05-01-2012 01:03 AM
1,740 ... 6667686970
tools
  1. gater's Avatar
    do you need rom manager premium to get this? i don't see it in free rom manager...
    07-16-2011 11:08 AM
  2. watskyhotsky's Avatar
    you have to use rom manager to install clockworkmod 3.2.0.1
    then use manual flash override to tell rom manager your phone is a "LG Optimus One P500"
    now when you go to download rom, it will show under AOSP.
    its just in the wrong place. youll need the GAPPS too.
    the rom is labeled for VM670 so its clearly the optimus V version of aospcm7
    anyways thats how you get it on rom manager
    07-16-2011 12:25 PM
  3. gater's Avatar
    ugh. none of my buttons work properly in 3.2.0.1 recovery. My menu button makes the screen disappear, home does the same, back resets the screen and search does nothing.
    07-16-2011 01:04 PM
  4. zedorda's Avatar
    Try the side buttons: Voice / Camera
    07-16-2011 01:43 PM
  5. bjones72751's Avatar
    Volume rocker moves up and down, camera selects, back goes back.
    07-17-2011 02:26 AM
  6. bradhoschar's Avatar
    Installed this ROM on Friday. Had a lil problem syncing to Goog, but after i wiped the cache, it worked fine. I have CPU master free running stable at 787...haven't noticed ANY bugs with it....Very good work guys, keep it up
    07-17-2011 08:28 AM
  7. mtndew948's Avatar
    what is the camera fix for the 6/01 build?i know its probably in this forum somewhere but i really dont want to dig through hundreds of pages trying to find it..
    07-17-2011 06:37 PM
  8. danieljc1's Avatar
    The camera fix is for fixing the auto focus I believe.
    07-17-2011 08:37 PM
  9. mtndew948's Avatar
    thanks,but i know what its for what i meant tho is how do i get it,is it something i have to install on my phone or what?
    07-18-2011 01:52 AM
  10. defcon545's Avatar
    I believe its a flashable zip that you can flash from the recovery menu, the one where you flashed the rom. The download should be maybe 10 pages back or so.
    07-18-2011 02:27 AM
  11. mtndew948's Avatar
    appreciate it.
    07-18-2011 02:48 AM
  12. mtndew948's Avatar
    i have dug through alot of pages and i cant find the link for the camera fix,can someone please help me
    07-18-2011 03:17 AM
  13. JerryScript's Avatar
    If you use the search this thread tool at the top of the page and type in camera fix, you can find a link to the original post about it over at xda, search is your friend, or should be!
    mtndew948 likes this.
    07-18-2011 03:26 AM
  14. Eollie's Avatar
    Search always lobs raccoon at me...so its my enemy.
    07-18-2011 06:17 AM
  15. anon283326's Avatar
    So is it just a zip file that you can do a dirty flash on in recovery mode? Our do u have to wipe some stuff first...?
    07-18-2011 10:30 AM
  16. JerryScript's Avatar
    You should wipe cache and dalvik cache since the lib files are different. Then just flash it.
    07-18-2011 01:40 PM
  17. mtndew948's Avatar
    haha i never even noticed thread tools
    07-18-2011 07:50 PM
  18. mtndew948's Avatar
    when i try to flash the camera fix this is what it does
    install from sd card...
    finding update package...
    opening update package...
    E:wrong digest for META-INF/MANI
    FEST.MF in META-INF/CERT.SF
    E:Verification failed
    installation aborted.
    07-18-2011 08:19 PM
  19. anon(182107)'s Avatar
    It's probably a corrupted download. Download it again. If the new download still doesn't work try selecting that option "disable signature verification". Try a new download first.
    Sent from my Optimus V using Tapatalk
    07-18-2011 08:26 PM
  20. anon283326's Avatar
    Yeah, I get the EXACT same error :/
    Sent from my LG Optimus V using Tapatalk
    07-18-2011 08:53 PM
  21. MrHyde03's Avatar
    turn off verification from within your recovery and it'll let you flash it.
    07-18-2011 09:40 PM
  22. anon(182107)'s Avatar
    Let this be a lesson to everyone. Always check for errors and sign everything properly before you publish/upload to the internet.
    This happened to me once. Everyone needs to make sure updates meet a high enough standard.
    07-18-2011 10:55 PM
  23. SagaciousB's Avatar
    Sad - this thread seems to be dying. I guess the long delay since a new release has kind of killed interest in this rom? Or are the other new gingerbread roms stealing the attention?
    07-21-2011 01:56 PM
  24. Kreatur3's Avatar
    Both. I left aosp because, for me at least, ath3nos has more things working and a few extra options this one doesn't. Once IHO has ext support working properly I will switch to that one as it is the most actively developed CM7 rom for our phones at the moment. Ath3nos doesn't count because it isn't for our phone and based off the same source that IHO is using.
    07-21-2011 02:00 PM
  25. Nit3H8wk's Avatar
    I tried iho just too choppy/laggy compared to this rom. also rom manager can't find any roms under download just gapps and superuser so I can't even use the most recent version of this rom.
    07-21-2011 03:12 PM
