05-01-2012 01:03 AM
1,740 ... 6566676869 ...
tools
  1. Kreatur3's Avatar
    Sounds like you aren't booting into recovery just trying a reboot. You are holding down the volume up or down key plus the home and power buttons correct?
    daryllh likes this.
    07-12-2011 11:27 AM
  2. daryllh's Avatar
    I want to reboot into recovery. That's my desire.
    I tried all of the button combos. I have gotten it into 'safe mode' but it's still hung up on the green robot getting started screen.
    07-12-2011 11:44 AM
  3. daryllh's Avatar
    Got it to reboot into recovery. I tried one last 3 finger salute and it actually worked this time. Go figure.
    Thanks for the help. I appreciate the quick response.
    07-12-2011 11:54 AM
  4. Kreatur3's Avatar
    No problem. All day long I sit at a computer with plenty of downtime so tend to be on the android forums a lot lol.
    07-12-2011 12:37 PM
  5. roxasj9112's Avatar
    This ROM by AOSP is old. Get the new one via ROM Manager. You gotta have ClockWork though...
    I was just using this ROM.
    Main problems:
    Black screen after calls
    No receiving MMS
    Constant reboots (I have no clue why. My Optimus V is brand new, barely a week old)
    Laggy at times
    07-12-2011 03:04 PM
  6. Kreatur3's Avatar
    Main problems:
    No receiving MMS
    Laggy at times
    You don't have to use Rom Manager, lots of posts here with the link, or use clockwork.
    You can use xionias recovery to flash any rom out there and if you are tired of this one you can always try one of the other numerous ones out there.
    07-12-2011 03:12 PM
  7. rockneo's Avatar
    Mms is fine and no random revolts you must be clocked too high or are using the SD card that came.with.the phone Which is no good it made my.phone reboot on stock
    Sent from my Optimus V
    07-12-2011 03:15 PM
  8. Kreatur3's Avatar
    He was saying that Aosp is old and talking about updating through rom manager. I'm willing to bet he is using an older version that had broken mms.
    07-12-2011 03:20 PM
  9. MrHyde03's Avatar
    hmmmm k. so, the rom is great. i love it. 'cept.... the screen rotation. when the phone is freshly booted, it rotates quick. i mean REAL quick. it's great, very responsive. but, after a couple hours it starts to slow down. and by the end of the day it will take about 5 seconds for the screen to rotate.
    anybody else have this "problem"?
    07-12-2011 08:00 PM
  10. JerryScript's Avatar
    It has been mentioned.
    Based on the work Blarfie and ath3nos have done on their ROM, I believe it has something to do with the coding getting stuck on the lack of a hardware keyboard, which it checks each time screen rotation is attempted (if the keyboard is out on phones with a sliding keyboard, the screen wont rotate out of landscape).
    07-12-2011 08:05 PM
  11. jSterling's Avatar
    Sometimes the screen takes 2 or 3 seconds to load but it don't happen to me often. I don't use the keyboard sideways a lot.
    The only real problem I've had is the android keyboard actually force closing, but comes right back, its not a big problem just a lil annoying sometimes.
    Sent from my Optimus V running CM7 @ 825mghz
    07-12-2011 09:09 PM
  12. jakarrer1's Avatar
    What recovery are you using? Did you also flash the gapps.zip?
    I Gave up on Aosp and am now running Bumblebee 2.4. It was able to install flawlessly.
    I tried all options listed on multiple forums and was not able to get Aosp to boot past the Android scroll.
    My best guess is that there is a compatibility issue with CWM that I am just not quick enough to catch.
    On a side note I keep getting switch to "Edify scripting" errors when installing .zip files. I was able to get Bumblebee to load after re flashing CWMR.
    Just out of curiosity, what's that about?
    Thanks,
    Jake.
    07-13-2011 08:49 AM
  13. pbailey212's Avatar
    Don't use cw, use xionia recovery
    07-13-2011 09:22 AM
  14. jakarrer1's Avatar
    It's my understanding ( maybe false ) that I can not use Xionia because I am not able to run SDK on my Win7x64 machine ( my only option ). I have no interest in setting up a virtual machine to run XP.
    Is that correct?
    Thanks
    07-13-2011 10:06 AM
  15. idbl_fanatic's Avatar
    Is that correct?
    Thanks
    I was using XIONIA and I run WIN7 64
    07-13-2011 10:15 AM
  16. jakarrer1's Avatar
    Ok, I will do more searching/research on how to do that. Thank you.
    07-13-2011 10:28 AM
  17. pbailey212's Avatar
    You don't need Sdk just download it and flash it with terminal emulator
    jakarrer1 likes this.
    07-13-2011 10:28 AM
  18. jakarrer1's Avatar
    Got Xionia up and running through Terminal emulator. Thanks again.
    07-13-2011 12:16 PM
  19. itsnotadam's Avatar
    Is anyone else having trouble using Groove IP with the headsets, on this rom?
    07-13-2011 10:43 PM
  20. Eollie's Avatar
    Headsets are a known non working bug.
    07-13-2011 10:45 PM
  21. MrHyde03's Avatar
    keep getting a lot of network errors and restarting data services don't help any
    07-13-2011 11:45 PM
  22. mtndew948's Avatar
    gapps-gb-20110325-signed.zip
    MD5: 4cbe712c0bde778fb7f2d32d32b57dd8
    aospCMod-OV-20110531-signed.zip available on Rom Manager under "Download Rom"
    aospCWMod-OV-20110531.img
    MD5: e75e92d259c675b9dfd5113bd1cd0939
    WIKI
    Follow AOSPBOT on Twitter for latest OV updates
    Live Support
    [GPL] Kernel Source
    Original XDA Thread
    aospCMod from Optimus V to Optimus S .zips
    HOWTO Logcat (DEBUG)
    ROM/Kernel DEV: aosp (Donate)
    I'm just sharing the rom link with android central.
    aospcmod-ov-20110427 is what i currently have on my phone but witch one is better the one i have now or gapps-gb-20110325-signed.zip any help would be much appreciated.
    07-15-2011 12:25 AM
  23. bjones72751's Avatar
    Why not run the 6/01 build? Its the newest and most updated. The only bugs are bt/headset and camera, but there's a camera fix.
    07-15-2011 12:32 AM
  24. mtndew948's Avatar
    im still sorta newbish and i dont know how or where to look for updates at,and if you you would be so nice to send me the link or tell me where to find the 6/01 build it would be much appreciated
    07-16-2011 01:16 AM
  25. JerryScript's Avatar
    Go back three or four pages, I posted the official link from the romshare deployfu website. Go back a few more pages, and someone else posted it, go back a few more pages, and someone else posted it.
    I know it's hard to find things right now, your best bet for up to date info is to start at the end of the thread and work your way backwards.
    mtndew948 likes this.
    07-16-2011 03:05 AM
