05-01-2012 12:03 AM
1,740 ... 5354555657 ...
tools
  1. JerryScript's Avatar
    Do the same people that port also to the OV also make ROM manager? I'm all for supporting the dev but the app only made things more difficult IMO. Hopefully it will still get uploaded somewhere for people to download...
    No, the port of aospCM7 for the OV is not handled by the same people who make clockworkmod or ROM Manager. However, the android dev community does help each other out on a daily basis, so there may be members of various teams helping each other out.
    06-05-2011 09:37 PM
  2. KidFr3sH's Avatar
    oh thx bro!!!(:
    06-06-2011 12:31 AM
  3. bigsupersquid's Avatar
    the OP has a link to AOSP's thread on xda if you want a current direct download.
    not a rom-manager item as far as I know, has to be flashed through recovery.
    edit
    blast. download link gone. I was just corrected on xda
    06-06-2011 11:54 AM
  4. Irate Iguana's Avatar
    I found out why AOSP has horrific battery life with this version. While checking the battery stats to find the culprit, I realized that my phone hasn't spent one second asleep!
    06-06-2011 02:49 PM
  5. 00_wrath_00's Avatar
    And here I just ordered a new battery thinking that was the problem.......thought it still could be my battery too.
    06-06-2011 03:03 PM
  6. mjs2011's Avatar
    that's really concerning about the phone never sleeping. is there a way to change this? as much as i love the perks with this ROM, i'm tempted to make a switch to compare.
    06-06-2011 03:10 PM
  7. mmarz's Avatar
    06-06-2011 04:02 PM
  8. 00_wrath_00's Avatar
    Good looking out mmarz.
    06-06-2011 04:05 PM
  9. TekOne's Avatar
    So, the latest rom handle MMS?
    06-06-2011 04:29 PM
  10. TekOne's Avatar
    so, i can flash this rom from recovery mode?
    06-06-2011 06:01 PM
  11. xtravbx#CB's Avatar
    MMARZ - thank you
    When trying to flash that in the latest CWM, it fails for me.
    I think 3.2.0.0
    Anyone else able to flash it w/ that recovery?
    06-06-2011 08:38 PM
  12. JerryScript's Avatar
    The latest aospCWMod version hasn't been updated in the OP here, but it has at xda.
    aospCWMod-VM670-20110531.img
    06-06-2011 08:49 PM
  13. Eollie's Avatar
    Everything was working fine until tonight when swype decided to misspell every single word and I uninstalled it. Now I get force close after force close.
    06-06-2011 10:31 PM
  14. JerryScript's Avatar
    Just an idea, try the fix permissions in ROM Manager. I'm new to RM, so I don't know if that will help or not.
    06-06-2011 10:52 PM
  15. pbailey212's Avatar
    5.31 is not the current aosp, 6.1 mms fixed is. I can't get it to flash, I had no problems on previous versions, even with rom manager. It just keeps aborting in the flash process. I tried deleting it and redownloading it, same outcome
    06-06-2011 11:30 PM
  16. rockneo's Avatar
    What is your recovery?
    06-07-2011 12:03 AM
  17. youngSWi's Avatar
    Does anyone just have the zip for the latest build of ASOP they can send me? I just cant get it on rom manager...
    06-07-2011 01:09 AM
  18. JerryScript's Avatar
    It was posted by mmarz one page back: http://forum.androidcentral.com/976679-post1357.html
    06-07-2011 01:13 AM
  19. autobotguy's Avatar
    After spending most of the day unbricking my phone (damned factory VM wipe/restore, plus infinite CWM loop) I FINALLY have this ROM installed and it is quick as hell! Only problem is that when I turn off the phone and turn it back on, the recovery kicks in and wipes the ROM to a new status and I lose all my apps and progress. I'm using the Xionia Recovery. Is there any way to get this worked out??? I'd greatly appreciate any assistance.
    06-07-2011 03:36 AM
  20. watskyhotsky's Avatar
    use adb and push the last version of the Clockworkmod recovery. the latest one has issues, not working right for me either.
    06-07-2011 04:26 AM
  21. Kreatur3's Avatar
    The one from aosp twitter worked fine for me. The one from rom manager was messed up for me.
    06-07-2011 10:42 AM
  22. ravenroost's Avatar
    FWIW,
    I also had trouble with 601, and switched to 531 (which, so far works fine). I am also glad I'm not the only one that keeps bricking my phone. Misery loves company I guess.
    06-07-2011 10:51 AM
  23. iphear's Avatar
    FWIW,
    Funny everything's working perfect for me
    06-07-2011 11:32 AM
  24. autobotguy's Avatar
    .....and now my phone seems to randomly reboot....which means it automatically wipes everything and puts this ROM back into its stock state. Is this because I'm using the Xionia recovery instead of the ClockworksMod recovery???
    06-07-2011 12:13 PM
  25. mjs2011's Avatar
    so i just switched to the Harmonia ROM yesterday, and i must say that i wish we could combine the two ROMS! AOSP is definitely more visually appealing but with so many bugs/headaches. Harmonia runs so smooth and has much better battery life, but Netflix has the green bar and it's not quite as visually appealing.
    06-07-2011 12:52 PM
