05-01-2012 01:03 AM
1,740 ... 4546474849 ...
tools
  1. watskyhotsky's Avatar
    Sheesh, i dont know whats up with your guy's batteries but mine is working great!
    it looks like you let it idle for 2 days.
    Or you charged it, then left for vacation and let it sit on the counter all weekend.
    try USING the phone, the battery wont last nearly that long.
    05-29-2011 09:27 PM
  2. GeekOutDog's Avatar
    I don't think that screen reports correctly...
    My phone today has been on a reported 13h18m51s on battery.
    It's at 20% battery life.
    I used my phone heavily today and it reports Cell Standby 47% Phone Idle 40% Display 10% and Browser 3%
    I don't buy it.
    05-29-2011 10:45 PM
  3. rockneo's Avatar
    I use my phone plenty and I could get that type of usage, I just turn off 3g when i'm not using it, saves a lot of battery.
    05-29-2011 11:54 PM
  4. munkyvirus's Avatar
    I've been testing my battery today.
    Just screwing around on the web, some sms, some music and am at 24% battery. It's been on 18 hours with out a charge. I could probably easily get another 6 hours out of it. 24 hours ain't to shabby. Xionia kernal 14.
    05-30-2011 12:36 AM
  5. JerryScript's Avatar
    I just installed 014 anykernel, and it is honestly the best my phone has performed to date, and I mean real world performance, not benchmarks. Everything from boot to initializing apps to screen animations are faster. Netflix for example launches twice as fast, and running tweaks.sh via terminal finishes in about 1/3 the time.
    Looking forward to the kernel aosp is working on, but this is great now!
    05-30-2011 02:36 AM
  6. defcon545's Avatar
    I used 3g today for like 20-30 mins and it really killed my battery, i had it at 31 ish and in like two hours it was down at 13 when i only used 3g for like 20 minutes. I think its mostly the 3g thats killing it.
    Edit:
    No internet connection, no phone calls, no apps being used... why is your phone even on? Some people actually USE their smartphone LOL
    HAHAHA very funny.
    Yes, i use my phone, i sent out a couple of texts, made a couple of calls and played a game of ninjump, but it wont show up in the battery info screen. Oh, and i do load up skyfire every couple of hours to read up on the news.
    05-30-2011 03:27 AM
  7. nemirn's Avatar
    Anyone know how to disable screen rotation of the home screen?
    I want Youtube etc., to obey the accelerometer, but not the home screen.
    Thanks.
    05-30-2011 04:27 PM
  8. beepFTW's Avatar
    depends on the launcher...
    05-30-2011 04:33 PM
  9. overthinkingme's Avatar
    Thanks.
    I recommend the app called Smart Rotator. I use it to make the camera rotate and nothing else.
    Sent from my VM670 using Tapatalk
    05-30-2011 04:37 PM
  10. watskyhotsky's Avatar
    Thanks.
    download an app called Smart Rotator, allows you to choose which apps can or cant use the rotation.
    say you want the launcher app and the music app to stay portrait and the browser can freely rotate, this is one app youd use to make that happen.
    theres probably others, but i happen to know of this one
    EDIT
    I should add that smart rotator requires internet access and phone priveliges for some reason. I just block these in droidwall and it still functions fine. all it does is turn on and off rotating. I have no idea why they need phone and internet access.
    05-30-2011 04:40 PM
  11. MrMACHOMAN86's Avatar
    Link to the Xiona 014 Kernel?
    05-30-2011 04:44 PM
  12. JerryScript's Avatar
    If you are using ADW Launcher:
    Menu>>ADW Settings>>System Preferences>>Home Orientation>>Portrait (not Auto/Sensor)
    05-30-2011 05:09 PM
  13. shawayne21's Avatar
    im still running 4/27 2.3.3 ... just cus it was said that this rom had many bugs amd wasnt fully stable yet .. how is it now?
    and which kernel is best for the 4/27 2.3.3 performance and battery life wise
    05-30-2011 07:10 PM
  14. dburg's Avatar
    phone was on pretty much 80% of the day. stock rules. 3G and wifi all day. thats pretty good for a smart phone....with those fancy sync's
    I Like Stock and I'm Fine
    05-30-2011 10:27 PM
  15. citizeninsane89's Avatar
    Could you link me to the theme you're using, please?
    05-30-2011 11:21 PM
  16. TekOne's Avatar
    I want to update to 0523, but i have alot impove txt msg. how can avoid it delete my txt msg?
    05-30-2011 11:39 PM
  17. jralabate's Avatar
    Use handcent to back them up online it's free in the market
    05-31-2011 12:22 AM
  18. dburg's Avatar
    sure here ya go http://goo.gl/J5AMa
    citizeninsane89 likes this.
    05-31-2011 07:18 AM
  19. dburg's Avatar
    defcon545: 3G is a known battery killer. Atleast it always have been for since CM5 on various devices. Depending on your area...i.e. if you're in a low signal zone 3G will go into 1x or search for towers endlessly. Which drains the battery dramatically. Best I could advise you to do is go back to stock and use the activate app then come back. Or call VM and tell them to use Sprint's roaming as well
    05-31-2011 07:21 AM
  20. dburg's Avatar
    I know that trick heroC battery life
    05-31-2011 07:41 AM
  21. doggscube's Avatar
    Just flashed the 5/23 update, and the battery icon in the notification bar isn't showing percentage. Various themes don't add it. Any way to get that back?
    05-31-2011 10:16 AM
  22. takehull's Avatar
    Go into the cyanogenmod settings from the settings menu and select "interface." Then select "status bar tweaks." You'll find a battery percentage option there.
    tl;Dr settings>CyanogenMod settings>Interface>Status bar tweaks>battery percentage
    doggscube likes this.
    05-31-2011 11:27 AM
  23. dburg's Avatar
    why you on 5/23 :P
    check rom manager
    05-31-2011 11:44 AM
  24. doggscube's Avatar
    why you on 5/23 :P
    check rom manager
    I'm still pretty new to this, I've been backing up, wiping, and flashing each one like new, I'll check out rom manager.
    ETA: not sure what I'm looking for. It says OTA updates not available. First post says the 5/23 version is the latest.
    05-31-2011 12:01 PM
  25. overthinkingme's Avatar
    Someone please mirror?
    05-31-2011 01:00 PM
