05-01-2012 12:03 AM
1,740 ... 4243444546 ...
tools
  1. JerryScript's Avatar
    Update!
    aospbot: aospCMod-VM670-20110523-signed.zip aospCMod-VM670-20110523-signed.zip
    MD5SUM: 99704114dd0d42a58a9fe02c6cae233e
    YeeHawww!
    Guess I was a bit premature on saturday, better late than never
    05-23-2011 07:44 PM
  2. 00_wrath_00's Avatar
    YeeHawww!
    Good things comes to those who wait. But great things come when there's update
    05-23-2011 07:49 PM
  3. jroofad's Avatar
    Is the new 516 img file needed for this zip install??
    05-23-2011 08:33 PM
  4. JerryScript's Avatar
    If you're updating from the previous build, no, you can just backup then wipe cache and dalvik cache and install the new ROM.
    If you're installing from a non aospCM7 ROM, you should use the latest aospCWMod for the OV posted on twitter.
    Yep, looks like they had to revert to some previous apks to get everything to work with the framework. Thanks again for all the hard work devs!
    05-23-2011 08:48 PM
  5. GeekOutDog's Avatar
    Just installed - looks good.
    Any fundamental changes? New tweaks?
    05-23-2011 08:48 PM
  6. munkyvirus's Avatar
    Couple new things in the Cyanogen settings menu and camera and clock have been rolled back. I think that's it.
    05-23-2011 09:22 PM
  7. csrow's Avatar
    Some fonts are missing in the 5-23 version.
    05-23-2011 09:36 PM
  8. SM0k3's Avatar
    everything works now..camera..video..and alarm
    sweet.....downloading it right away.
    05-23-2011 09:52 PM
  9. Takenover83's Avatar
    Note, the camera does work. But the zoom is back to .1-.5, instead of the 1-5. No biggie, as I rarely use zoom.
    05-23-2011 10:22 PM
  10. jralabate's Avatar
    This is more them a bug fix update. This update has added more things mostly in the CyanogenMod settings menu. Here is wut I have found....In input settings under buttons "Volume rocker wake"....also in Lockscreen settings under Style options "Incoming call style"....and last In CyanogenMod setting all the way at the bottom "Permissions"(wut is this for?) Well I hope this help you all out. Post new things as you find them
    05-23-2011 10:31 PM
  11. gbeaguilar's Avatar
    Does this apply to only the stock camera? Do other camera apps now work also, and if so will they be able to use a higher zoom? Sorry, my first time using this rom was the one before this update so I don't know how the camera functioned before.
    05-23-2011 10:32 PM
  12. GeekOutDog's Avatar
    Not that it means much, but my Quadrant score increase by over 100 points going from 2.3.3 to this latest 2.3.4
    Wonder what was tweaked under the hood to give that improvement?
    05-23-2011 11:01 PM
  13. nemirn's Avatar
    I just installed it (yes, I wiped everything first) and video is not working for me.
    When I move the mode slider from Camera to Video, I only see black in the "viewfinder".
    Switching it back to camera crashes the app.
    EDIT:
    After restoring apps, data, and settings with MyBackup Root, video seems to be working. Very weird.
    05-24-2011 12:31 AM
  14. RyanGHappy's Avatar
    yeah, I updated to this new version, and I'm getting the same weird issues with the camera app. It SOMETIMES comes up, and then sometimes crashes. By this, I don't just mean a force close, I mean an entire phone reboot. Switching to video crashes the app entirely.
    I made sure to wipe the cache, and the dalek cache (yes, I know I spelled it wrong, but its funnier that way) when I updated to the new version.
    The clock app works again, and video seems to work fine again. Also haven't seen any other apps deciding to force close strangely. The only app I've noticed with strange issues now is the camera app.
    UPDATE: I think the weird issues with the camera app have something to do with overclock settings. I went back to 600 clock and the camera app and the video recorder worked fine consistently. These overclock settings worked fine on any app in the last version, but this versions camera app doesn't like them. So, for those of you experiencing camera app crashes, dial down the overclock.
    05-24-2011 01:50 AM
  15. RaeFlynne's Avatar
    Setting the camera to use the volume buttons results in a FC when the button is pressed.
    05-24-2011 01:57 AM
  16. thexxoffspring's Avatar
    Is there anyway to fix the missing character issue?
    05-24-2011 04:53 AM
  17. csrow's Avatar
    The build is missing DroidSansFallback.ttf
    android.git.kernel.org Git - platform/frameworks/base.git/tree - data/fonts/
    I installed it using "Font Changer".
    05-24-2011 06:18 AM
  18. dburg's Avatar
    Usually every build includes a Sync with the CM trees. So whatever CM has added usually is included. Permissions is pretty sweet...you can adjust what apps are allowed to do..i.e. access network etc. Which could cause some apps to not work properly but still pretty neat feature. Kind of like droidwall but built in. If you enable it...then go to manage applications you see the permissions it has. Tapping them turns certain ones off. Don't report bugs on it though because you're changing the natural apps state.
    05-24-2011 07:08 AM
  19. jralabate's Avatar
    where are they at i have not found any missing characters can u give me a screen shot or tell me where i will c them?
    05-24-2011 08:42 AM
  20. bjones72751's Avatar
    Can I, and how do I enable stagefright?
    05-24-2011 11:39 AM
  21. JerryScript's Avatar
    Stagefright is already enabled in this ROM
    05-24-2011 01:52 PM
  22. thexxoffspring's Avatar
    see the rectangle? it was like this back in BB 2.1. I also see this on fb in the browser
    05-24-2011 02:32 PM
  23. JerryScript's Avatar
    This was posted over at XDA, just thought some of you might like to know the devs do appreciate your feedback, even if they do have a life of their own and don't always have the time to respond.
    Keep the feedback coming fellas you guys are doing a great job I'm busy working on a new kernel for the rom and audio bugs are still my priority stable is my goal so no worries
    My thanks, and my donation dollars, to all the ROM devs out there!
    05-24-2011 03:00 PM
  24. radiotecha1234's Avatar
    My bluetooth play/pause button does not work anymore. Went to use it in the gym this morning and does not work. I guess it has not worked since the april update. Tried wiping and reinstalling and that did not fix it.
    05-24-2011 03:27 PM
  25. jmart981's Avatar
    One ISSUE that i found while using the phone is the SPEAKER PHONE during a call...after tapping the speaker button, the volume is very low, can anyone else replicate the problem?
    05-24-2011 04:31 PM
