Rename xionia to vrecovery.Img.
with terminal emulator type as shown.
Su
Flash_image recovery /sdcard/vrecovery.img
And make sure the recovery is on the root of the SD, it just makes it less typing
Best bet is to not use ROM Manager to flash a recovery at this time. Download it from the OP of this thread, place it on your sdcard, then use adb or terminal emulator to flash it;
adb:
adb remount system
adb shell
flash_image recovery /sdcard/NAME_OF_RECOVERY.img
Terminal:
su
mount -o remount,rw -t yaffs2 /system /system
You don't want the second mount command, it is remounting the system ro=Read Only, you need to keep it rw=Read Write in order to flash the recovery image. When you reboot, it will automatically go back to ro, so no need for that command.
Remove this line:
# mount -o remount,ro -t yaffs2 /dev/block/mtdblock5 /system
There is one with a camera fix?!? WHERE!?!
Ok, so how do you activate the phone once you are on this ROM? the ##VIRGIN# doesn't work, and neither does the activate app. I am trying to troubleshoot this MMS not working, and VMU wants me to re-activate the phone
The only way to get the activate app and those codes working is to go back to stock ROM or a Froyo VM ROM with the app. If your trying to fix MMS did you make sure the Virgin Mobile APNs are activated? Try download APN Manager on the market. When you open that app there should be a green icon with "APN Enabled: Virgin Mobile"
If that's not there that's whats causing the problem with MMS.
Okay I'm back with one more problem...I'm still trying to use Xionia, I just rerooted my phone and now I'm in Terminal Emulator. I typed in adb shell, but before I could type in su to continue flashing the recovery, it said "adb: permission denied." Thanks in advance, again lol
