05-01-2012 01:03 AM
1,740 ... 4647484950 ...
tools
  1. dburg's Avatar
    Someone please mirror?
    Sent from my VM670 using Tapatalk
    working on it...
    05-31-2011 01:03 PM
  2. vegetajin8's Avatar
    Downloaded fine through rom manager
    Checking it out now.
    05-31-2011 01:12 PM
  3. vegetajin8's Avatar
    I'm still pretty new to this, I've been backing up, wiping, and flashing each one like new, I'll check out rom manager.
    ETA: not sure what I'm looking for. It says OTA updates not available. First post says the 5/23 version is the latest.
    Go to download rom open select aosp choose latest version 20110531
    05-31-2011 01:14 PM
  4. jralabate's Avatar
    I downloaded the newest one via rom manager and put the asop cwr back on then flashed the update. Now in rom manager I don't see aosp wut gives?
    05-31-2011 01:22 PM
  5. dburg's Avatar
    Rom Manager problem people: Open Rom Manager, press Menu...Manual flash override. Select LG Optimus One...it doesn't flash anything. Then you can "Download Rom"
    El Schisne likes this.
    05-31-2011 01:25 PM
  6. doggscube's Avatar
    Thanks. I'd like to know if this upgrades the ROM or is the same as wiping/flashing a new one.
    ETA: tried it anyway, it updated but now apps are missing including market and talk. :/
    05-31-2011 01:28 PM
  7. overthinkingme's Avatar
    premium only?
    05-31-2011 01:28 PM
  8. jralabate's Avatar
    Thanx mate works great now
    05-31-2011 01:34 PM
  9. dburg's Avatar
    please if you can use Rom Manager to get the 0531 do it. If you absolutely cannot here is a mirror. It is my dropbox so please dont go too wild http://db.tt/UGDlqML
    05-31-2011 01:40 PM
  10. KidFr3sH's Avatar
    theres no lg optimus one wen ido manual flash override plz! help
    05-31-2011 01:41 PM
  11. overthinkingme's Avatar
    I would use rom manager but I don't get LG Optimus One as an option unfortunately
    05-31-2011 01:42 PM
  12. El Schisne's Avatar
    It should be an option there. Note that the devices are not in any order that I can discern. "Optimus One" is just kinda hanging out by itself on the list.
    05-31-2011 01:44 PM
  13. doggscube's Avatar
    Updating to 0531 broke Talk and Market and Titanium Backup can't restore them. Any ideas?
    ETA: even non-system apps (Weather Bug) won't restore properly.
    05-31-2011 01:48 PM
  14. overthinkingme's Avatar
    The dropbox mirror is to 5/23 I believe
    05-31-2011 01:51 PM
  15. El Schisne's Avatar
    Go back into recovery and flash gapps again. The zip should be on Twitter. Same thing happened to me; re-flashing gapps fixed it.
    05-31-2011 01:52 PM
  16. overthinkingme's Avatar
    I am coming from a froyo rom, not from an aospcmod rom. Maybe that's why the O1 option isn't there..
    I have to flash 5/23 to download 5/31 to flash 5/31 haha
    05-31-2011 01:52 PM
  17. dburg's Avatar
    sorry updated my post
    05-31-2011 01:54 PM
  18. vegetajin8's Avatar
    It be nice if rom manager fully supported our device. But I think now that aosp through rommanager can be checked for updates. Correct me if I'm wrong. But with the 523 build I'd select check for rom update and got a rom not supported. Now with the 531 build I do that and says no updates available. So is aosp now ota capable through rom manager?
    05-31-2011 01:56 PM
  19. doggscube's Avatar
    Crap. Before you posted I decided just to go back to 0523, and now gapps is just gone completely? How do I flash just gapps?
    05-31-2011 02:00 PM
  20. El Schisne's Avatar
    That doesn't make a difference. The latest gapps is in the OP of this thread. Put it on your SD card, boot into recovery, select flash from zip, and select the file. This works regardless of what version of the ROM you're using, and I believe (not completely sure; this is my first update, personally) it's necessary each time you update.
    05-31-2011 02:16 PM
  21. overthinkingme's Avatar
    05-31-2011 02:23 PM
  22. citizeninsane89's Avatar
    Thanks!
    05-31-2011 02:39 PM
  23. munkyvirus's Avatar
    The camera has zoom options again, and can focus and take pictures. Too bad it zooms out when it takes the picture. Foiled again aosp!
    05-31-2011 03:02 PM
  24. bdfull3r's Avatar
    i am running aospCmod-OV-20110427
    if i want to upgrade to the newest version would i have to wipe everything and reflash completely?
    05-31-2011 03:07 PM
  25. dburg's Avatar
    yes. I believe Rom manager only gives CWM recovery is Koush (the dev) has the device. Not sure tho
    05-31-2011 03:12 PM
