05-01-2012 01:03 AM
1,740 ... 5556575859 ...
tools
  1. Eollie's Avatar
    Ok something a little weird.
    I came from Bumblebee back to AOSP.
    Everything seems to be working great - BUT
    Plants VS Zombies was working totally flawlessly on Bumblebee. On AOSP every time I load it, it freezes, have to close & reload it multiple times before its playable.
    I did a full wipe before switching to AOSP and to be honest really don't have much installed but GAPPS.
    I never get it to go past the loading screen freeze.
    Anybody have any clue what is causing this?
    06-09-2011 03:30 PM
  2. Retorrent's Avatar
    So I've been following the forums here at androidcentral for the past few months with my Optimus V and have loved how far I have gotten with being able to flash whichever recovery/roms I want. Love this rom and have only been experiencing one problem with the vibrate function which breaks even after new flashes of the rom. Since Rom Manager has been updated to support the Optimus V I have had issues with flashing so I put back thunderc on it and have been able to re-flash the rom to see if it fixes the issue with vibrate. Last night I flashed and before I went to sleep the vibrate function was working. When I awoke it was no longer working. Any clue as to what might be causing the issue?
    Could it be a hardware thing? Like possible failure? Or is it just with only specific ROM you have used?
    06-09-2011 03:57 PM
  3. kirurus's Avatar
    No because it still vibrates with haptic feedback and such. It just doesn't vibrate on notifications. And as stated before it was working after I had flashed last night. I believe it stopped working after I accidently toggled silent mode on the lock screen this morning. I may just need to re flash and stay away from the toggle... Im using the current aosprom and kernel 6/01.
    06-09-2011 04:24 PM
  4. 00_wrath_00's Avatar
    Have you tried setting the vibrate in message settings? Just a thought
    06-09-2011 04:39 PM
  5. kirurus's Avatar
    Actually I just did a minute ago. LOL!!! HUGE NOOB HERE!!! XD Thanks!
    06-09-2011 05:56 PM
  6. 00_wrath_00's Avatar
    Its all good lol
    06-09-2011 05:58 PM
  7. rockneo's Avatar
    To make it work on cm7 when it freezes press the home button, then open the game again, then it works for me.
    06-09-2011 07:51 PM
  8. nixie21's Avatar
    I have the same pvz issue on aosp as well
    06-09-2011 08:21 PM
  9. 00_wrath_00's Avatar
    Anyone experiencing when ur typing that when a text comes it it auto rotates when the text is received then rotates back? Is this normal?
    06-09-2011 09:38 PM
  10. keystonep1mz's Avatar
    How do you get rid of the clockwork recovery?
    06-11-2011 03:57 PM
  11. Irate Iguana's Avatar
    Yeah, it does this to me sometimes. I think the sensor thinks that you moved the phone when it vibrates.
    Flash a new recovery.
    06-11-2011 04:30 PM
  12. keystonep1mz's Avatar
    I have seem to forgotten how to do that
    06-11-2011 05:07 PM
  13. KemikalElite's Avatar
    Open Terminal Emulator app.
    Enter commands:
    $ su
    # flash_image recovery /sdcard/nameofrecovery.img
    # reboot recovery
    06-11-2011 05:39 PM
  14. keystonep1mz's Avatar
    thank you it worked
    06-11-2011 06:02 PM
  15. Irate Iguana's Avatar
    What IS the difference between the may 31st and june1st updates? Because june1st gives me horrible battery life and I just flashed may 31st over it so I could have the old battery life.
    06-13-2011 02:48 PM
  16. JerryScript's Avatar
    There were actually two 06/01 builds, one had a fix for MMS, and may have had other fixes that seemed to be left out by accident during the first 06/01 build. Can you send and receive MMS?
    06-13-2011 03:16 PM
  17. staticmaal's Avatar
    I flashed the picasticks0.7 kernel and it gave me better battery life. I think the mms was fixed in the June 1st version.
    06-13-2011 03:18 PM
  18. Irate Iguana's Avatar
    I can send and receive MMS in the 05/31st update .I tried picasticks with 06/01 and I still had horrible battery life and had lots of problems with certain apps, oh and the screen wouldn't tilt when I would turn it :P.
    06-14-2011 02:01 AM
  19. madmardigan's Avatar
    Since Rom Manager sucks and won't let me download the ROM after their update, where can I get it to manually flash it?
    06-14-2011 09:21 AM
  20. JerryScript's Avatar
    Try reading a couple of pages back in this thread, it's been posted several times, and two pages back is the most recent.
    06-14-2011 09:43 AM
  21. gyanos422's Avatar
    i was having a lot of trouble with this when i started. i just needed to read directions to find out i didn't do what i thought i did: flashing a new recovery. after that it went smooth and im very pleased. is File Manager and some of the other preinstalled apps safe to uninstall? i prefer a different file manager and wanna get rid of the other one. thanksfor everything
    06-14-2011 11:24 AM
  22. JerryScript's Avatar
    I think File Manager is a system file, and it's pretty small. You might leave it installed, and go ahead and use another file manager. Uninstalling system apps can sometimes cause issues.
    Use Titanium Backup to do a complete backup of apps+system_apps+data and you'll be covered if you do uninstall something you find you need later.
    06-14-2011 01:00 PM
  23. yroc1234's Avatar
    Ugh...I can't get a data connection with my phone. I had this issue previously and the solution involved forcefully making the phone activate through the activation app, but thats not available for this rom and neither is the plethora of dialing codes that don't work with this rom (##virgin# and others). What can I do to get data back?
    06-14-2011 01:22 PM
  24. mmarz's Avatar
    1. Back up your phone.
    2. Flash a Froyo rom.
    3. Run the activate app.
    4. Restore your backup.
    06-14-2011 01:33 PM
  25. yroc1234's Avatar
    [QUOTE=mmarz;996873]
    Is that "Confirmed" to work?
    06-14-2011 01:43 PM
