05-01-2012 12:03 AM
1,740 ... 4445464748 ...
tools
  1. dburg's Avatar
    Is there a way to port this to the Optimus S?
    updated OP with this link AospCmod to Optimus S .zips
    05-26-2011 07:34 AM
  2. anon(182107)'s Avatar
    Personally I think battery life is better on this than any other 2.2 rom
    Really? My battery experience with RebornROM was disturbingly good. I left my phone on standby for five hours and returned and the percentage was at 98%
    If there's something everyone is doing to optimize the battery for AOSPCMod I'd like to know because even with the newer kernel I'm still losing 7% an hour.
    Sent from my Optimus V using Tapatalk
    05-26-2011 11:15 AM
  3. Takenover83's Avatar
    AOSP can't hold a candle to a 2.2.1 rom's battery life... Trust me, I have tested enough rom's to know.
    05-26-2011 11:35 AM
  4. Eollie's Avatar
    On the latest build battery life for me was horrendous. I rolled back to the broken camera build and right now Im at 55% and 11hr down. But that is also on wifi for the whole time.
    05-26-2011 11:54 AM
  5. JerryScript's Avatar
    Yesterday, I went 9 hours and was still at 81% on the latest build. I only made a couple of calls, checked email every hour, and checked news/weather two times, took 3 pictures, I think that's it.
    Light usage, but less than 20% drain over 9 hours seems respectable, of course it drained alot faster at home when I turned on wifi and started using the phone.
    05-26-2011 12:36 PM
  6. anon283326's Avatar
    Anyone else noticed that with this ROM, the camera doesn't work???
    Sent from my VM670 using Tapatalk
    05-26-2011 12:40 PM
  7. watskyhotsky's Avatar
    in an effort to calibrate my battery stats. I charged the phone to 100 percent, booted to recovery, wiped battery stats, rebooted to android. turned brightness 100% and kept using 3g and wifi and GPS all day until it died.
    got 7h 57m 37s before it shut itself off while i was looking at the battery stats screen.
    Should I be impressed? I would consider this is worst case scenario. i did nothing but ABUSE the heck out of every battery wasting feature of my phone, the screen was ON for almost 8 hours. it was set to not shut off at all.
    So now im charging it back to 100%, where ill do another test and see how long i get out of having all the battery saving features on.
    05-26-2011 12:40 PM
  8. watskyhotsky's Avatar
    you have to set the focus mode to "off" when its off it works fine, you just dont get autofocus.
    when any kind of focus mode is on, the camera becomes unresponsive when you attempt to take a pic and it needs to be force closed
    05-27-2011 01:02 AM
  9. munkyvirus's Avatar
    Has anyone else noticed that the battery leak has resurfaced? Down to 55% with barely any use after 5 hours.
    05-27-2011 01:08 AM
  10. Liquidplacidity's Avatar
    My camera works fine with focus. Never have had any closes at all. 2.3.4
    05-27-2011 01:30 AM
  11. JerryScript's Avatar
    I'm getting about 5% drain per hour with moderate use, and 3% with light use, I turn off wifi when I'm not using it, and I use the tweaks posted here, oher than that, nothing special.
    Note- I use $10 China Ebay batteries, two of them rotated daily, and one gets much better life than the other. I have not tested the current build with the stock battery, so my results are a bit skewed.
    05-27-2011 01:42 AM
  12. Eollie's Avatar
    I remember mmarz saying 3g would be better for cm7 roms.
    However it seems worse to me. If I leave 3g on Ill get about 7 hours with pretty much just gmail checking and texts and a couple calls..
    I did find where my biggest thief was, soundhound widget. Deleted it and my battery life jumped majorly.
    05-27-2011 02:21 AM
  13. JerryScript's Avatar
    I keep 3G on when I have wifi off, and on prev builds, it only caused battery drain when the signal was so bad it kept tower hopping (confirmed with OpenSignal app).
    Rather than a SoundHound widget, I use Shazam's Tag Shortcut in the market. Put it on one of your homescreens, and when you hear a song you want info about, just click the Tag icon and it launches Shazam in listening mode.
    05-27-2011 03:51 AM
  14. checcles's Avatar
    1) When I run Quadrant, my device is just above the Galaxy S. What else can I do to it to make it like the one on the first post?
    2) I tried installing the missing font using Font Changer and my screen went all wacked.....so much that the buttons didn't do anything and I had to pull the battery to get it back up and running. What did I do wrong? The missing symbols are annoying.
    Thanks.
    05-27-2011 04:42 PM
  15. dburg's Avatar
    You can now use ROM manager to download this Rom
    05-28-2011 12:29 PM
  16. caedryn's Avatar
    Not sure how much this helps the battery drain issue, but I noticed last night that on the latest build 0523 the governor was turned off in the performance settings. May or may not help.
    05-28-2011 01:05 PM
  17. 00_wrath_00's Avatar
    I looked and said clockwork needs installed to download roms. So I went through the list and the optimus v is not listed still. Can you explain how to do it?
    05-28-2011 01:19 PM
  18. dburg's Avatar
    Think you have to do web connect then go to download Rom. You'll see aosp
    05-28-2011 01:52 PM
  19. dburg's Avatar
    You can also select Optimus one recovery. Just be sure to reflash optimus v recovery afterwards
    05-28-2011 01:54 PM
  20. 00_wrath_00's Avatar
    Worked like a charm thanks
    05-28-2011 02:07 PM
  21. anon(182107)'s Avatar
    So I enabled the Web Connect, How do I use it?
    05-28-2011 10:36 PM
  22. defcon545's Avatar
    Sheesh, i dont know whats up with your guy's batteries but mine is working great!
    05-29-2011 08:05 PM
  23. Takenover83's Avatar
    Display 3%? Standby and Idle is almost even. Do you use your phone, ever?
    05-29-2011 08:15 PM
  24. defcon545's Avatar
    Yeah, i have been using it lightly though. Played music for awhile, vids/youtube vids, wifi and texting..
    05-29-2011 08:24 PM
  25. one80oneday's Avatar
    No internet connection, no phone calls, no apps being used... why is your phone even on? Some people actually USE their smartphone LOL
    05-29-2011 08:25 PM
