05-01-2012 01:03 AM
1,740 ... 4748495051 ...
tools
  1. Eollie's Avatar
    Ok so I tried to update via rom manager, and well it all worked fine wxcept it reboots before you can get gapps to install. SOOOO restore backup and try to manually install it. CANT FIND THE SILLY ZIP.
    SO I will for now just for go the rom manager updates and hope somebody hosts the file..
    05-31-2011 03:15 PM
  2. anon(182107)'s Avatar
    Okay I just flashed the 0531 OTA from Web Connect. Rom Manager works great!
    Also, my battery is now draining insanely fast! I've lost almost a quarter of the battery in 20 minutes. Anyone notice any changes yet?
    05-31-2011 03:18 PM
  3. El Schisne's Avatar
    After it reboots, just go back to recovery and flash gapps. It's an extra reboot, but that seems to be the only way to do it unless you download the update from another mirror.
    05-31-2011 03:35 PM
  4. dburg's Avatar
    if you're having issues with Rom Manager here is a tutorial on how to do it.
    howto Rommanager
    05-31-2011 03:47 PM
  5. mjs2011's Avatar
    i might just wait on this update unless there's something significantly better. since i installed the xionia kernel, i've been a happy camper.
    05-31-2011 04:00 PM
  6. 00_wrath_00's Avatar
    How is the battery life on xionia in your opinion?
    05-31-2011 04:13 PM
  7. idbl_fanatic's Avatar
    I LOVE bumblebee kernel 2.6.32.9
    05-31-2011 04:18 PM
  8. JerryScript's Avatar
    Won't possibly be able to tell for at least a day, this was just released.
    05-31-2011 04:19 PM
  9. 00_wrath_00's Avatar
    I was on the assumption he was on a previous build. If not my mistake.
    05-31-2011 04:26 PM
  10. mjs2011's Avatar
    exactly. i also calibrated my battery after charging this morning, since i installed the kernel yesterday..
    i always unplug my phone around 5:40am and have 3G on while at work until i get home around 5pm. at that time, i'm usually around 55-60%. that's also counting heavy use during my half hour lunch and light use periodically during the day. after turning on wifi when i get home, and with much heavier usage, i usually sit anywhere between 25-40% by 10pm (it all depends on how much i use it). so we'll see if the kernel makes any difference. i pretty much figure that i will charge my phone every night while i sleep, which isn't a huge deal. i'm also very glad that i invested in a car charger for family road trips.
    05-31-2011 04:28 PM
  11. JerryScript's Avatar
    More candy found:
    Press the status bar then swipe left or right to adjust screen brightness
    menu_key>>settings>>cyanogenmod settings>>interface>>status bar tweaks>>statusbar brightness control
    Max VM Heapsize option increased to 48m
    menu_key>>settings>>cyanogenmod settings>>performance
    Sour Candy: Camera zoom is now 1-5, but the zoom snaps back to 1 when you take the pic. :P
    Edit: Screen on/off animations don't appear to be working, no big deal, just reporting.
    05-31-2011 04:59 PM
  12. afro31's Avatar
    i found dis on da romrepo optimus V change log lol
    Version Release Date Changes
    aospCMod-OV-20110534 34 May 2011 * Updated to CyanogenMod 8 (Honeycomb)
    05-31-2011 05:50 PM
  13. ohfivepro's Avatar
    i am running aospCmod-OV-20110427
    if i want to upgrade to the newest version would i have to wipe everything and reflash completely?
    in recovery just wipe cache and davil (however you spell it) then flash the new rom.
    dont forget to backup before rom flash
    05-31-2011 05:56 PM
  14. csrow's Avatar
    please if you can use Rom Manager to get the 0531 do it. If you absolutely cannot here is a mirror. It is my dropbox so please dont go too wild http://db.tt/UGDlqML
    Thank you. I really didn't feel like installing 523 just to be able to use the Rom Manager. The Rom Manager does not work with 2.2.1 set up.
    05-31-2011 06:17 PM
  15. FLDataTeK's Avatar
    I am having a problem with TweetDeck FC after I add accounts to it.. I didn't have this issue until I loaded aospCMod. Anyone have any suggestions? I have wiped caches etc.
    05-31-2011 07:06 PM
  16. mjs2011's Avatar
    More candy found:
    Jerry, do you have any ideas on what the VM Heapsize increase means?
    05-31-2011 07:19 PM
  17. El Schisne's Avatar
    It's a computer science term.
    Dynamic memory allocation - Wikipedia, the free encyclopedia
    Java Virtual Machine - Wikipedia, the free encyclopedia
    Broadly speaking, bigger heap = less available memory, but possibly faster performance. Smaller heap = more available memory, but possibly slower performance. YMMV.
    05-31-2011 07:40 PM
  18. shawayne21's Avatar
    what bugs are on this? and how stable is it compared to his 4/27 2.3.3 release?
    05-31-2011 08:25 PM
  19. JerryScript's Avatar
    Throw it on your phone, and help us find the bugs.
    05-31-2011 09:54 PM
  20. MrMACHOMAN86's Avatar
    My 3G isn't working. I wiped everything, and still nothing. (I used the zip provided by a user on an earlier page)
    05-31-2011 10:04 PM
  21. overthinkingme's Avatar
    Data outage
    Sent from my VM670 using Tapatalk
    05-31-2011 10:05 PM
  22. MrMACHOMAN86's Avatar
    Oh data outage. Ok thanks!
    05-31-2011 10:08 PM
  23. itsnotadam's Avatar
    Thats odd, I'm on RebornROM and I have data...
    05-31-2011 10:20 PM
  24. itsnotadam's Avatar
    I was just about to install this rom, now I'm scared LOL.
    05-31-2011 10:21 PM
  25. easyguy's Avatar
    DAMN!!!!!!!
    I thought it was a ROM issue, so I wiped everything and reflash.............GREAT!
    Thanks a lot VM for crappy service.
    05-31-2011 10:33 PM
