bit and use all the advanced features as well so I cannot switch over yet, however I did like the substantial increase in battery life so I am pumped about the next update but until then 2.3.3 is great for me!
    05-23-2011 09:35 AM
  13. RyanGHappy's Avatar
    After seeing videos of this ROM running on an Optimus V, I knew I had finally found a reason to root it. Perhaps its just advances in "one-click root" software, but this phone was WAAAY easier to root than the Intercept was. So far, I'm really loving it. The camera/clock/browser bugs are a tad bit annoying, but nothing worth going back to stock over. I've overclocked to about 768, and I can tell a difference in apps that could use a tad more speed. I've not really noticed much difference in battery drain, but it wouldn't surprise me if it was slightly worse because of the higher CPU clock.
    I'm not sure if this has been reported already, but this ROM fixes a bug in the unofficial netflix app on Optimus V's where it showed an annoying green bar while viewing videos.
    One question, though: Is it just Gingerbread or some sort of specialized add-on this rom has for the "move app to SD card" option? Compared to Virgin Mobile's stock froyo, this version really moves more of the apps to the SD card, which really helps saving on space. I'd not really heard anyone mention how much better this ROM does with moving stuff to the SD card, so it was definitely a pleasant surprise.
    05-23-2011 04:49 PM
  14. JerryScript's Avatar
    Many of the tweaks for moving to sd card have been baked into this ROM, just one of it's advantages.
    Haven't expericenced any browser bugs, so I don't know if that's a ROM issue or not.
    05-23-2011 05:16 PM
  15. RyanGHappy's Avatar
    I get the occasional FC with the browser, just like was reported in a few posts above me. Its nothing major, and doesn't happen very often, but will happen sometimes when first opening up the app after awhile. Hell, it could be something related to my overclock (although no other apps FC at the higher clock speeds).
    Oh, and one more thing to add about this ROM (or any other custom ROM if you think about it), you can actually use an up-to-date version of swype! The way virgin mobile blindly added an early version of a beta application like swype without the ability to update is completely idiotic. Swype is a good app, but the one shipping with the Optimus V had way worse prediction of words than the newest version does.
    05-23-2011 05:18 PM
  16. Magicman08's Avatar
    Cool part is the fact that with my nanroid backup of my all setup reborn rom 2.1 I can make a backup, wipe my phone and install cm7 with netflix to watch netflix, and then flash it back. (or just use my laptop)
    ***cue upward thrusts***
    05-23-2011 05:33 PM
  17. one80oneday's Avatar
    Update!
    aospbot: aospCMod-VM670-20110523-signed.zip http://www.mediafire.com/download/s8...523-signed.zip
    MD5SUM: 99704114dd0d42a58a9fe02c6cae233e
    05-23-2011 07:19 PM
  18. justinh's Avatar
    Update!
    aospbot: aospCMod-VM670-20110523-signed.zip aospCMod-VM670-20110523-signed.zip
    downloading and installing now
    05-23-2011 07:28 PM
  19. jralabate's Avatar
    Update!
    re-posted on XDA and DL now!!!!!!!!!!!!
    05-23-2011 07:30 PM
  20. dburg's Avatar
    tweet tweet :o
    05-23-2011 07:31 PM
  21. jralabate's Avatar
    Installing now!!!!!!!!!!
    05-23-2011 07:34 PM
  22. justinh's Avatar
    everything works now..camera..video..and alarm
    05-23-2011 07:35 PM
  23. jralabate's Avatar
    I have installed aospCMod-VM670-20110523 from wut i have found aosp reverted back to the old camera apk
    05-23-2011 07:41 PM
  24. 00_wrath_00's Avatar
    Awesome downloading now
    05-23-2011 07:41 PM
  25. justinh's Avatar
    agreed
    jralabate likes this.
    05-23-2011 07:43 PM
